On the other hand, if MPG is the primary concern for you, then go with the Civic Hybrid, Yaris, or Corolla...but you won't get the 21CuFt of trunk space nor the magic seats, which my wife loves for long trips.
http://fueleconomy.gov/feg/FEG2007.pdf
For example, if your odometer is reading 5% high, then when the odometer shows you've driven 300 miles, you've actually only driven 285 miles (5% of 300 = 15 and 300-15=285). So if you were calculating that it took 10 gallons to drive 300 miles, you'd calculate 30mpg, but if in reality you were only driving 285 miles (assuming your odometer was 5% off), then your real MPG would only be 28.5mpg. So it would be even worse.
If you're planning on doing a long highway trip, try keeping the speed under 70mph on cruise for a couple of hundred miles and calculate your mpg based on that to see what you get.
How does this affect the tires? I'm wondering if other drivers on the Forum do the same.
With my current non-Fit, I noticed my mileage dropped from about 32-33 to 28-29. I pumped up the low tire and it was back the next week to 32-33.
However a good thing can be overdone.
The more pressure in the tire, the less tire tread is actually touching the ground and the harder the tire is.
A really over inflated tire will ride on the middle treads of the tire. Therefore, there are less tread to support the weight of the car and they will wear more than the outside treads.
The over inflated tire can/will result in less control of the vehicle in emergency breaking and cornering, because there is less tire patch on the ground to grip the road.
It will also tend to be nosier as well as rougher riding, as it is multiplying the effects of road irregularies.
I like running about 2# over the recommended pressure posted on the door.
For hauling extra passengers, say on a trip, another 2# in the rear tires.
I figure the Hondas of the world want to be able to advertise and actually obtain the best mileage possible while also dealing with safe handling. A good part of that handling comes from the tires and the pressure in them.
Surely Honda did some research on this subject, in order to achieve the best possible combination of safe handling and fuel mileage
Kip
However in reality the car only traveled 95 miles so the real mpg is 23.75 mpg. This is less than believed.
Good news is that a slightly larger tire would "FIX" the error and maybe even look better!
Kip
100% City, stop and go the entire way, 13 mile commute. Probably stop/go 20-30 times a trip?
I was curious about the same thing myself. I don't have a Fit, but my speedometer is fast by 4 miles at 50 mph, and 5 miles at 60-65. The odometer is only slightly optimistic when comparing to highway mile markers over a long stretch.
So, while the speedometer is ~12% fast, the odometer is ~3% over the actual distance.
When I mentioned my non-Fit, my low tire is due to some random leak somewhere. Since I am getting my car soon, I have not wanted to put in any repairs, so I let it slide from the recommended up to 35 psi down to 28 with a less then accurate measurement.
Other people I have spoken with who got just downright awful mileage have found later that there was a nail or other issue with the tire.
If the tire has a problem because it loses pressure fast, best to get the issue taken care of with a tire under warranty perhaps. I am unsure how much air a tire needs to lose before maintenance minder comes on but a friend with a caddy caught that very problem for her.
If nothing else a good, accurate periodic reading is going to go furthest towards better mileage.
I did. The Fit's speedometer is pretty accurate when compared to my TomTom 300.
Kip
I watched the mileage when we got it back from the body shop. I doubt they did anything special to prep the car after all the work, just reconnected the battery and made sure it worked. The first tank was in the 20's, the next one in the low 30's and the next several between 35-39, consistent with what we were getting before the accident. I do think its interesting that the car seemed to adjust to our driving style and conditions - there wasn't any difference between the type of driving we did between the first tank (high 20's) and the last tank (high 30s).
I know next to nothing about cars, but bought my Fit to get good gas mileage. I live in Chittenden county in Vermont and most of my driving is around town. Those few times I have been on the interstate, I rarely go over 65.
Can someone please help me understand what I need to do to get better gas mileage?
thanks!!!
If you owned a car before the Fit and drove it under the same conditions, what what your fuel economy?
Yes - it is quite cold here. This week the high temps are below 20 degrees.
When I drive around town I would guess my average speed is 40 - 50 MPH.
My daily trip is approx 10 miles. The first 2 miles I have 10 short stops. Most of those are at stop signs so my idle time is very short. After that I hit 6 or 8 traffic signals. There my idle time is probably 1 minute (2 minutes tops).
I have a few hills (after all - this is Vermont!), but nothing major.
I am not a jackrabbit driver (fast start - speed - jam on brakes to stop).
My previous car was a 2003 Accord and I got 19-20 MPG with that car. I had really been hoping for better gas mileage with this car.
Is the cold weather hurting things? I park my car in a garage so I don't have to let it warm up much.
Thank you so much for any and all suggestions!!!!
Cold weather such as what you get in Vermont (and I get in Minnesnowta) definitely has a negative impact on fuel economy. Also, I doubt your average speed around town is 40-50 mph with all the stops/starts you have on your 10-mile trip. Keep in mind that every moment you are stopped, your speed--and fuel economy--are zero. Try this: time exactly how long it takes you from the time you start your car to when you turn off the engine at your destination, on a typical day--or average several days' times--and calculate your average speed. For example, if you actually average 50 mph then your 10-mile trip would take only 12 minutes.)
One thing to try is to try to anticipate stops as much as possible, and coast up to the stops (in gear) if practical (i.e. if you won't be blocking anyone). Or maybe you already do that?
Cold flattens them out a bit.
Why in gear?
I guess since the car is still being "broken in" and it's been terribly cold, I should disregard that 23 MPG as indicative of what I should generally expect for mostly short commutes.
I just hope that "breaking in" the car during sub-zero weather isn't degrading its long term performance. I let the car warm up a couple minutes first, but I haven't been waiting for the green "cold" indicator light to go away.
You probably would not get a good mileage with such a short commute even if the temperature were 70 degrees, but certainly the low winter temp does make it worse. Your Fit's engine is almost certainly running richer in gas all the way to the end of your commute, without having a chance to get back to the normal fuel/air mix. And warming up for a few minutes beforehand would not help, either, because the gas lost in the process, earning you 0 MPG, could not possibly be made up in such a short commute (well, it could not be made up either way, but at least the MPG damage would be spread thinner if you drove further).
To put it simply, a short commute in a large city in a very cold climate is one of the worst combinations for gas mileage. Given that, I actually think that your Fit's 23 MPG is pretty good. Many other cars would give you a whole lot worse.
Unless you have an auto and then you cant do anything about it.
I feel sure you mean, do not coast to stops in neutral.
I have had similar problems with mileage on my Fit Sport automatic and was wondering if your mileage has improved or if you have run any of the tests that have been suggested. I average 19 MPG and, like you, have been getting worse, not better. Our driving conditions sound very similar. I also have a friend in town with the same car and he is getting 30-37 MPG and we have very similar commutes. Hmmm. I have not reached 5000 miles yet and the dealer says wait until the first oil change. Not sure it will get THAT much better.
Any thoughts, suggestions, information would be appreciated!
I have many cases myself where I coast to a stop in neutral, but as you say in traffic it is not necessarily wise.
Sometimes one must accelerate to avoid problems.
I just wanted to be sure I understood what the other poster was saying.
I mostly only coast to a stop down a local hill when there is noone around but I also know that if a deer jumped in front of me, even though I am a long time driver with good reflexes, it still adds time to my avoidance.
I'm a bit confused about shifting. The speeds recommended in the manual seem to be about 3400 rpm, which feels about right to me. If I approach 2000 rpm in any gear the engine requires more throttle and seems powerless. Wouldn't shifting at 2000 lug the engine?
Thanks for you thoughts,
Kevin
I feel like for lower gears, the 2000-2500 rpms feels about right to me but at higher gears it feels as though I need to wait to shift.
I have no clue what my mileage will be like.
I've maintained pretty good records on gas consumption, and can report that my car is averaging just shy of 31 mpg. Most town mileage is 28-29, and highway use averages about 37 mpg. Most of my miles are suburban commutes of 10 miles or less. I'm not a very conservative driver, but not a racer, either. All in all I think this is pretty good. I know if I adopt a more conservative driving style I could probably squeeze 10% more fuel efficiency, but then it's not as much fun to drive.
Sadly, things have remained the same. I'm averaging about 19 mpg. Based on all the posts I've seen here, it sounds like this is not out of the ordinary for the 100% Chicago city winter driving that I've been doing. I'm concerned though, that you have a friend to compare to and he is getting much better mileage. I hope there is nothing wrong with our cars.
