#1. if you don't have the problem, consider yourself lucky.
#2. the problem isn't at 85mph.
#3. slow down.
<<<<<<I purchased an 06 as well in April of this year and we are experiencing a type of "resonate frequency" in our Pilot. Mainly at very low speeds or when we are stopped and this is very strange. It sounds like a very deep BASS from the Stereo system, although I do not believe it is coming from the speakers. But it elevates slowly and is almost deafening. Here are a few things I have noticed. If I open any door to the vehicle, the noise subsides. Once I close the door again, the noise starts back. My wife stayed inside the Pilot one time when we were parked at a stop sign. I wanted to hear the sound from outside of the vehicle as I thought it may be coming from the engine. Guess What? I could not hear anything outside the car and my wife would Nod her head from inside the vehicle that the inside of the car had the deep vibration (Stereo Bass Like) noise inside. We also told the dealership about it, but could not reproduce it at the time. It is very annoying and happens at least every 2 - 3 days. If I hear it now, I usually just open the door until I start moving again and it goes away.
Has anyone experienced this with their Pilot? >>>>>>
Anyone had any problems with the FWD?
I would like to get the FWD for the cyl deactv as well as no vibration issue.
Having put on a significant amount of miles with the brackets I would call the fix a 97% solution (in my opinion). It may not be absolutely perfect but it is significantly better and worth every bit of the $50.
Hope all goes well
I am/was planning to buy one but am holding back because of this issue.
I test drove a couple and didnt notice any marked vibrations but that was before I read this thread.
If all it takes it parts worth $50.00 to fix this(as reported in different posts) then I wonder whether Honda has taken care of it this year.
You have to test drive yourself and make up your mind. I am sure people are going to jump in and bite my head off for saying this. But remember, some people get picky about little things and the only way to satisfy them is to build a custom build car exactly to their specifications.
Test driving a vehicle does not preclude the possibility that the car or the one you actually buy has problems. Also, the fact that your car does not exhibit a particular problem does not mean other cars do not have that problem. I think it's bit presumptuous to suggest that those desribing a problem they are experiencing is merely excessive pickiness. People generally do not go out of their way to find solutions to nonexistent problems - at least not outside the world of politics!
SUVs and Smart Shopper
http://www.hondapilot.org/forums/showthread.php?s=be8ea97d53fdde85e641c472b0996d9a&threadid=4117&highlight=vibration
A honda rep told me this himself
Whatever the cause honda should issue a recall or at least a TSB to replace the tires
Interestingly found repeated 'vibration' in only one vehicle.It did occur at 70mph.I hope I am NOT imagining this.
Actually that vehicle matched my ext/int color preference(only one on the lot)and deal was nearly on phone however I declined based on above experience after test drive.
Have now made a deal on another Pilot after a long and satisfying test drive.
Hope that future will be vibration free.
Sales person seemed to acknowledge that vibration can be a problem but.....
Do you really think that if this was such a big deal as people make it out to be, a company like Honda would completely ignor e it if a 50 dollar part fixed it???
You and I are entitled to our opinions, but the way I look at it, something don't add up with this vibration defect thing.
I have no idea whether Honda is "completely ignoring" anything and doubt that they would. I do know that people have expressed concerns about a particular problem and just because you haven't experienced it is insufficient reason to conclude that a problem does not exist. Surely, if Honda receives enough complaints they will remedy the situation.
I have never owned a Honda and plan on getting quotes over iternet first. Should I tell them that the price is contingent on the freeway test drive ? Do Honda dealers give you a car for a day before actually buying ??
65-75 does seem to magnify the symptoms as though the whole truck has a resonance at the speed, but the vibration could be felt here and there in other speeds. Steering wheel vibrated to lesser degree compared to lower back and thighs could feel unless tire pressure is way too high
If it becomes an irritant, spend the $50 and 35 minutes. No guarantees but it worked on mine.
I've not experienced the shimmy/vibration issue, but I did order the part and install it, and found that it did help keep the rear a bit stiffer. For $45, it was well worth it.
http://www.hondapilot.org/forums/showthread.php?s=&threadid=14481&perpage=15&pag- enumber=1
My question is, will the vibration problem which has plagued this SUV (and its owners) be evident right away, at all times or is it something cn mask for a short amount of time (like enough time to make a sale)?
I was sure I had found the perfect minivan alternative...now I am questioning my decision.
Odie
Odie's Carspace
Hope that helps!
I just got a 2014 2WD Honda Pilot and detected the vibration shortly after getting on the freeway. The vibration occurs between 75-95 mph. Went to the dealer, they said one tire was out of balance. However, while slightly better, the vibration is still there. I also hear the low pitch noise, which I believe it comes from the overdrive.
It's possible that one (or more) of the tires are "out of round". I put that phrase in quotes because it's a bit more complicated than that.
But it's also possible it is something else.
So do you feel the vibration through the steering wheel or through the seat? Rotate the tires front to rear and see if you get a change. That will help determine if the problem is in the tires (or wheels) or somewhere else.
I have a 2009 4WD. I had the same vibration problem 2 years ago. After getting new tires and alignment (from Firestone), the problem went away. Last week I took the car into local dealer for 60k service, and the vibration comes back when I go up to 70MPH. I called the service tech and he said Honda doesn't recommend alignment on my car. He asks me to bring it back it but with work, I don't have to time. If it won't cause any other issues, I'd just have to live with it. This is the first time I own a car for longer than 3 years, and I've been very happy with the car except for this issue.
I purchased a certified used 2011 touring Pilot with 23k miles on it and it had Michelin tires on it. I was getting the car maintained prior to a trip to NH, 2 tires were bad, had Firestone tires put on, didn't really feel any issues, then I started to notice the vibration at 70mph. Took to local Honda dealer, 2 front bushings were leaking and replaced under warranty, still no help. after several alignments, wheel balancing, new rotors, pads in the front, I had Firestone upgrade the tires to Bridgestones, no help..... 70mph, vibration happens, feels like the balancing is out, but they do all the same things, road force balance etc. Made a trip to IN took it to a dealership in Fishers IN and the service person had the front end checked out again, nothing wrong, he did suggest going back to the Michelines.... right now , cannot afford to do it, taking car back to Firestone for additional balancing, etc. I hope the previous posts about the stabilizing kits have been used on a Pilot that is close to the same model as mine. Look forward to anyone that has the same issue, and had a fix that worked!
My wife and I recently purchased a 2005 Honda pilot and drove many of them. Every one that I drove that had the vibration I took to a local dealer that had the Hunter Road force system (GSP9700) HOWEVER I made sure they had StraighTrak LFM Integration. Not all shops will have this and this is key. I took two 2004s, one 2006, and a 2005 pilot to my local dealer who has this exact system and viola no matter what tire was on the pilots they fixed it. I do work for them so I got all these for free and I did them all just to see if it was a issue with the car or the balancing tech. Every time this setup fixed the vibration. I will say I tried another local dealer that had this same system and they did not fix it so there is a level of knowledge with techs that has to go with and it may not be all pilots that this fixes but I have not run into one yet. The person I purchased my pilot from works at a dealer that has this setup and we never have had a problem with any vibration. So not all balancing systems are equal and not all techs are equal.
I have sent about a dozen other people with pilots to the dealer now and same result they are lifers at that dealership now. Hope this helps some people on here and here is a link to find a local or nearest dealer who has this technology. Just make sure the dealer has the StraighTrak system listed at the store/dealer.
Hope it helps
