309.1 miles since last fill up
36.13 mpg
sport AT, 80% freeway with AC (50% of that at 80 mph. On my car, at 80 mph you're right at 3000 rpm. 75 mph is 2750rpm, and 70 is around 2500).
That means 90% Ethanol 10% Gasoline? So, I can use what's known as the 85% blend we hear lately?
I don't even think they have this in Atlanta area.
There are many different ratios of ethanol to gasoline...E5, E10 (gasohol), E15, E20, E85, and E100 (pure ethanol).
E5 and E10 are supposed to be OK for cars that were designed for pure gasoline, but fuel economy is usually adversely affected.
E10 (10% ethanol) gasohol is the most that should be put in the Fit according to the owner's manual. Some states have E15 (15% ethanol, 85% gasoline). I know there are some people on these forums who live in these states and have used this fuel...to the detriment of their fuel economy.
E85 is the fuel commonly used for "flex-fuel vehicles" with 85% ethanol. Ratios like E20 and E100 are used in other countries like Brazil.
The Fit owner's manual says not use gasoline containing more than 10% ethanol or 15% MTBE.
It Is the mandatory fuel in all counties surrounding Houston (where I live) and I have found that I get about 5-7mpg worse on E-10 than when I go to the next county over and fill up with regular gasoline.
That seems odd... ethanol has about 70% of the energy potential of gasoline, so with E10 you should only be losing about 3% of your mpg. Which is more like 1 mpg, instead of 5-7 mpg.
Your results sound more consistent with either a) a car that just isn't dealing with the E10 blend properly, or b) E85 usage.
I don't do much highway driving, but it's not really city either...more suburban...I'm over 40 alot. Did have several short trips this week (I'm only 12 miles from work) but I hope it will get a little better...up to 30 at least.
46.037 gallons
34.4 MPG
30% freeway 65-75 mph
65% two lane 30-60 mph
5% town/city
Sport A/T
That's what I always thought, too. Yesterday or the day before, there was an article in the local fish wrap by some expert saying that Ethanol has higher octane and will "increase mileage". I didn't think higher octane led to better mileage.
Bubba :confuse:
Ethanol has a lower energy potential than gasoline, and will always REDUCE mileage, not enhance it. This isn't even argued by anyone serious anymore.
Yaris 37, epa 34/40
Fit 35.8, epa 33/39
Nissan Versa 27.8!/ epa ?
Kia Rio 30.3/ 29/38 with a/t
Finally! Anyway, the figures bear out what people have been reporting herein. It also marks the first time I've seen cars, the Fit and Yaris, get a realworld average mpg completely in agreement with EPA estimates.
They highly favored the Fit. My quest is ended. I will buy a Fit when they offer it with a 1.3 liter conventional engine--should average 40-42mpg, but that's a topic for another forum. And I will only drive it when my 2000mpg ebike won't get me there.
Sorry Versa, Rio, Accent, Caliber, and some kind of Suzuki (forget). :shades:
You will be waiting for your Fit for a very, very long time if your waiting for a 1.3 litre Fit to come to America.
Might be why my mpg is lower than I expected. We are already using the 10% blend here in VA.
mostly highway at 65 MPH
some heavy traffic when I first picked up the car from the dealer near Hershey PA (some event, traffic was just sitting) - some more traffic on my DC trip.
i'm hoping it does better after breaking in.
LOVE MY FIT
only got 26MPG what happened?????
wondering if it is SHEETZ gas??????
anyone know where i can find stats on fuel from different gas stations?
not happy with 26MPG
still love my fit :shades:
311.4 miles
refill 8.991 gallons
34.63 MPG. That was on Costco gas. I filled up with convenience store this time.
ALERT: The "gas" light came on just as I was pulling in. I refilled 8.991 gallons. I think the light goes on when you've expended 9 gallons, maybe, leaving 1.3 gallons in the tank when the light comes on.
Kinda freaked me out tho!
IIRC, the engine runs more efficiently the colder the outside air is, because the air is more dense and so contains more oxygen per unit volume.
as for the uphill power, i took my Fit up the Canejo grade (also in SoCal, also during this yucky heat-wave) and found that the uphill power and acceleration were great as long as I was already moving at a reasonable clip. Acceleration starting from slower speeds on a steep grade was definitely less impressive. Does this match your experience mtngal?
That might have something to do with the difference between summer and winter gasoline. I really have no idea how that works in the US...but if the entire country gets "winter gasoline" and someone in southern California with a milder winter get the same as Minnesota, it would probably affect mileage to some degree.
In regards to mtngal's Fit's performance in this humid weather, I have also noticed the car to be a bit more sluggish in certain respects, but not too bad.
Certainly that's possible. One factor no one's mentioned is that warm air is less dense than cold air. So presumably, wind resistance is reduced in summer (read hotter) air.
Sounds crazy until you hear Phil Mickelson describe how he can hit the golf ball significantly further when its hot out.
From my test drives in the AT Fit the transmission really lets the engine rev. From my experience with my VTEC Civic on the Highway it makes a 5-8mpg (33-35 to 26-28) difference cruising above or below the VTEC point. Some of that is from just plain going faster.
Having an AT in the Fit makes it hard to “stay off the pipe”.
As for worse gas mileage in the winter,
1. When you start a cold engine the fuel does not vaporize as easily when cold so the computer richens the fuel. It also holds the idle higher. Both use more fuel.
2. All the rest of the oils in you car are thicker when it is cold, wheel bearings, transmission and engine oil. All this makes for more rolling resistance.
-Matt
I guess my Fit can be considered "broken in" - it's well over 10,000 miles now (10400, I think).
Yeah, I still love my Fit for all kinds of reasons, but I expected better than 27 mpg. How long before the engine is "broken in?" Service guy at the dealership said his Civic didn't "break in" until it was close to 18K miles. It'll take me year and a half to get better than 27 mpg?????? :confuse:
35.31 mpg.
And my brother-in-law's 2006 Corolla gets 36 mpg.
The 2 cars are very close in weight even though the Corolla seems quite a bit bigger. I knew the Fit's mileage wasn't that great - but I wanted a hatchback.
On our 4th fill-up, I will try driving at the speed limit. That should improve the mileage, but it will also make the cars following me very angry.
10,895.1 miles
302.002 gallons
36.076 mpg
My mileage does seem to be going down during the summer - could be the winds, the fact I'm driving a bit faster, it's been a whole lot hotter and more humid than normal recently (AC on all the time). I'm still not complaining at all - the mileage is in the range we had hoped for. The Wrangler's mileage always went down in the winter (assumed that was because of the change to winter grade fuel), so I'm surprised that the Fit seems to go down in the summer. I suppose it's possible that the smaller, more efficient engine is more prone to atmospheric changes, while the heavy, powerful inefficient in the Wrangler reacts more to the change in fuel.
The mileage is almost all freeway - some Los Angeles slow-n-go, some high speed, most involves some type of large elevation gain or loss.
That '04 Corolla is broken in. Your Fit is probably not yet. Your bro's '06 Corolla? I wouldn't know how many miles are on it.
A lot of Fit owners report that their mileage improves as the car is broken in.
it takes a while to get really cold too.
wondering if there is something wrong with the AC and if that is affecting my MPG.
probably take it to the dealer this week.
