Hyundai Santa Fe Timing Belt
I purchased a used 2003 Santa Fe December 31 2007 it had 59000 miles on it. It now has 65000 miles. Does anyone recommend getting the timing belt changed now? Please give me your thoughts on this.
HELP! :confuse:
I love my santa fe especially with having two kids however it is a gas hog.
What is the "Kelley Blue Book" Price?
I've had no problems with my SF, it's now got 85k on it. It has the 4cyl-5sp power train - never less than 25mpg. Just not a hot rod.
The original tires were horrible for winter snowfall (Bridgestones), but after I put some Liberators on it-the snow was not a factor.
Just my .02 cents.
If your engine is an interference one, then you are risking catastrophic engine damage if it breaks on you. If it's not an interference engine then the biggest risk is getting stranded somewhere or losing power on an interstate, which wouldn't be much fun. An owner should be able to pipe in and say what kind of engine is in yours. Gates.com says interference for the 4 and the V6, but you should double check that.
I'm, ahem, ~8,000 miles overdue on replacing the one in my wagon.
Mucho dinero.
Question #1) I am a past ASE mechanic in all areas, but have not worked in the field for 20 years.
Is this a project that I could do in the driveway?
I have not checked into anything until "Now". I know some engines are VERY easy and others are NOT.
The 3.3L is a timing chain, same as the 3.8 Veracruze.
I will never buy a car with a timing belt again. If the belt breaks, it will toast the engine for $2K - $4K. Even at 50K, Hyundai will not warranty a timing belt nor it's damage.
Audi had to have an out of court settlement after their cars broke their belts and got $4K of engine repairs. That's after YEARS of court battles. Google it.
The timing belts can be pretty easy to replace. I did two, a Chrysler and a Mitibishi. The Chrylser was a piece of cake. Just the one or two items in the front of the engine had to be removed. The Mitibishi was a nightmare... never again.
The Federal Gov. should never allow a interference engine to have a timing belt. They can make an engine not be interference, but then the car companies won't make a fortune off them. Lots of places will replace them at less cost, but will they warranty the ENGINE if they do it wrong ?
Many engines require lots of parts removed to just get to the belt. Then they have special parts needed to line up the gears.
Thanks!!
Edmunds Maintenance Guide
2003-2006: GLS; 6 Cyl 3.5L;
2003-2005: LX; 6 Cyl 3.5L;
The Gates Catalog also carry timing belts for the 2.7 V-6's as well.
Looks like the 3.3 engines get the timing chains instead of the belts..IMO a much better deal.
Combine repairs and you'll save big and buy all your parts except the timing belt ( you want the shop to be liable if the belt breaks right away ) .Since all the labor was to get to the timing belt, no additional labor would be needed to put on the other belts .
word of advice : don't ignore the timing belt change . I had a 1982 Ford Escort with a timing belt. I had no idea it had one or it had to be replaced ( stinkin car co's won't post a message on the engine warning about the timing belt ) . It had 67000 miles, it was 7 1/2 years old and one day I was driving it and I heard some noise in the engine and I kept driving for about 15 miles and then the car died. I tried starting the car again and again, nothing. Next time I hear a noise from the engine I'm stopping. Now I'll know it might be the timing belt failing and I might catch it in time. Don't count on hearing a noise, it might snap just like that and your car is out of commission.
I'm not really upset about a timing belt change and the cost because I have to replace the water pump and the other belts at 60 anyway .
re: the timing belt in the 1982 escort, me and my father changed the belt ( after the engine was re-bored and new valves installed ) ourselves using a Chilton repair manual. But the engine was already apart and it was easier to repair then.
Hyundai technician
so just you know, being some one who works at the dealership, we HATE when we have to do timing chains... belts are far more easily replaced, and way cheaper... on chains you pretty much remove the engine from the car.. or do it the harder way IN the car (removing ENTIRE front of engine(engine front cover), so if this CHAIN isn't under warranty.. you'll get charged something like 5800 bucks.. so i rather replace the 400 dollar belt at sixty thousand. any day.
good day
oh btw i've never seen a car.. have a factory timing belt detonate an engine.. IF it was done every sixty thousand, or according to manufacture specific mantainence schedules.
just don't buy a suzuki..
Thanks for any advice!
Later,
Dick
I was able to find a detailed description on removing the timing after more searching.
As for the power steering leak. I need to replace all the metal lines as the lower pressure line is cracked and the high pressure line is scraped up quite a bit. But I found out we can bend new lines using steel brake line. Some of the rubber hose needs to be replaced also.
New Hyundai's don't require timing belt changes any more, if I recall correctly. They all now use a timing chain.
If its a chain do they need replace on a schedule?
http://forums.edmunds.com/discussion/10867/hyundai/santa-fe/hyundai-santa-fe-have-a-timing-belt-or-timing-chain
