on .. whn I turn the truck off and let it sit for a few all is well again..
i had this problem a year ago and took to the mech. and was told tht i needed a new trans cooler which is located in the radiator [600.00 bucks] including new filter screen oil ect it work o.k for a while but the problem still exist anyone ever have this problem ??
charge me $600 thy said tht the cooler was located in the radiator and the chk was
at the neck and the whole thing had to be replaced i guess it was better than replacing the tranny but at the time it worked but i only drove on the expressway
once or twice a week for apx 30min to an hr but now.... again it wont last 30 mins
without having the od kickout and tranny temp light comming on but it will if i slow down to under 60 mph for a while reset it self and then kickout again apx 5min later
some man looked under hood and said Oh i c its a linkage problem
any suggestions where I shoul start...
Toni
Toni
when at 60 the rpm's read 2750
when in park rpms got to 3200 ( redline is 3000)
fuel mileage dropped form 18 to 8... any suggestions?
Oh I did ask one mechanic he looked under hood ..had me step on fuel and said oh i see it is a linkage problem... ??? but he would not explain it to me and he did not have time to fix.. and he is now 200 miles away.
Thank You for any suggestion
Toni
kcram - Pickups Host
seems like truck is stuck in 2nd gear?
A 12-valve Cummins will never get to 60 mph in 2nd gear... not enough rpm.
Josh
I'm thinking that i need to replace the governor pressure sensor and the solenoid in the tranny. Am i way off base here or is that the right thing to do?
It will start and idle perfectly, however after putting in gear, fwd or rev, and traveling app. 10 ft, truck shuts down. If I juice it and get through the first shutdown, the indications are every 10 ft or so of travel all electrical shuts down (gages, engine) for a split second and it is perfectly timed or rythmic, like snapping your fingers to a song, and that is about how long I lose electric and power, the time it takes to snap a finger. Pulled up code P1762 but have no idea what the code is.
Any ideas?
