Make sure your shift level cable is not out of adjustment. Over time I think it stretches. If cable is out of adjustment, you think it's in drive, but it's actually 1/2 way between neutral and drive. I suggest you ask your mechanic. I thought it was hard to do without a lift, but it's not impossible.
The transmission interacts with the engine (controls, sensors, etc.). Look for problems here. Their repair cost is low compared to transmission repair. Check the fluid level HOT. Low fluid can cause all kinds of symptoms. I made this mistake once. Good Luck
A while ago (don't remember where), I came across this note on Throttle Position Sensor symptoms and saved it:
"A faulty TPS can cause driveability problems such as hesitation, stalling, an erratic idle, pinging (spark knock), no torque converter lockup, hard starting, an intermittent check engine light while driving, poor fuel economy, and generally poor engine performance."
I would also add "random transmission slipping" and weird shifting patterns as well.
I have a 95 GrandCherokee AWD with the 4.0 about 178,000 miles. I recently replaced the headgasket because it was leaking oil. That didn't work but after I got it back together and test drove it the tranny wouldn't shift properly. When i push the gas starting out it got to about 3000rpm then skipped over 2nd and went to 3rd for a little and into overdrive. The trannys strong it just don't shift properly. when I get it up to speed and need more power, and push the gas it shifts from OD to 3rd but no other gears like before i worked on it. I checked the Throttle Valve cable, I took a TPS(throttle position senser) off my brothers jeep and that didn't fix it. I also checked the Tranny fluild and its full and was just changed Jan 09 when my brother had it (He's a mechanic and it got him stumped). Those are the only things i did when i worked on it that are Tranny related. I also had him hook up our scanner and no codes and we tried to reset the computer but nothing. Now I'm stuck i would appreciate any suggustions. Thank You!
The first thing I would double check is all the wiring and connectors that might have been affected (or moved) by the head gasket job. It sounds very possibly like a bad or loose connection to one of your sensors might be taking place. I can't help but think you don't have a new problem separate from the gasket job, just one that was the result of it.
Ichecked all the vacuem hoses and you can't get them mixied up and theres not many, about three. it runs funny if you unhook them and a check engine light but it runs fine when there hooked up and the light goes out.
I played with all the pluggs and they all look ok. I think the only one that affects the tranny is the TPS and if i unplug it it runs funny. My brother said the TCM(tranny control module) may be in a limp home mode if that is an option. if this is possible do you think a senser made this happen and it will correct itself or can you reset it.
What model transmission do you have? I found this diagnostic trouble code method on link title and didn't know if this method would give any different information from what your scanner does.
I think the Transmission is a 42RE or 46RH. I got the numbers off the tranny but they don't tell me nothing without a chart. I tried the link you gave me and it gave a code 16 for transmission temperture sensor. While i was counting the OD button flashes the check engine light was flashing for about 28 flashes. Do you know what that whould mean. thank you!
I figured out that that flashes are codes and the first is 12 batter connection input to PCM (which is nothing), then 24 TPS voltage high or low test TPS, 14 manifold absolute pressure sensor voltage too high or low, 13 indicates problem with manifold absolute pressure sensor vacuum source. and now the OD button flashes 55 for end of message. I also played with the MAP sensor on the firewall and now its trying to shift for more power, i'm thinking that sensor may be bad or bad connection.
Hopefully you might be on to something. Judging from your vehicle description and this page (link title), it looks as if your tranny is the 42RE. A good short description can be found here at link title. The manual can be viewed at link title.
I had a previous experience earlier this year where my TPS was affecting shifting and engine performance on my 98 Cherokee with 198,000 miles. Replacing the TPS only "fixed" it about 2 days. In the end, it wasn't the TPS, but the female connector plug going to the TPS. The weight of the wire harness on the connector had weakened the grip of the connector (female) prongs. Only after I disassembled it and squeezed the prongs tighter did it work. Initially I thought I was dealing with a broken wire, because moving the wire harness would make it act up, only to find out later the connector itself was the culprit.
I dropped the pan this evening and it is a 42RE because the links said about a few parts on that tranny and me and my brother found those parts, plus it's a four speed w/ OD. When I dropped the pan a few shaving were there but i'm convinced it's one of the sensors I unpluggedduring the head job.
Today I found a plug inside that was mentioned in that link which is for the tranny and to me it looks fine but i'll have to have my brother look at the reading. Tomarrow when I drive it to school I'm going to see what codes come on the scanner, i had some MAP sensors that were from some GM cars which is what is used on some jeeps, and i'm going to see if the MAP code goes away.
I also will take that TPS plug apart again and make the female end tighter. Thank you this is alot of help!
I now have no codes, the MAP code is gone and the TPS I tighten the female ends and when I went down the road it tried to downshift, but went back to what it was doing before, The TPS checked out ok on the meter, but when I play around there it tries to work right? :confuse:
When I had the bad TPS connection, wiggling the wires going into the TPS connector while the vehicle was idling would make it act up and the engine would go up or down in RPM's. That's how I discovered the location where it was bad. Now that I fixed it, no matter how much I wiggle the wires, the engine doesn't change.
One thing I was unaware of while looking at the Transmission manual, was how close the adjustment on the Throttle Valve cable is supposed to be. If this applies to your vehicle (if you're not aware of it), look at page 21 - 6 in the manual, They want it "within 1 mm (0.039 in.) in either direction" . The total tolerance they allow you is a hair over 1/16" of an inch! I wasn't used to Throttle Cable adjustments using tolerances that close. On a previous GM vehicle I had, they said to push the cable back into the bracket, then push on the accelerator to the floor bringing it back out and resetting it. I know using this method I wasn't getting tolerances they call for in the transmission manual here. The 42RE Tranny manual shows the adjustment on page 21 - 44.
My girlfriend is having the same exact problem with her car. While she is driving the car shifts into neutral and all the dashboard gear lights light up. Did you find a solution to this problem?
My girlfriend has a 2005 Grand Cherokee Laredo, and while she is driving she says the car will occasionally shift into neutral and all the dashboard gear shift lights will light up. The check engine light will also come on periodically. Does anyone have any idea what might be causing this?
This could be alot of possiblities, but start simple. Check the Tranny fluid, because if it's like it's going into neutral then it might be slipping out of gear. Low fluild on new vehicles causes wierd things. If it's low on fluid don't drive it until you add fluid. Some cars need to be running and hot to check proper fluid in the Tranny, but i would check not running to see if any is there first.
Also have scanner hooked up to see the codes, or like on my 95 jeep you switch the key on an off three times leaving the key on at last turn(not starting), then wait for the check engine light to flash. The light will flash codes like one flash, pause, two flashes, pause would equal 12. This will tell you what to look for. This might not work for all vehicle. Good luck!
The same thing just started happening to mine (2007 Jeep Cherokee Laredo) and the dealer was unable to offer any suggestions? can you please let me know what you came up with for your jeep? thanks
Hi , i have a 2001 GC with 150K miles on it , has the same problem with your transmission , did you know what was the problem with yours !! its at the shop and the mechanic have no clue !!
My 95 jeep is doing the same thing. A few weeks ago I decided to fix my engine leak at the head gasket, so I took the Intake and head off and replaced It the leaks still there and when I test drove it the tranny did the same thing. I think a sensor I touch during the head job caused it but I don't know. If you look at some of my post i've got some good resposes maybe it will help you out.
What engine work did you do because there's alot of things that factor into the tranny. let me know what you find, if find somthing i'll let you know good luck!
I wiggled the harness at the intake all around where the TPS and MAP sensors are. Now there's a code for the TPS voltage. I'm going to rip back the tape and trace some wires maybe i'll be lucky. My brother the machanic told me to try driving it with out the kickdown cable and it shifts like it's been but alittle worse so we know the cable is working. I'm going to cleat the codes after I look at the troubleshooter in the scanner, which my brother will do may i'll find something.
I read an article you posted the 42RE about a default mode on the TCM, which is 3rd but manual shifting is possible, and that modes from a fault code, what does this mean, there a way to reset this TCM? Thank you!
i dont know much, i think it was a transmission control module that they replaced. i actually had to leave my jeep there and they went out several times a day and tried to start it until the "transmission over temp" sign came on and it didnt start. then they hooked it up to their machines and figured it out from there. they cant fix the problem until it actually doesn't start. at least in my case, my jeep would start for a while, then just out of the blue, it wouldn't start. good luck, hope this helps.
seems dalmer/chrystler's decesion to farm out their soldering to third world countries did exactly what they needed it to do..last ten years,then-good luck ! --after re-soldering mt headlight switch,my headlights don't blink on and off like the alarm has tripped..it works fine now.. --my best advice is to get a tube of DIELECTRIC GREASE-available from electrical supply places,then anytime you unplug ANYTHING-give the connection a good coat of that non-conductive grease..at least it will slow the contact corosion problem these trucks seem to be plauged with--even when you change a bulb !
p.s.. people--PLEASW CHECK YOUR TAILIGHTS AND BRAKE LIGHTS!..this annoys the hell outta me when people don't seem to care if their lights work ! the simplest way is to see your reflection in a store window !..might keep someone from hitting you! to keep the break pedal down to check brake lights-i use a hammer weged between the pedal and the front of the seat !but don't leave them on too long,as they get hot !..makes changing them harder.. :sick:
Hi , I need help !! my 2001 jeep has 150K on it , and when i take off the car is so heavy like putting a lot of effort ( i assume the transmission starts from the 2nd) and it will not shift to 3rd or 4th unless i start driving with the shift is on 2 and when i aproch a highway i shift it to D and OD then it runs smoothly , it used to do that once in a while but now it does it everyday , took it to the mechanic he said rebuilt or change the transmission which i will not do and prefer to sell the car instead if couldnt fix the problem , so please Help !!
If you wiggled the harness and got a trouble code when there was none, it seems like there's a bad connection (or wire). Be careful as I have, of tripping a code by unplugging a sensor or something else.
The 42RE article about the default mode means if the TCM has a trouble code set, then it places the transmission in default mode as you described. On my 98 Cherokee, when I erase trouble codes with the scanner, it erases trouble codes in everything (engine computer and TCM). On my Jeep, I can only read the engine computer trouble codes, and not the TCM. I'm told I need a DRBII scanner to read those which the dealer has and is very expensive. I was surprised by some Jeeps with the 42RE, having the capability to read trouble codes of the TCM separate of the engine computer. I don't know if yours has an overdrive switch, but this is what the article described:
"This system has self-diagnostics. Fault codes can be read with a scan tool or by cycling the ignition key three times, then counting the flashes of the LED in the OD off switch."
My Jeep is a 95, with the OD off switch, which is before the OBD-II scanner connector, mines the OBD-I connector, there is one in the engine bay at the computer which we looked at and some codes were on that we caused, and then I found a plug inside for my TMC. The scanner we have reads the TMC and the computer, from that we got alot of readings, but I had no codes when I had the scanner in. Now with the flashes you said about I checked because I didn't have the scanner and I have TPS codes in both computers, this is after I wiggled the wiring harness a few days ago.
How do you know if it's in default mode, from the articles my symtoms would say but i'm not sure. I guess the scanner will reset this.
The way I translate the article (link title), default mode is when you place the transmission in "drive", it automatically goes to third gear. You can make it go to reverse or second gear by manually putting it in that gear yourself. Seems like you have a choice of three gears while in default mode. To me it doesn't sound like you're in default mode because you have all your gears, they're just not shifting right.
My 98 Cherokee with an AW4 transmission had the same symptoms. Not sure what your transmission is. I brought mine to a transmission repair shop for a free first time estimate, and all he could tell me he was the fluid was a little dirty and he didn't know what was wrong. According to him, my only option was a total rebuild. Then I thought, what the heck, I'll bring it to the Jeep dealer, with all their tools they will know what's making it act up. I got the same answer from them, only this time I was a $100 poorer.
I knew the "guts" of the transmission was alright, because like yours, once I got it to drive it ran normally. Only when I came to a stop, it would not shift down to first unless I manually put it there (in order to take off again). So with nothing to loose, I bought a solenoid kit consisting of three solenoids off the web and installed them. To my surprise that's what my problem was.
If this is what you decide to do, look around at some of the transmission parts sites on the web for solenoids. The Jeep dealer wants an outrageous price for theirs. I got all three solenoids (the kit) off the web for LESS than the price of one from the Jeep dealer.
Sounds good to me. I had the scanner hooked up tonight with my brother watching it and everything is working and there's no codes, we cleared them so now I'm going to drive it tomarrow and see what happens. It tells me the readings of all the sensors to do with the tranny, so I want to see if they are correct. Also the scanner says that everything is good and ok to drive.
Do you think the TCM could have gone bad. I was reading about them and TCM tells the tranny when the best time to up shift and downshift, but there is only one shift solinod in that tranny which is for the OD and the rest I think is controled by shift valves. and the solinod is working because I have all gears.
I need to look at the engine again I ran out of time. I want to check wires to the TPS. Thank You!
From what you've discovered so far, I don't think the TCM is bad. I have a spare one which I used to switch with the factory one to rule out the TCM, and that has never gone bad on me. I've read some people have had the dealer reprogram (or Flash) them, but it's not cheap. Yes, from what I read your TCM controls the solenoid for 3-4 upshifts and back down. Shift valves control the 1-2 and 2-3 upshifts (and back down I assume - they don't say). But what actually controls the shift valves themselves is the TCM, because it controls what the governor pressure solenoid does - and that is how much pressure the shift valves have to work with. So actually, there are two solenoids, one is a shift solenoid (3-4) and the other is a governor pressure solenoid (valve body), from which controls your shifting. The clinker in all this is that your TCM relies heavily on inputs from all your sensors, so they make a good weak point.
One thing I thought of and read somewhere, is make sure the ground strap from the engine (or tranny) to the frame is good, otherwise it will mess up all the electrical parts and make them act strangely. Especially after working with the head, there might have been one connected to it.
You're lucky you've got the tools and a brother who knows what he's doing. Best thing is, don't get discouraged because in the end I'm sure you're going to find it's only a wire or small component that's screwing things up. I've been there many times.
There's not one of them on mine but I know what you mean. When my brother work on his cherokee a few weeks ago (headgasket) we had to unhook that strap, but the only thing that is in the back of mine is a plug, I think with one wire and I checked I out and played with it and it didn't change anything. Do you know what that wire is for. It screws in to the head then a plug hooks on?
There was no ground strap on the back of the head like my brothers, a one wir plug which I had to unhook. This screws down into the head then the plug hooks on from the harness. Could this be my ground to the head.
Could very well be. Either way, the transmission has to be grounded to the frame in some way for it to work right. A corroded ground would cause the same problems. My Jeep has a flat braided strap (wire) from the head to the firewall. I don't know what 95 models used.
I would like to add a request to all the people posting their vehicle problems in this forum. If you have found what was causing the problem in the message you posted, please let the rest of us know what your solution was so we can all benefit by it. I've learned and discovered many solutions in forums like this not found anywhere else. Many of them are not to be found anywhere, not even from the manufacturer. Forget garages and transmission specialists, as they are not going to throw away easy money. Feedback benefits everybody! Thank you.
You think oil will make a ground short out because there is oil on some of the plugs and I've been spraying them with WD-40. I'll ave to look and see if there's a ground.
Yesterday I drove it to my buddies house and put the scanner on it and I had a code 13-VSS in the tranny and the code 24-TPS in the engine. And the night before we cleared the codes, but nothing has been showing up, also I took voltage reading on all the sensors from the scanner and they are around specs.
Still sounds like something isn't making a good connection somewhere. I assume all your fuses are ok. How is the PCM grounded? I looked at one schematic (link title), and it says the PCM provides the ground for the TPS and MAP sensor. That was on page 8w-30-4. Unless a component tests bad like the VSS, up to this point my guess is it's in the wiring or a bad connection or ground.
When my brother bought this jeep before I got it the powerwindows didn't work, so we checked for power to the moter and there was so we put a ground on the other and thats how they been working for the past year. On his 1990 jeep he had there was a fuse he found hanging down from the dash in line with a wire and needed a fuse so he used it and it shifted strange the next day, then he put that fuse back and it shifted great. Do you know if there is a fuse like that on mine and where, all the fuses I just looked at were good.
I don't recall any "inline fuses" under the dash of Chrysler products, although I could very well be wrong. It makes me think maybe it was a wire from an accessory someone added, like a radio or lights. But don't get me wrong, it could still be something Chrysler made with the Jeep.
Since initial inspecion of the trans was OK, I would be suspicious of the shift lever cable and make sure it is properly adjusted. Over time everything stretches and gets looser. You may think you are in drive, but you are actually 1/2 way between drive and neutral.
My 97 jeep has a manual indicator which just shows you the position of the lever.
I assume you have a manual indicator. If you have LCD indicator on dash, I am not sure how they work, but in either case, the cable may be the issue.
Saturday I checked the codes on my jeep and it had a code 13-VSS, so I cleared it and drove it sunday and now today monday. I just hooked the scanner up and I have a code 13-VSS. It tells me there is no signal. Now this is what controls my speedometer and that is working, when we unhooked that no speedometer. Any ideas. I think tomarrow if I have time I will take the sensor part off and see if it's defective. I'll keep you updated.
Found this page link title on Speed Sensors. It focuses on newer models with a note about earlier Cherokees.
A few electrical diagrams I found on the web show the Vehicle Speed Sensor sharing the same circuit (or wires) as some other sensors. All three of them end up back at the PCM. If that is a code you keep getting after repeatedly erasing it, and you've checked the wires and connections (I know some are hard to get at), you might consider replacing that sensor. It's a 50/50 chance this problem is related to the head gasket job, so it's possible a problem happening at this time might have been a coincidence. One thing for sure, it's definitely a part that would cause those symptoms.
I have an 2006 Jeep Grand Cherokee with approx 33,000 miles. I moved my car this morning and there was a good size puddle of transmission fluid under it. Upon inspection it looks like the pan gasket is the problem, I checked and all the bolts are tight. Anyone heard of a gasket going bad so soon? I tried to check the fluid level and where the dip stick should be there is a cap that reads "For Dealer Use" Can I get one at any auto parts store? How much fluid does a grand cherokee take, the manual doesnt specify? How much torque do I use when putting the pan back on?
At 33,000 miles you shouldn't be having problems with any gasket. Is it possible a silicone type gasket was used by the manufacturer instead of a pre-cut one? I was surprised to hear some newer vehicles don't have a dipstick for the transmission. A few pages which discuss this and have some parts numbers are link title and link title (see page bottom). Two dipstick sources are link title and link title. Like you mentioned, I would try a local auto parts store first. Also, Googling "dipstick 8863B" brings up a lot of hits, although I'm not sure if that's the correct dipstick number for your Jeep. As for tightening torque, I only go slightly tighter than "wrist tight" using a srewdriver type handle with socket for older precut gaskets, but in your case I would try to obtain that information from a service manual or dealer.
My sisters vehicle has no dipstick, they want you to go to the garage and get it checked and have them do it. And I would do the same for torquing, just finger tight the snug them with a wrech or socket don't torque on them they break and leak, it works for me i have no leaks you should have no problem. My 95 I put in about 3.5 quarts almost 4, then checked if it was on the dipstick, but you should add a quart at a time then check it you have on the dipstick, then drive it, check it running and added if needed. Good luck!
Today when I drove it and parked, I cycled the key and it gave me VSS code and Governor Pressure sensor offset drift. My brother and I think you are right about the connection, but we think a ground, because of the ground for my windows going(still didn't find) and moving wires causes different things so. I'm going to a shop tomarrow where he gets his diagrams and get a ground diagram for all the grounds and whatever will help. And start here tracing wires (fun). I'll let you know!
Let us know if you discover anything more.
p.s..
Good luck and keep us posted on what you find.
Thank You!
I'm still searching for other ideas.
Thanks in advance for your help
