2008 Mitsubishi Outlander
I have had my 08 XLS since new and love every aspect of my outlander. I can share the usual minor problems most owners have like the drivers seat rocking forward and backward on accel & decel but that hasnt changed my thoughts toward the outlander or mitsu.
On my second oil change an oil leak was noticed by the dealership I worked at which was NOT Mitsubishi. I drove 3 hours to the closest dealer and my oil pan was resealed. (6000 kms) Third oil change when my tech told me the oil leak was still there I thought he was messin with me. Drove back to Edmonton where I was told that there were a couple cases where the actual walls of the block were porous. Upon inspection the dealer replaced the rear main seal but they did not sound like they thought it was the actual problem, just wanted to try something. (12000 kms) Had an oil change and AGAIN it is leaking and worse now than ever. (29000 kms)
Anyone??? :sick:
Not my idea of a dealer tech. If properly torqued the drain plug should never do this. :sick:
Your Mitsubishi garage must find out what is going wrong with your oil leaks. Clean thoroughly your engine where there is oil. Drive it just for 1 mile, stop the car in some place where you can go underneath the car and observe the oil leaks. Open the bonnet/hood and observe the oil leaks on the engine. If there is no clear oil leaks drive the car for another mile and repeat the process. If you can take photos of the oil leaks take it. If the leaks is around the oil drain plug then the experts has messed up your car, if the oil leaks is around the engine seals then you need to put new ones to cure the leaks. As I said an experienced mechanic must be able to tell you what is wrong with your car.
Sorry to hear about this!
:confuse:
Boring question I know, but thanks in advance for any suggestions.
Even if you don't buy from them, the reviews at TireRack.com can be informative.
After finding the OEM GoodYear Eagle LS tires to be just so-so on my old Galant, and being dis-satisfied with the quality of Michelin Energy tires, I put GoodYear TripleTred Assurance tires on the Galant and noticed an improvement in wet & snow traction. Based on that experience my wife put them on her car.
At the moment those are what I plan to replace the OEM tires on my '10 Outlander with when the time comes. They aren't cheap tires by any stretch but should last a long time.
Could be that Energy tires perform differently depending on size, so might be good for 185/60R15, bur no so good for larger wheels and/or heavier cars. Our Eagles currently have less than 1000 mile wear, so we have plenty of time to sort this out!
I will recommend for your case the Yokohama YK520. I have used in my Outlander XLS 2008. They are not expensive.
I do miss the Michelins. I see they make HydroEdge for 225/55R18, and would be tempted to get a set when the time comes.
The YK 520's were excellent up on the gravel and dirt forest roads..If you don't mind the loud "whrrrrr" when rolling on highway, I'd recommend them. They were not expensive..The noise started with the 520's after about 10,000 miles and progressively got worse..
N.B. Tire shop always sends me out with 36psi...
