I took my 04 odyssey to my mechanist and he replaced Air Idle Control Valve. I've never had this problem again. Hope this helps you.
Any Help Out There???
Also, i see the vibration at between 40-60MPH in top gear with RPM of about 1500, it's like groaning noise.
I am curious to know, what you did to fix this problems..??? Did you ever got that fixed. Can you please reply. Any help would appreciated.
If you find a solution please let me know.
My van has not had any accident and any repair history, so we are not happy with the engine dead without any warning. We asked the American Honda to send the District Manager to take a look and at least we can get the second opinion, it is very dangerous that the van was dead suddenly on the road without any warning. The case manager refused this and he said he only stand behind the Warranty and the dealer's decision (but not the customer). I am so disappointed to hear this. I said I did not ask for any refund, just the responsible way for the entire Honda’s customer, he refused this from the beginning to the end!!!
Please let me know if you guys have some good suggestion!
I do know other people from earlier posts that had the same work done but did not help. Hope your dealer looks at closer it definitely looks like a transmission issue which is covered by the power train warranty.
We have an 07 and I have not been thrilled with it. (ever)
that will buff right out.
I have observed the cruise control throttle cable not retracting 100% and have tightened up the cable as it was a bit loose.
Honda service looked at it twice. $550 in the hole later they say spend $650 and replace the throttle body. Sounds reasonable to me if the idle was rough or ramping up or down....
Please respond if you have heard of this happening. - Thanks
OHare Honda dealer service has not experienced this problem. HELP!
Sorry to hear yours caught fire. Do you know where it started?
Trevor
VTEC, the original Honda variable valve control system, originated from REV (Revolution-modulated valve control) introduced on the CBR400 in 1983 known as HYPER VTEC. In the regular four-stroke automobile engine, the intake and exhaust valves are actuated by lobes on a camshaft. The shape of the lobes determines the timing, lift and duration of each valve. Timing refers to an angle measurement of when a valve is opened or closed with respect to the piston position (BTDC or ATDC). Lift refers to how much the valve is opened. Duration refers to how long the valve is kept open. Due to the behavior of the working fluid (air and fuel mixture) before and after combustion, which have physical limitations on their flow, as well as their interaction with the ignition spark, the optimal valve timing, lift and duration settings under low RPM engine operations are very different from those under high RPM. Optimal low RPM valve timing, lift and duration settings would result in insufficient filling of the cylinder with fuel and air at high RPM, thus greatly limiting engine power output. Conversely, optimal high RPM valve timing, lift and duration settings would result in very rough low RPM operation and difficult idling. The ideal engine would have fully variable valve timing, lift and duration, in which the valves would always open at exactly the right point, lift high enough and stay open just the right amount of time for the engine speed in use.
VTEC was initially designed to increase the power output of an engine to 100 PS/liter or more while maintaining practicality for use in mass production vehicles. Some later variations of the system were designed solely to provide improvements in fuel efficiency, or increased power output as well as improved fuel efficiency. In practice, a fully variable valve timing engine is difficult to design and implement.
The opposite approach to variable timing is to produce a camshaft which is better suited to high RPM operation. This approach means that the vehicle will run very poorly at low RPM (where most automobiles spend much of their time) and much better at high RPM. VTEC is the result of an effort to marry high RPM performance with low RPM stability.
http://en.wikipedia.org/wiki/VTEC
did you resolve yours?
I hope you have better luck.
Mechanic checked other plugs - all were in tight. Put coil in head (in place) and replaced plug.
When we opened it up, there was evidence of a mouse nest under the cover, but can't find any evidence of them chewing on anything. We are guessing it's something they did or maybe it's just bad plugs. (Due to be replaced anyway.) We don't think it's likely it's the ignition control module.
Any guesses, theories or ideas?
