"If you drove 250 miles/day and recharged 500 times, then you would have driven 125,000 miles! We expect the performance of the battery to decline at that point, but it will still be a gradual drop in performance. If you rephrase the question, think of how much gas you would save if you drove your electric Roadster for 125,000 miles!"
http://www.teslamotors.com/learn_more/faqs.php?PHPSESSID=486e9c7df4d4a8f1509456d- - fe1582420
Startup companies are notoriously optimistic. We'll have to see how this plays out. At 15k miles driven a year, it looks like they expect 6 years or so battery life. Then a "slow" decline. not too shabby.
people do upgrade as one of the posters, above, mentioned
easier to upgrade a pc than a car
still, it's probably not a significant part of the market
just as people upgrade brakes, suspension components, and the like
That's probably true but the owner/founder of Tesla Motors seems to be a little more conservative in his estimates. There is someplace on their website where he is quoted as saying that with his driving style he only expects to get 200 miles per charge. Also they are telling customers that even though the battery pack is rated for 500 charges (125k miles) they anticipate a 100k mile life expectancy. The part about Li-ion batteries that is difficult to predict is how they will age. I'm sure they have done tests where they rapidly charge and discharge these batteries but Li-ion chemistry has a property where it loses storage capacity purely as a function of time. That is probably harder to evaluate without real world data.
I don't know, it depends on how you define significant. There are a lot of online vendors like Atomic Park, Newegg, The Nerds, etc., that do a good business selling computer upgrade/replacement components, including CPUs and Motherboards. For $150 you can get a CPU/Motherboard combination that will blow away what is available on a $300 bargain basement PC. And it really isn't all that hard to replace. The major computer manufacturers design their cases with this in mind. Dell's cases slide open without even the need for a screwdriver. MidnightCowboy says he is an IT professional but I suspect he is in charge of his office's BizHub. You know, the email machine.
You pull in the driveway and you plug it in. That's at least 300 charges/year, which means a battery life of less than two years.
but I may have read that topping-off improves battery life.
Not sure if any of you have read about the potential for signing contracts with utilities where you would buy cheaper power at night in exchange for you driving to your workplace, plugging in, and then letting the local utility suck off your battery to help even out local electiricy needs. Interesting stuff. Just another way that we might avoid building a bunch of new power plants.
Not sure it is a good thing, but it is interesting.
alp8 is correct.
perhaps more people upgrade than i know. I was likening the CPU to the battery in an EV. Do many upgrade CPUs anymore? I don't honestly know. The people I know simply get a new puter when the time comes, but my experience may vary greatly from the norm. I'll leave dungeons and dragons or grand theft auto to the boys in the basement.
OTOH, battery life in a car is not infinite. Since you must replace it anyway or scrap the whole car, my original question was regarding if newer technology can simply be plugged in without too much infrastructure work.
and that is a good question
THAT could be a significant problem depending on how long we are talking about.
Just someone's luck; they pull in at the office and plug the vehicle in and find that by the time they're ready to go home, there isn't enough charge left to get home, lol. But of course, if the user has a way of dialing in how much electricity they would be able to part with, I guess this would be workable.
That is a common misnomer, actually on typical NI-CAD (Nickel Cadmium) batteries recharging on a partial charge is more detimental and significantly reduces the number of total recharge cycles. it also cause retained memeory and reduces the effective amp-hour capacity.
It is sometimes claimed that NiCd batteries suffer from a so-called "memory effect" if they are recharged before they have been fully discharged. The apparent symptom is that the battery "remembers" the point in its charge cycle where recharging began and during subsequent use suffers a sudden drop in voltage at that point, as if the battery had been discharged. The capacity of the battery is not actually reduced substantially. Some electronics designed to be powered by NiCds are able to withstand this reduced voltage long enough for the voltage to return to normal. However, if the device is unable to operate through this period of decreased voltage, the device will be unable to get as much energy out of the battery, and for all practical purposes, the battery has a reduced capacity.
There is controversy about whether the memory effect actually exists, or whether it is as serious a problem as is sometimes believed. Some critics claim it is used to promote competing NiMH batteries, which apparently suffer this effect to a lesser extent. Many nickel-cadmium battery manufacturers either deny this effect exists or are silent on the matter.
An effect with similar symptoms to the memory effect is the so-called "lazy battery effect". (Note, however, that some people use this term as a synonym for "memory effect"). This effect is the result of repeated overcharging; the symptom is that the battery appears to be fully charged but discharges quickly after only a brief period of operation. Sometimes, much of the lost capacity can be recovered by a few deep discharge cycles, a function often provided by automatic NiCd battery chargers. If treated well, NiCd batteries can last for 1000 cycles, or more, before capacity drops below 50% of what it was originally.
NiCd batteries, when not used regularly, tend to develop dendrites (thin, conductive crystals), causing internal short circuits and premature battery failure, long before the 800-1000 charge/discharge cycles claimed by most vendors. Sometimes, these dendrites can be cleared by applying a brief, high-current charging pulse to individual cells, but once dendrites have begun to form, they will typically recur soon thereafter.
Biz-Hub operator LOL thats a good one! Then I guess I am way, way overpaid.
Wait intil February to replace your PC becuase the Vista software will be the standard OS then. Yes back in 286, 386, 486 days it was cheaper to upgrade. Nowadays, if you will check , most PC upgrade shops have gone out of business. It is just easier and more cost effective to replace with brand new equipment. No from a business perspective we don't buy the bottom of the line desktops, laptops and workstations. But when you buy in volume you can get a Dell Lattitude D610 for about half of retail price.
Getting back to the Telsa. After the first generation comes out there will be a second and ... other generations. More than likely the infrastructure, wiring harness, microprocessors, sensors, programming, mechanical engine components , even the electic motors will change in total and it will be fairly expensive to upgrade from gen 1 to gen 2. But hey I'm just a Biz-Hub operator what would I know ?
Cheers,
MidCow
You are clearly talking about NI-CD batteries, which are not used in any electric cars I know about.
The memory efect of which you speak is a NI-CD phenomenon only.
The Tesla, and other new electric cars, use LI-ION batteries.
From the FAQ at Tesla Motors:
Li-Ion batteries are good for 500 complete charge/discharge cycles. One cycle consists of discharging the pack from 100% state of charge (SOC) to 0% SOC. Realistically, drivers will not completely discharge their pack. More likely, drivers will drive the car for 50 or 100 miles then plug it back in to charge it up to 100% SOC. Driving only 50 miles is only a partial discharge, roughly using 20% of the charge. If a driver continues to drive 50 miles every day and recharges every night, then after 5 days they would complete the equivalent of one charge/discharge cycle.
In any event, the battery pack is guaranteed for 100,000 miles, so you can take it up with Tesla if they don't make it that far.
Hey, did you ever figure out how to get coffee on the BizHub?
Not to mention the Cadmium in NiCd batteris is considered a hazardous waste product. Li-ion batteries are not. I don't think we will be seeing NiCd batteries in any future EVs.
Interesting note about the Lithium-Ion still too expensive for hybrids, but maybe not for $100K electric car. Smaller more power, but still the same heat recall the recent Sony battery fire problem? The solution chilled water and a radiator to cool the Lithium Ion heat discharge.
My BizHub has one of those coffee holders. You just push the CD button.
Now the big question: If don't tell you about something/everything does that mean I am not familiar with it? LOL, you probably assume impedance always equals resistance because you assume the amperage and the voltage are in phase.
Cheers,
MidCow
1,100 pounds of them. :sick:
1. The batteries will need to be greatly improved in the speed of recharge. This will be needed as a way to spur the development of a fast recharge infrastructure in order to allow us to use the vehicle for more than just a commuter.
2. The batteries used will need to be greatly improved in the number of times they can be recharged. I believe this is necessary so that the cost of the batteries doesn't become part of the 'cost of ownership'. If I have to pay 30k for batteries, but I'm able to recover 80% of that cost when I sell the vehicle (since the batteries don't have to be replaced) then I've greatly reduced the total cost of ownership. I hope that the replacement battery pack for the Tesla will be of this type instead of the current version.
3. For those of us that can't afford two vehicles, we will most likely focus on a vehicle that can satisfy 99% of our driving needs. Until a fast recharge infrastructure is in place or a vehicles range is greatly increased, an EV will not satisfy most peoples needs as their only vehicle. More power to those that can afford this particular vehicle though and for families that can afford multiple vehicles so that they, at least, will be able to consider a 2nd vehicle that serves primarily as a commuter!
I've read several of your posts and I think that I have a good idea of where you're coming from. With that said I think you will agree with me on the point I'm about to make. The Tesla Roadster has a 1,000 lb battery pack that will provide it with 250 mile range per charge. This battery pack probably costs $40-50k. There are now new battery technologies that have a far higher power density. With these new batteries a 200 lb battery pack could provide all the power needed to achieve the same Tesla Roadster performance. So why not go with this 200 lb battery pack and a 200 lb efficient diesel generator? You save 600 lbs and a lot of money. The 200 lb battery pack would provide 40-50 miles of all electric driving. This accounts for the vast majority of all driving done by Americans. Occasionally this generator would have to kick in and you would be burning fuel. Oh well. I read a nice quote along these lines from the President of UC Davis. He said that good is not the enemy of perfect.
Perfect quote! :P
More power to those that can (and do) accept an electric only solution!
If using an ICE to charge a battery to run an electric motor is somehow more efficient than driving the wheels with an ICE, why hasn't someone just used this as the primary system long ago? That is, regardless of the size of the battery, the power from the ICE/generator could be used to drive the motor?
I tend to think that this
ICE-->generator-->battery-->motor, chain can't lead to a gain in efficiency. I guess aside from the simplified trans, what else do you get?
Can you really get by with a smaller engine if you want a serial to be able to run completely on gas when needed?
Seems to defy my rudimentary knowledge of physics.
Engineers out there?
On edit: Ok, I just thought of one advantage. The battery can be charged while the car is stopped in idle.
I used to feel the same way and maybe you are correct. The gain might come from the fact that when the engine kicked in to re-charge the batteries it would always run at its peak efficiency in terms of power generation per fuel usage. And once the battery was adequately re-charged the engine would shut down. This is not the case when the engine is driving the wheels and is operating throughout a wide range of power outputs that don't represent optimum conversion efficiency.
While using this IC generator won't be as efficient as charging the batteries from the grid in day to day use this type of vehicle could be more efficient than a pure BEV. The reason being is that it could be significantly lighter. Replace the Tesla Roadster's 1,000 lb battery pack with a 300 lb battery pack and a 200 lb generator and you'll save 500 lbs of weight. For trips less than ~70 miles you will still be able to run as a pure BEV but will have saved energy by carrying around less weight. So it becomes somewhat of a trade-off that will vary by individual. If you are someone that rarely drives over 70 miles then you will actually save more energy by going this series hybrid route. If you take a lot of longer trips than the large battery pack would provide the greatest energy savings.
You've done what seems to be an excellent summary of why this type of serial hybrid will probably be with us until such time as we have much better battery technology (e.g., less weight, better recharge, cheaper, more capacity) and a more comprehensive recharging infrastructure for extended road travel. This type of vehicle will allow most of us to drive in electric only mode for limited range commutes, but still allow us to have the freedom to take longer trips as needed without having to resort to having multiple cars or renting one.
While I know that there are a lot of families that already have multiple cars, there are also a lot of people that are single with only one car or where the driving needs are so disparate between couples that sharing is not a comfortable option. Has anyone ever gone to a rental agency and been given a choice of vehicles to rent, where there was nothing available that they would have picked if given a choice? Has anyone ever said to their significant other, 'just pick out what you want since it's really going to be "YOUR" car'? For those that don't fall into these groups, great, for others, I'm sure you'll want what you want and will want it with as little compromise as possible.
By any chance would you happen to be single? :P
I emailed Tesla as to what they anticipate the replacement cost of a battery to be. No reply so far.
You know what I think the biggest possible killer to EV/HEV vehicles is? Liability. Suppose we go for awhile and people get the idea that there are health risks to being around that much EMF. Think of what happened with cell phones and breast implants. Doesn't even have to be valid. The sharks will circle.
I don't know what their cost structure is, perhaps they lose money on every roadster made. But to do these small production runs using a purchased Lotus chassis and pretty much customizing the rest, has to be pretty expensive...if you are arriving at it by trying to back out costs from a total. I may ask Tesla again and this time be a "potential customer."
MSRP on a Viper is $85k and up.
I'd take the Tesla over the Viper in a heartbeat.
Probably pretty safe to say that the pack costs at least $25k+...taking into consideration the quantity purchased.
http://www.edmunds.com/insideline/do/News/articleId=119384
Rocky
... So you are going on a trip in excess of 125 miles, well here is one thing the computers are not doing yet. At the start of this trip you run both batt and genset power, after two hours the genset should have added 40 to 50 percent charge. This should be near 200 mile range.
... This would also save quite a bit of time looking for a charging location any time you were stoped on these rare trips. Yes, it has it's limitations. What is that old saying about making all the people happy all of the time or that pursuit there of.
... Allright, you left the vehicle in long term parking for three days with the lights on and when you open the door your not quite sure if that's a reflection or the domelight is on, but the genset does crank; however this (with some sophisticated switching to not charge the batts at this time) will only run the car 15 MPH, but it gets you accross the street to a restaurant where you leave the genset run for an hour or more and viola 20 to 25 percent charge, might get you home if you live 30 or less miles away.
Even the 50 mpg in gas mode would be a quarter to a half less fuel used for most.
Not saying anything new here. I want to see these cars of various modes on the road and competing. Can't wait.
I don't think the wait will be that long. Within a couple of years we should also have a lot more high mpg diesels to choose from and maybe even some diesel hybrids. So something for everyone. And when the government suggest higher CAFE the auto-manufacturers can respond, "hey, the vehicles are out there, now make people want them".
By the time the car is ready for production, I feel confident that the price would also be at a reasonable point, perhaps even to allowing options for increased EV only range to keep price down for short range commuters but allow longer EV commute for others as they wish.
In summary, I see no reason for GM to express any doubts about the possibility of the vehicle being made production ready and available sooner rather than later.
... Any engineers out there have an idea of what would happen to the four second, zero to sixty, with half the peak load, taken away in batt size? Keep in mind that the car might be two to three hundred pounds lighter even with the little genset. Oh yeah, would have ten to fifteen thousand dollars to put a genset in the vehicle.
I'm by no means an expert on this but here's a couple things I do know. The Tesla has a 185 kW motor and a battery pack that is around 450 kg. Cut this in half and you have a 225 kg battery pack. Given that standard Li-ion batteries have a power density of around 1 kW per kg I think that the performance wouldn't suffer. There are newer battery technologies from companies like A123 Systems and Altairnano that supposedly have a big advantage when it comes to power density. They claim their batteries produce 3-4 kW per kg. So potentially a relatively small battery pack, say 100 kg, could supply a very powerful electric motor producing incredible performance, albeit with limited electric range. If I were rich I'd love to build a car with a 100 kW motor powering the front wheels and a 150 kW motor powering the rear. I'd install one of these new technology 100 kg battery packs and a 1 Liter diesel generator to keep it charged. Granted the generator would be running almost non-stop, which wouldn't make it much of an EV but it would have performance that probably exceeded that of a Viper while getting at least 30 mpg.
Also reporting that the price will be "at least $50k." How many green mercedes drivers are there who will accept the limitations? They say they want to build 10,000 units a year.
All good I guess.
http://www.detnews.com/apps/pbcs.dll/article?AID=/20070220/UPDATE/702200428
Other questions would be, are there any owners of $50k vehicles that never drive over 250 miles? How many people that can afford a $50k vehicle have more than one car? If there are those that fit into these categories then there are really no relevant limitations. And if this would be your only vehicle and you rarely make the 250+ mile trip there is always the option of renting on those occasions. And any limitations also need to be weighed against the convenience of foregoing the 30+ annual trips the average motorist makes to a filling station. What about the situation where you didn't plan on driving 250 miles but ended up needing to? Well I've been driving over 30 years and that's never come up. What about people that don't have access to an outlet for re-charging? Remember this is still a $50k vehicle. Not exactly aimed at the apartment dweller.
So, IMO, a 250 range will be a non-factor for enough people that this car will still have a market. No it won't have the mass appeal of Camrys and Accords that sell 400k units but since they only plan on making 10k a year the fact that its appeal will be limited is also a non-factor. But to even sell that many this $50k EV will still have to offer comparable performance, comfort, and amenities to the other $50k vehicles that buyers have to choose from.
I am just guessing at the mindset of the average buyer in that categary, but I don't think they are much concerned with saving gas or the planet. Any drawback such as a range limitation could well be a deal breaker, whether it comes into play much or not. It's all about convenience, luxury, performance and status. Still, 10k is not all that many units..perhaps there are enough folks with the money and incling to move them. Certainly hollywood has a few elligible buyers. I have little doubt that the Tesla will be tricked out and perform well for its class. Perhaps the unique factor will spur buyers to go with it. The status thing..the I got stuff you don't thing.
I guess at this point, I will be waiting for the Volt.
I agree. I think the Volt is the more logical next step on the way to pure EVs.
For some reason, I see Phoenix doing a lot better in the beginning than Tesla. Whether it be their lower prices, or their awesome batteries that fully recharge in 10 minutes and have 9,000 life cycles. The car goes 130 miles, but they said something about an expansion pack that would allow the cars to go for about 250 miles.
You guys are right, though. The cars, for a while, at least, won't be too affordable to the mass market. There will be some people pushed over the edge by the gasoline prices. The prices will come down once they mass-produce them, though. And then the Volt will come out. I wish they gave us a price estimate for the Volt, though.
Tesla added weight to their car for safety and durability reasons, so now they just say, "Over 200 miles."
So basically your roadtrips will be limited to ~200 miles. Probably not a big deal. If you consider this car to be an electric Dodge Viper then ask yourself, how many 200+ mile roadtrips do people make in Vipers? Probably not many. These types of cars are toys and not meant to be practical and shouldn't be judged from that perspective. But even as a toy the Tesla will be a valuable proof of concept testbed.
