GMC Yukon Start Stall Idle Problems
I love my 2001 Yukon xl Denali with over 130,000 miles but having some starting problems. The initial problem was taking several tries to start, when after it seemed a clog was cleared and the engine banged loudly once it would clear and start and be ok for the rest of the day, but a little more difficult in colder weather. I brought it to a small gas station where they kept the vehicle over night, recognized the problem but couldn't diagnose. I went to the dealer and they couldn't even find the problem after keeping it over night.
The problem is now getting worse. I have to keep pumping the gas rigorously several times and restart several times to finally get it to turn over and actually start--it is not weather dependent and a little harder to start even after the vehicle has been in use during the day. It has never not started, but I really don't want to get stuck somewhere.
I don't know what to do or where to take it---any advice.
It started up just fine but the next time it was driven for a while and shut
off for about 30 minutes, it would not restart again... not even after waiting
more than 12 hours. Here are the results of some testing that I have done:
No check engine lite was ever present, and plugging in my OBD2 reader showed no error codes. Security light seems to function normally - stays on for about 5 seconds after turning on the key and then goes off.
The fuel pump does run when the key is turned on.
The fuses are good.
The starter relay is good. Jumped across the output terminals of the starter relay socket and the starter cranks fine, motor starts but will run for just a couple of seconds.
The ignition switch on this vehicle was just replaced about a year ago.
According to the factory manual that I have, there is supposed to be a ground present on one side of the starter relay (coil side) this is pin 85 on the relay, and then when the ignition key is turned to start, there should be +12 volts on the other side of that relay coil which is pin 86. I dont see either when I put my meter on there. The diagnostics dont appear to take into account the theft deterrent system, which I suspect may be the reason. Should I be able to see theft deterrent trouble codes with the OBD2 reader as well? I tried adding a ground to pin 85 of the starter relay but it still wont start. What else can I do to figure out what is keeping the starter relay from working? Is there a way to bypass the theft deterrent system? HELP ! I'm stuck.
Thanks in advance.
Any ideas?
Help!
I just purchased a 2009 gmc yukon a few days ago. On the second day my wife was driving it and while attemping a slow left turn the vehicle died and she then pulled to the side of the road and it started right up. She was driving it today and it did the same thing. I drove and it did have some hesistation to it. I called the dealer and asked the service advisor if he had heard of this happening and he said know. I will take it in this week for a diagnostic. It sure doesn't look promising since I am already having problems. A vehicle that dies on you while driving is very dangerous. Will let you know what they find.
Note: The crankshaft position sensor is located in the passenger side of the vehicle. It is between the starter and motor.
I hope this helps.....
FYI!
FYI............GMC will not sell U a Idle Air. They make you by the Whole $850 TB assembly. Dont attempt to buy from Online auto parts house! They will not fit!!!!
Model's referenced 2000-2002.
