Cadillac SRX premature brake wear
Left the 2007 SRX (8 cyl) with 32,000 miles on the clock for an oil change/tire rotation yesterday. Service writer called and said the brake pads were worn, front and rear. Replaced them. I've never had disk brake pads wear so quickly except on a track car. Even then I typically go through 3 sets of front pads to 1 set of rear pads.
Others experiencing such rapid pad wear?
I like the SRX a lot and was considering replacing my E60 BMW with a CTS. I am waiting to hear from Cadillac as to whether they have or can recommend replacement pads with a reasonable life expectancy.
If anyone gets a resolution to this problem, please let me know, I dropped way too much $ on a leased vehicle.
I am beginning to think the premature brake wear stems from two things. (1) the car may be too heavy for the brakes and, (2) the transmission freewheels on deceleration requiring more brake use than on some cars.
My experience with the dealer in Austin has been exemplary. I would probably buy another SRX in a couple years except that Cadillac is switching the SRX to a smaller, cheaper platform with FWD.
Thanks for your input, maybe another dealership will be nicer and give a little credit back for the $$ I've spent.
I am from GM Customer Service. You do have the option on getting a second opinion at another GM dealership, if you haven't already fixed the brakes. I can locate another dealership in your area if you like. I would need your zip code. Thank you,
Mariah GM Customer Service
I now have approx. 60,000 miles on the car and I am returning (off lease) early to avoid another brake job!
Had the same laim response from service and reluctantly paid the $1000 + bill. This was the last GM I am going to purchase.
I apologize for your frustrations. Can you please send me your VIN, and a description of what you are experiencing? I look forward to your response. Have a great weekend!
Christina
GM Customer Service
If you are uncomfortable with your dealers’ diagnosis, I recommend getting a second opinion. Please let me know what happens with that.
Christina
GM Customer Service
I have Cadilac SRX 2004, and dealer want 2300,00$ for brake, rotors and pipes replacement. It seem extremely expensive. What I should do?? PLease help.
