When I insert DVD's into the changer it accepts them ok (and ejects as well), but then nothing happens. The rear screen remains blank and there's no reaction to whatever I press on the remote. Am I doing something wrong or the RES is screwed?
Also there's no reaction to pressing the UConnect Phone button, maybe there's a correlation?
Any suggestions?
http/www.smartauto24.com">link title
Can I simply remove my existing standard radio and install one of the Chrysler head units or do I need some type of adapter kit?
Preechr
yoki
someone help me please :confuse:
I'm posting this here because this DVD player flashing and broke seems to be a common problem that Chrysler doesn't want to address except to sell you a new unit between 500-1200 dollars.
Thank you so very much for responding.
"I reassembled without the two disk and it works. except I can only put 4 disks until I can find replacement disk finger tabs.. "
How did you reassemble? How did you get in?
My question to The Chrysler Media Systems expert was "What use is a VCS if you can't use it to make selections from the HDD? That technology has been available for years and it's incomprehensible why Chrysler would allow a dinosaur like that on its top-of-the line 2012 auto." Answer: "Sorry but your system does not have that capability. There may be a software upgrade to provide it later but nothing is available now".
WOW!! Who wouldda known? Guess that all I can do is express my astonishment and disappointment. Sure hope the nerds who designed the Media System didn't participate in design of the rest of the car!
Any comments?
I have not been brave enough to take it apart, as my usual struggle is at the "reassembling" phase of such projects. Let me know how it turns out!
I have an REN unit in my 2009 T&C that has started turning on the MyGig system. It will go completely off and then come back one. Sometimes it will do it every 3 minutes, sometimes it takes longer. Sometimes the screen will just go black, whereas other times the unit reboots and the Chrysler logo reappears.
I have application 9.214, grace notes 881
The system is 6826 006 3.3
I've visited http://mofv.com/mygig/ and downloaded the most recent application available. I'm burning it to a data CD now to try the update. This started just a day ago but has been consistent during the day.
Any thoughts? The stations are not being lost, just the unit is turning off and turning back on. I feel there is a loose connection somewhere but I don't know where to start. Again this is a new problem and we have not had any service done on the car prior to this problem.
Today we will see what's happening and if it made it any better. I found one other case of this happening and they had the same version of both. REN 9.214 and GraceNotes 881. Well I'm not updated to 2.292 which I believe is the last of the REN updates. We will see if this helps the function of the unit.
I did try to erase all the music off the HDD, it seemed to take forever and never completed on it's own. I ended up deleting some songs manually which now shows a clean drive with almost 29 gig of data.
So if anyone has any thoughts please share~
We deleted everything off the internal HDD and the head unit hasn't given us any problems. All updates were a success and the unit is performing just fine. I do believe the internal HD is the problem, but I don't need it and would rather not take it in to fix something I don't use.
SO I have not idea what the real solution is, however removing the data off the HD resulted in the unit working right.
Jesse
THere must be another option utilizing the Uconnect System.
Michael
