Don't said that, man.
Aisin transmission used synthetic fluid. Once in a while, the service people at Mazda dealer put in the wrong fluid causing it to seize up badly. This has been happened to many other brands as well. Wrong fluid kills transmission. Aisin is the transmission supplier of Toyota and Lexus. The reputation is there.
Mine has 21K on it and it is as smooth as day 1.
It became almost comical taking it in so often. Dont get me wrong I do not complain about every little thing, heres another issue to add. I started to smell mold in the car a day or tow after driving in the rain. At the same time I started to hear a very light clicking, but only when I would be on a bumpy road. It was coming from the right rear section.. hold that thought.
My daughter discovered the floor in the rear was wet..not damp... soggy wet. all of the windows are shut tight, sun roof is fine. I took out the rear cargo area because this is where the noise was coming from. First thing I noticed was a lot of rust. So I asked my father to drive while I sat back there and looked around . What I see right away is where a spot weld gave way hence the metal to metal "tapping sound"
But when he drove through a puddle ..the water is channeled up through the wheel well where the weld gave way..some goes forward to the rear seating area, some goes backwards to the cargo area.
When I show this to the dealer they said "you obviously drove in water over 30 inches. Well if you know the CX9 you know that 30 inches is just below the headlight...and would be about seat level on the inside...and we all know cars are not water tight and there would be significant interior water damage... instead of a rusted right rear quarter panel...i dont know what else to say.. i just done
Tried contacting mazdausa (corporate) yet and complaining? good luck...
Where in NORCAL do you work? I used to live in Davis ( I now live in crappy SOCAL ) and worked for Carmichael Honda in Citrus Heights just South of the Roseville Auto Center and just North of Sacramento.
Sorry for the bump on this thread!
I posted the following on the Ventilation/Air Conditioning forum:
My CX9 is out of warranty so I asked my buddy that works at Riverside Mazda to hook me up with a copy of TSB 07-008/09. I read through it and was very simple and straight forward. I bought the relay that the TSB said to replace (part# G115-67-730) replaced it (under hood relay box closest to the driver's side fender) and up to right now no more occurences.
I know that I am referring to the relays on this post, however, I do recall reading on this TSB something about doing a check on the complete control unit and thus replacing the head units if faulty. If you can get a "nice" Mazda employee to fax you this TSB, it may help you to get your problem fixed.
Don't place your keys too close to the vehicle when they are not in use.
That way, the battery gets drained more quickly.
The button 2023 (or is it 2032) battery is very commonly used. Store a few as backup like your typical AA or AAA.
Thanks for all of your input.
Hope they fix your CX9 at first time.
BULLETIN NO: 02-006/09
XXE1LXRX/.90
TD11-34-380B
82/92A
TECH REPLACED RUBBER MOUNTING
As you see, it is relatively new TSB.
One of the benefits of having the "Auto" setting is to avoid this "lights on" alarm. The dealer acknowledged that this issue is annoying and defies logic, but after several hours he chalked it up to a poor design that could not be fixed with the 2007 models. This seemed like a convenient answer to the dealer, but exceptionally inconvenient for me.
Has anyone had this problem and/or been able to have it fixed? Thanks.
It must be a design flaw of 2007 model.
Maybe other 2007 model owners can confirm this.
I never thought it was odd because my previous 2003 Honda Accord did the same exact thing. It also only had two positions "OFF" and "ON" and it also alarmed me if I got out of the car and the lights were left on, they also eventually turned off after 20-30 seconds.
Normally I wouldn't care about such a thing, but I have infant twins and every time I cut the engine and open my car door, this annoying sound (it's a constant screechy/squeal , not a soft "chime" or "ding-ding") wakes the girls unless I open the door and quickly rotate off "Auto" and back on again.
Anyone else with this problem or know of a more comprehensive forum where I might find discussion of this issue? Thank you.
You may want to cross-post over in Edmunds Answers too. It attracts a different group of folks.
Bottom line, do not let them treat you like dirt and yes any other Mazda dealer can service your vehicle as well even if you did not buy it from them. BTW, if your door is jammed it could be covered under warranty since your CX-9 is only a 2008 as long as you have less then 36,000 miles.
Good Luck!
I have mine replaced (four on the doors). The service advisor actually used hie finger nail to scratch off some paints, therefore, he easily agreed to replacing them. The problem was due to lack of a protection layer on top of the silver base layer. That makes it easily scratch-able.
We recently resolved a bizarre issue with the lose of tire pressure to our 2008 CX-9. The tire appeared fine for months at a time & would only act up when the temperature dropped below 30 degrees.
The first time it happened, I went to sleep with a full tire and woke up with a flat tire. When I brought it to a family friend with a shop, he assured us that there was nothing wrong with the tire. Sure enough, after filling it wilth air - no issues for several wks until the temperature dropped again, The low pressure warning light came on & same Tire lost about 5-10 psi overnight. I brought to the dealer and was told there was absolutely nothing wrong w/ the tire or wheel - NO Leaks! After 3 separate trips to the dealer to diagnose over 6 moths, they finally found the culprit which was a FAULTY SENSOR/VALVE.
So have them check this if you are having any similar issues. Could probably apply to other models as well.
I have a 2007 CX9, with MANY issues, so many that I have given up on this car totally. At least 10 trips to the dealer in an 8 month period for various things.
I have a glove box full of those tire pressure sensors.(new ones). I was in the car with my wife the other morning and the temp. was around 30 degrees, I looked at her started the car and said "you know what time it is?", for a moment she was puzzled and then said "oh yeah, it cold out its time for phantom flats" sure enough right before i dropped her off the yellow low pressure light came on.
I always figured if you abuse your car and drive it into the ground then you deserve whatever happens. But since I take very good care of it, keep it in a garage and maintained it that all would be well. HA!
Well I am glad I bought the extended warranty.
I took it to the dealer recently for the loud creaking noise, that can only be described as a wooden ship from the 1700's just to hear them say "its fine"
NEVER again .....making the last payment soon.....trade and be done with it. :mad:
But if they still have the vents, then it sounds like pressure is building when you try to fill it and as you put liquid in its shooting back out? pretty odd that it would be getting progressively worse though...hhhmmmmmmmmm. Its probably still under warranty right? try another dealer perhaps?
The guy before me had a fairly new Honda Odyssey. He was describing the strange issue he had with the TPMS to the technician. (I guess out of 3yr!!!)
My point is this. When it comes with TPMS sensors, it is the same among all brands. They all give false alarm. My co-worker's Lexus LS TPMS sensors have given him many false alarms. Each time, the dealer reset it and send him on his way.
Its wireless, it shakes and spins like crazy inside the tires.
It's bound to have "issues", if you know what I mean.... :P
Never had hit a curb or big bump...it was just like it slipped a cog???
Also, read a thread earlier about handling in ice/snow and just returned from a bad trip (it was like floating whenever in ice/snow mix and only so-so in snow)...pretty sure it is the tires based upon the "tire issue thread" and plan on replacing and only using the stock tires in the summer months since I only have 6k on them.
I am the owner of a 2007 CX-9 Grand Touring. It has 15k miles on it and I have had some of the problems mentioned here. My car has been in the shop numerous times and the issue with the snow/ice has been an insanely frustrating issue with me, since I crashed the car into the curb because I couldn't get it to stop on a snowy day. Of course, the Mazda folks would never admit to inferior tires or any issues with the car (although they have admitted that there were numerous complaints about the car not stopping). So, I had to go to the insurance to pay for "my" crash (I was going under 25mph) and the result was an increase in my premiums (never had a claim before). I live in the Northeast, so snow will always be an issue here. I suspected the tires may be the issue and I will be looking to change those out relatively soon. My luck, we won't get any more snow this winter. I won't complain, though.
I, too, had issues with the steering wheel showing some "shimmy" (the term the mechanic used) when I would apply the brakes. The steering wheel would shake a bit (the car was also pulling slightly to the left). So, the dealership checked it out and they machined all the rotors and now the car feels brand new. It has only been a few days, so I am hoping it continues.
I also had issues with the rear a/c control not being able to shut it off. I would have to put the temperature control to heat (all the way to the right) to be able to shut off the a/c to the back. The mechanic found an issue with the wiring and they corrected it. I tested it and it works great.
I also have to mention that I am now having my car serviced at another Mazda dealership because the one I originally bought it from was terrible. They were condescending and never bothered to go the extra mile to check the car. I found another place that makes me feel like they are actually trying to help me. The lead mechanic actually drove the car with me while I explained what was wrong and how it was acting. He was able to note the "shimmy" on the steering wheel and recommended what needed to be looked at. He saw that the car was pulling to the left and recommended a diagnostic to make sure that the AWD was working.
Hopefully, I will no longer have issues with this lemon. I am soooooo close to trading it in and getting something that I feel safer driving!
