Dodge Intrepid Maintenance and Repair
I have a 95 intrepid and iam wondering if anyone has found any solutions as to how to stiffen the rear suspension for towing purposes.
Does anybody know where I can find a replacement? I'm having trouble finding anything online.
Does your rear like its blown when you turn up the bass or is mine the only one?
If interested email me at ctbrecheen@hotmail.com
Terry
Joe
Kent
Is there a special way to bang on the key? Anyway, I'd love to find out what happened with your Neon (and if it had to be professionally repaired how much did it cost?) THanks!
only way they go out is if your dumping raidator stop leek in it i would adviz NOT useing ANY of them on the market
you more than likly have air in the syatem with all the radiators u have gone throgh that is whats worng !!!! IF u have a 3.5 it's easy to fix your self
the over heating thing has hit me to it's air in the system on the intrepid's it's a closed cooling system
3.5 engine only how to fix it will take time but not to much u will need like 2 gl's of antifreez just in case
look at the engin u see the main hose going to the radiator thats your thremastat now do u see the little silver bleeder vavle next to the hose on the therm housing i think it's a 10mm rench when the car is hot open that bleeder vavle CAUTION WILL SPRAY OUT HOT AIR AND COOLENT STAND OFF TO THE SIDE OF IT once u get all coolent close vavle do this a few time then drive the car some more u will repeat this over and over till it stops over heating!!! when the car is cold normly in the morning thats when u add your coolent to the reservoir DO NOT OVER FILL LEAVE AN INCH OR SO TO THE TOP . i think i had to do it for 3 weeks or less and not all the time only when temp went over 3/4's allso check your sensor on the therm.cant miss it same location as the bleeder vavle black clip with 2 wires coming stright out the top of it and the fans if they dont come on when the temp hits 1/2 it's the sensor
Now I do not get any spark.
error code 125455.
Autozone told me that error code 54 meant that my distributor was bad, HA HA "97" 3.3s did not have a distributor.
Cleared the code and tried to restart, error code 125455 came back.
Had plenty of spark before replacing the head gaskets.
Please help if you can.
Thank you in advance for your anticipated response.
Respectfully submitted,
John Wm. Willard
John 374
What was the symtem that caused you to bring it to your mechanic----? runing hot or did the radiator fail to the point of it spewd coolant on the ground.?
What is the time between the failed radiators? More info is needed for me to make
an educated oppinion.
1) symtem
2) time between radiators
3) the first radiators cause of failure
4) What is the tech saying is the cause of this failure
5) has the car ever been in a significant accident with damage to the front end
hope this will help, i do my best to give you the most accurate answer i can
i have a 94 3.3 and had that same problem when i change the timing sensor the motor will turn and should start
u will need a 10MM wrench when the car is hot stand on one side and open the valve once u get all antfreezz the shut and waite a few min and repeat
BAD SPELLER/GRAMMER SORRY DONT LIKE IT DONT READ MY POST
2) Can the power steering pump and rack and pinion be replaced with units that do not have that option and what could be the adverse affects?
RM
Below theres also a link to the ebay listing of the K&N intake. Its listed as 211.00 free shipping. I paid more because I live in hawaii. Good luck
http://cgi.ebay.com/ebaymotors/K-N-FIPK-Cold-Air-Intake-00-04-DODGE-Intrepid-SXT- -3-5L-_W0QQcmdZViewItemQQitemZ260545839076QQptZMotorsQ5fCarQ5fTruckQ5fPartsQ5fAc- cessories :shades:
khinz163
08-11-2005, 09:25 PM
I am unable to find an intake for 1999 3.2L V6 Intrepid? What reasons are there that a intake for a 2.7L wont work? Please help me because i am desperetly trying to improve my intrepid...thanks
Crash459
08-13-2005, 08:25 AM
The two intakes are a different size. K&N actually makes a Cold air intake for the second gen intrepids. Keep in mind that the 3.2 and the 3.5 have the same block. and the 98-04 intrepids are technically the same vehicle. Do a search for any cold air intake that will fit a 98-04 intrepid with a 3.2 or 3.5 and it will fit your car.
khinz163
08-13-2005, 01:12 PM
so you think a Intake for a (2000 DODGE Intrepid 3.5L V6 F/I - All) will fit?
Crash459
08-14-2005, 06:29 AM
Yes it will.
same thing happening here, except 3 and overdrive jacked up, and if you stay in 2nd for a while it will slip and the engine winds up real loud before it shifts back in to 2nd, lolz....
transmission guy said prolly needs a new one,
i was online looking for transmission prices with labor...
