Mitsubishi Outlander Real World MPG
stever
Guest Posts: 52,454
in Mitsubishi
Please report on your Mitsubishi Outlander mileage here.
Include your odometer reading, city/highway mix, driving style or anything else you think may help others compare their mpg with yours. Thanks!
This is our 3rd Mitsubishi & the best one so far.
29.6 mpg
Tried to keep the tach under 3k most of the trip.
Around town I usually average 23-24mpg in my 03 xls 2wd
Name says it all. It's my real-time MPG ratings for my 07 Outlander. I drive 100%city most of the time, but there is a field that will tell you the city/highway ratio (approx only).WIll get updated for each full tank I make. By the way, you will need a google account to view.
13 gal - 200mi - 15.38mpg - 6.5km/L - 100%City - Still in break in
13.74 gal - 247mi - 18mpg - 7.6km/L - 100%City - went past break-in mileage in this tank of gas.
At 18mpg just after break-in, I'd say it's better than I expected since the EPA ratings are 19/26, and these values are unrealistic in the real world.
1st part - 1 miles - Lots of lights - Posted speed 25. avg spd 17.5; mpg 13.5
2nd part - 4 miles - Less Lights, US 1 South. - Posted speed 45. avg speed 33; mpg 18.0
3rd part - 12 miles - Congested highway, US 1 S & 76 West - Posted speed 55. avg speed 57; mpg 27.8
4th part - 9 miles - highway, 476 S - Posted speed 55. avg speed 68; mpg 24.5
5th part - 9 miles - lights, Rte 3 W - Posted 40/55. avg speed 48; mpg 24.2
We get 18-19 MPG in traffic,stoplight to stoplight metro driving.
On the highway,again-metro,so some slow and go for us,we got 26 this weekend.
I like to drive fast sometimes,but other times I really try to get good mileage. Im a Mitsu diehard,my 91 AWD Eclipse I got 27mpg,I got 28 mpg out of my Evo,and we got 30 MPG from my Wife's Galant GTZ (2000). Im saying that because those are all above the ratings for those vehicles. I think I'll be able to get 32 from this Outlander given a good long highway drive.
That was a great model - wonderful on mountain roads! I had the Eagle Talon version and got about the same mileage.
With over 5000 miles (i.e. broken in)
Hwy 25.2 MPG.. Around town 19.8. I have the XLS 4WD.
I was using Sunoco gas because the station was close to my home. I notice a drop of 2-3 miles per gallon. I went back to Get-Go which is a local chain here in Pittsburgh and the MPG went right back up. Sunoco is the worse abuser of ethanol they use the max allowed. Sorry I can't give you much more detail about the mix, i use the lowest grade.
I have a mixed drive in the AM which is early, no traffic and fairly flat but still some hills. If I use the Get-Go gas (89 grade) I can get 27.5 MPG driving at around 60 MPH for the most part. If I use Sunoco I'm lucky if I can get 24 MPG. Also I run 2 wheel drive only I tried all-wheel just to see if it would change and I lost about 1 to 1.5 MPG, which should be expected. I bought the XLS but I really wish I would have gotten it loaded, I like this suv alot, if I knew that I was going to like it this much I would have loaded it up with the sound, leather and nav.
But it also depends on how heavy your right foot is - mine is bit heavier.
"Crawled" is the key word here. What do you expect? 400 was bad today too with all the snow on the road.
Hopefully it'll go up as more mileage is put on the truck. Currently it has 2750.
How many miles do you go on a full tank of fuel?
What's it get when you do highway-only trips?
LOL, I live near downtown Chicago...I don't know what a "highway-only" trip is. Unless you count sitting on the expressway for 45min averaging 5mph.
Once I take a highway trip, I'll post my results
It supposedly is based on Lancer platform. But it must be heavy... Not too thrilled about mpg. Gotta move closer to work or find work closer to me.
This is not correct. In 4WD Auto mode, up to 40% of the torque goes to the rear. On dry pavement, up to 15% goes to the rear, REGARDLESS of slippage. Under certain circumstances, like hard acceleration, more torque is sent to the rear.
4WD Lock sends 50% more torque to the rear compared to 4WD Auto, which means up to 60% could be sent to the rear.
2WD is plain FWD.
See link below which explains exactly, by Mitsubishi, how the 4WD in the 2007 Outlander works.
2007 Outlander 4WD System Explained
The 4WD versions have a smaller tank than the 2WD, so total mileage out of a tank gets a little tricky to compare.
Interesting that the fuel warning starts blinking faster as you get closer to empty.
You compare MPG which does not depend on the tank size.
The way to calculate the "Real World" MPG would be to divide the miles driven over the numbers of gallons used. You fill up the tank, reset the trip computer and drive. At the next fill up, check how many miles you drove. Very simple.
In your case, you drove 300 miles on 14.8 gallons so you got 20.27 MPG.
That's per "session". When you turn on your car for your first trip of the day, it will do the math for that "session" of use. When you turn off the ignition, it will remember those mileage math for that session and hold it for 4 hours in its computer since the vehicle was last turned off. After 4 hours (or more) have lapsed, and you start using the vehicle again, it will count that as a new session and redo all mileage math.
So far I'm happy with the mileage - low 12' L/100km and it's still new and cold weather. I'm sure it will improve within a year or so.
17.4 MPG
Mostly city driving.
