-mike
Subaru Guru and Track Instructor
Is this a head gasket fixing to go? They put the conditioner in it at the 30k service and I don't know if the greasy spot is oil or coolant. Thankfully it's still under warranty!
If that is the case, make sure you let us know! :surprise:
As a tech though I can understand that cars break but I sure didn't expect HG replacement so soon. Thanks for listening to me fuss! I'll have the work done and then watch it like a hawk until the end of the warranty.
-mike
Anybody ever have oil samples tested?
Just my two cents but it seems you may be over reacting a wee little bit
-Frank
Seriously I think you are blowing the ramafications way out of proportion on this!
-mike
-mike
I loved my Subaru and bought it with the understanding it would run to 200,000 with only minor problems. Needless to say, I was not happy I had to pay $5000 for a rebuild (of my own engine) after only 100K. Subaru America also totally ignored the faulty engine design (no bulletins), but replaced it with a redesign after only one year. I no longer trust Subaru as a company.
If you are looking to keep a car for 20 years or 200,000 miles, I think a Honda is a better bet.
-mike
But I do agree that you should be able to expect a Subaru to last longer than 100k before any major works needs to be done. On the otherhand, it is a 10 or 11 year old vehicle we're talking about...
In any case, by all means, go buy a Honda, they NEVER fail
-Frank
Let's not forget the 2002 CR-Vs had that engine fire problem when the oil filter gasket would stick to the engine block. I recall at least 9 or so caused engine fires.
I had a 98 Forester that went about 90k trouble-free miles, sold it, now we have a 2009 Forester that we trust completely.
You have to see a pattern of failures, i.e. not just one or two, to conclude a certain problem is common.
There's a guy in the RWTIV thread saying he has a Fit that goes through $1000 worth of brakes every 5000 miles, but even if it's true (doubtful) that doesn't mean the Fit has poor brakes.
I'll keep ya'll posted on this, especially if they have to send the heads out for milling. I really and truly have no desire to trade and have car payments again. Plus this thing just flat goes in the snow. Can't wait to test it with the new Blizzaks I installed Wednesday!
-mike
I'll be heading to the dealer this coming Tuesday for the HG replacement. I'll keep you folks posted on whether or not they send the head(s) out for machining.
I'm going to check my mom's 06 and see if her car has any seepage. The dealer uses a synthetic blend in her car versus me using full synthetic. If hers is exhibiting any sign of leakage, I'll tell her to take it to the dealer and have it checked while it's under warranty.
Called the dealer that did mine and told them about it. The service advisor said SOA had them return the HGs to SOA headquarters for analysis. Hopefully they'll figure it out. I'm wanting the same tech to do my mom's car since I know he does quality work, if it turns out the gaskets actually do need to be replaced.
Keep ya'll posted!
Needless to say, my faith in Subie has been restored!
http://www.blackstone-labs.com/free_test_kit.html
I have monitored the Forester Forum for the past year and have not heard of a head gasket leak on the 2006-on Forester.
http://www.subaruforester.org/vbulletin/
As I posted earlier, Mom's 06 showed signs of oil seepage on the passenger side head gasket. I cleaned it and will recheck it every opportunity I have. If it comes back, then it's off to the dealer with her car.
I have a 2003 Forrester 2.5 XS with 73K on it. Although it’s a 2003, I bought it in May 2002, it was one of the first new ’03 models that hit the showrooms. I’ve maintained it regularly and haven’t had any major problems with it. Until this month. I had leaky head gaskets.
Contacted Subaru. After some delays in getting an answer, in the end, I was told that my Subaru is “not part of the campaign” that Subaru apparently has to help customers who have had the head gasket problem. The “campaign” is for 2000-02 vehicles only.
Not the ideal outcome from my perspective. And it does seem like the issue might not have been solved with the 2002 models. I understand any car can have a leaky head gasket, but 73K seems a little early, no?
127,000 miles...no major problems.
When accelerating doesn't seem to get gas and won't go and proceeds very bumpy, then surges forward. Happens sporadically. Sometimes very rough idle ( car is almost jumping ). Pumping on the gas seems to keep it going.
Check engine light comes on sometimes. It's reading o2 sensor, but my mechanic says it's definitely not that. Mechanic not sure...thinks it's maybe the fuel pump. ig expense for a maybe solution. Any ideas? Many thanks for any assistance.
My mechanic has changed the oil filter, cleaned up various thingies and since the
Good answer here at WikiAnswers:
http://wiki.answers.com/Q/Car_hesitates_check_engine_light_stays_steady_or_blink- s_when_giving_gas_had_a_tune_up_done_and_replaced_bad_gas_any_other_ideas_of_wha- t_this_could_be_what's_a_v-tech_sensor
First change the fuel filter, it's the cheapest.
Then the spark plugs, then spark plug wires. At 127k you should be on your 3rd set of wires.
Beyond that, the ignition coil or fuel pump, let's hope it's not the latter. Everything else is a cheap fix.
My '01 Forester was doing the same exact thing a couple of months ago. They replaced the O2 sensor and she was running like a charm again. hope this helps.
BTW.... I needed head gaskets a few years ago. I noticed my fan was running more often than it should be, but the car was not overheating. I was told I needed new gaskets, but it was covered under warranty. Seems to be great ever since. I was very happy to see Subaru step up to solve this issue.
thanks!
Any suggestions? Do you think it would help to call the corporate office?
