Vibration Defect in 2006 4WD Honda Pilots
I have a 2006 Pilot with a vibration defect at 70MPH. This is not steering wheel shake, rather, a very noticable shudder.
Apparently this issue is well know with Pilot 4WD owners. Tire changes/balancing does not help. Neither do other "simple" fixes like alignment.
Does anyone have an answer to this product defect ? If everyone has tried and failed, is the only answer to raise heck with American Honda ? Or ???
Thanks !
Thanks !
One person has "solved" the problem by removing the front drive shaft. I find that an inexcusable solution for a vehicle owner.
If I find anything out I will post. Let me know how it goes.
thanks !
Odie
Odie's Carspace
I said this in a 2004 forum and was ridiculed. I saw the problem surface again 2 months ago and got no "heat" at all. I will say it again. My service manager was honest with me! ALL pilots vibrate. The source is the drive shaft to the rear differential. It can not be fixed. Honda feels most people who buy their cars won't don't notice. Drove me crazy! By removing the shaft (8 bolts) the problem is GONE. I'M in Chicago, so this week the shaft goes back on for the winter. It sucks but I got nowhere with honda. :sick:
HONDA KNOWS ABOUT THIS but is playing dum because they either don't know what causes the problem, OR they don't want to issue such a big recall.
I have written a letter to American Honda headquarters, and Honda Motor Company headquarters in Japan. They responded trying to cover up the problem and saying it is "a characteristic" of the vehicle! I recently got rid of my Pilot because I could no longer deal with this flaw; very unexecptebale for a $29,000 vehicle.
Don't take the risk in purchasing this vehicle; you may want to consider the upcoming redesigned Highlander, or you can wait for the new redesigned Pilot.
Otherwise, the Pilot is an EXCELLENT vehicle.
Odie
Odie's Carspace
I guess I will have to take some more test drives.
Odie
Odie's Carspace
I dumped the Integritys for Michelins. The problem persists. If you review other sections of Edmunds boards you will see that others have had no success with changing tires. Some appear to have slightly lessened the problem with very, very precise balancing, however, most have not. And... then there is the individual who has removed the front drive shaft on a 4WD to "solve" the problem.
Glad you have had success. However, Honda has a major defect and, to date, has not come forward with a solution.
Other than that, and the fact that my cell phone makes the stereo act wacky, I really like the vehicle.
Has anyone experienced this with their Pilot?
If your vehicle has "the disease" it will appear to have significant wind buffeting. The steering wheel doesn't shake, rather, it feels/sounds like... well.... wind buffeting. If you have the stereo turned up you will notice it less, therefore, always demo drive with the radio off.
This problem has been reported on multiple Honda 4WD models, including Acura's. It is not simply a "tire balance issue", although that may lessen it to some degree. One person reported that the problem went away when they removed a drive shaft. Tires still rotate but the problem was gone.
If you have a vehicle without the disease and at a good price, enjoy.
The problem is real, just not universally applied to every vehicle. And, apparently, Honda denies it.
I have read similar comments elsewhere about low frequency sound at slow speed. In some cases it was indicated that it may have to do with the Active Noise Cancellation system that is found on the Pilots with VCM. You might want to check the hondapilot.org site under "forums", "problems", then "deep thrumming sound". There is also an extensive section there regarding the vibration issue.
Vibration: An apparently serious vibration that is most prominent around 70 MPH. This seems to affect a significant number of AWD Pilots going back at least to the 2005 model year. There are many comments, complaints and theories but the common thread seems to be that, for the people who have this problem, Honda has been unable to fix it.
Noise: There are many complaints about road noise, as well as a more recent surge in complaints about a strange low pitched noise on new Pilots with VCM. It appears that Honda is utilizing some sort of active noise cancellation which comes through the speakers of the stereo. Unfortunately, it looks like that may have created some problems of it's own.
- 70MPH vibration/shudder design defect, ignored or at
least not acknowledged by Honda. They probably don't
want a national recall, including the expense and
publicity.
- Road noise, makes having a radio totally useless.
- Low pitched noise from ???? source.
I have had the tires road forced balanced and it helped "a little" but ONLY a little.
It's still there at 60-70. It's a very fast type of vibration.
If only I had felt it before I bought it. I assure you that I would NOT have bought the Pilot !
It's horrible and extremely distracting... so much so that I feel it's dangerous.
I drive my brand new Pilot very little now because of it and drive my Sebring instead.
How's THAT for a testimonial !
Tim
the noise is minimal. If you drive on anything OTHER than
very smooth asphalt (rough asphalt, concrete of any sort,
etc.) it is very noisy. Same speed. Same air. Honda
has a serious issue with road isolation, specifically,
picking up the noise through the suspension to the passenger
interior. And... doesn't matter whether it is the original
Integrity tires or new Michelin's.
Most people don't take a test drive for any extended time
on a freeway. If they did, Honda sales would suffer.
As far as the vibration, I've experienced it on a few Pilots, and road noise is a given on most Hondas.
I'm hoping these issues get addressed for the 2008 model, but I'm not very optimistic considering they haven't been yet.
Also, any thoughts on what to tell the dealer to fix the window noise - rattling kind of "styrofoam" noise. Repair attempts on this is four times as well.
I filed suit against Honda for our '06 Odyssey this past week. My attorney tried mediation with Honda's pre-litigation department but they concluded my problem was a "normal operating characteristic of the vehicle".
My documentation is a clear cut Lemon case win, however, it may take up to 9 months until award. If you have the willpower and good documentation (i.e. parts failing each time or written acknowledgement of the problem) then file a claim.
And... Honda has yet to admit the problem, much less fix it. The only group that sees the problem is the customer base. You may consider what that means.
Oh, by the way, test drive your Honda on a concrete highway and check the road noise. b-a-d
You are correct about the noise on a concrete highway. I cant even carry on a conversation without shouting. But I can tolerate the noise better than I can the Vibration in the front end. I have tried pretty much everything. It aint the tires and since it seems to be more prevalent in the AWD I can only assume it has something to do with the driveshaft to the rear tires?
Anyway, your advice is good for anyone looking at Pilots, be sure and test drive the car good at Highway speeds for both vibration and noise.
Regarding the wind noise, I think this is a common feature to many Hondas. The price advantage versus Toyotas has to come from somewhere and I feel that the luxurious-like noise isolation in higher-priced cars is always missing in Hondas. It is unfortunate but quite frankly, not enough to keep most people from buying the great bargain that is the Honda Pilot.
As an FYI, the noise issue is "road noise" verses "wind noise". It is picked up via the tires through the suspension and body. That is why traveling at 70 on concrete is very, very noisy and on asphalt is tolerable.
I suppose those who really like their radio/CD's must be pondering why they bought this vehicle.
Consumer Reports just came out with their auto issue. Global reviews of Honda noted one consistent negative: road noise.
I had the original tires balanced several times and the problem was not solved. I just put new tires on the car and the problem still has not gone away.
I've recently been told (not by Honda) that the rims might be the problem. The rims are not the conventional style rim where they can put the weights on the outer part of the rim. They have to use the adhesive backed weights and I'm told these reims are very troublesome to balance.
The researh continues....
http://www.hondapilot.org/forums/showthread.php?s=&threadid=14481&perpage=15&pag- - enumber=1
It is about a pair of braces for rear subframe that are on Accura MDX but not on Pilot. Apparently, they can be retro-fitted.
Several people tried and claimed they did improve ride and the "70 mph vibration" problem.
Reading through the thread it is unclear as to what the writers believed they "fixed". The 70mph vibration appears, from most earlier posts, to be more a "front end" thing than a "rear end" thing. One poster eliminated the front drive shaft, I believe, and eliminated the problem.
The posters on the noted thread are focused on the read end and seem have found more value in improved handling, body sway and side wind buffeting. However, after 10 pages of resplies, I have yet to see/hear/read from anyone that adding braces actually fixed the vibration defect.
I really wish it did. If it did, I would install the braces, front and rear, immediately.
If anyone has a thread/message that indicates that installing these braces actually FIXES the vibration defect (or lessens it to a significant degree) PLEASE post it as there are many people, including myself, that would take action at that point.
Thanks for the post !!
I myself just bought a '07 EX-L AWD, and I have not noticed the vibration problem yet. I also have not noticed posts regarding vibration problem for '07 Pilot (maybe there are there, I just haven't read it). This of course may be because there are not that many '07 out there. (Assuming they sell the same number of cars each year, only half are sold so far. Besides, it took some times for people to notice the problem and wonder onto the forums, so the percentage would be even smaller).
While the improved handling, sway and wind buffeting are interesting, my focus continues to be the vibration defect. If anything else benefits, fine, but that's not my objective.
Parts will be here in 2-3 weeks and then I will install and report on the results.
Enjoy,
a. Ordered the Code 50360 Retrofit Kit from HondaAcuraWorld.com. $50.95 delivered, took about 9 days.
b. The installation took about 22 minutes, total. The process is:
a. Remove the chassis bolt, replace with new bolt and tighten
b. Place brace on chassis bolt, hand tighten nut.
c. Install bolt on the other end of the brace (to frame).
d. Tighten bolt and nut. Verify everything is tight to spec.
e. Repeat on other side.
See the link on this forum to another forum that has pictures. E-a-s-y.
That's it. Really. Even the "hard side" is very easy, no real interference problems unless you have a hot muffler.
Road test:
I will ignore subjective commentary on "handling" as it is... subjective... and not my intent. I wanted the 70mph shudder gone.
I drove on smooth asphalt, no radio, no air conditioning, nothing to mask over the situation. I had to HUNT to find the vibration. HUNT !!! It's 95-97% gone, maybe more. If I didn't know EXACTLY where to look I would not have found it at all. Even at that, it was virtually g-o-n-e. It appears that dumping the cheap factory tires (contributed maybe 15% to the fix) and putting on the braces did it.
WARNING; YMMV Your Mileage May Vary
This fix worked on my vehicle. It MAY work on yours. No guarantee, no warranties, do at your own discretion. If you do it, you do it alone and you are responsible for anything and everything. There... my butt is covered.
Nevertheless, these braces have significantly improved my vehicle. It was absolutely worth the $50.95 spent. The install is EASY !! You need a 3/8" ratchet, about a 9 inch extension, a 17mm deepwell socket (11/16 may work... don't know). And plan for a half hour of time.
A hearty THANK YOU to those on this forum and the linked-to forum with details and photos of the kit.
Perhaps I should send the $50.95 bill to Honda...
Victory at last, regardless of the inattention of Honda.
I wish you all a very pleasant day.
This is one of those times when, it appears, the fix was simple (once found), the parts ordering was simple, the parts actually fit, the install was simple AND it worked. For me. As noted, YMMV.
that it might help.
Go to hondapilot.org and review their forums closely with an eye to body integrity. Might be a fix... this is a link to the page/thread...
We'll be going on a long trip in late June, and that will be the measure.
