I have a GLS made in March 2010 and I too have this problem. It is not unreadable, just annoying. Some have had their radio replaced with occasional success. There is a separate thread about this on the other hyundai forum: hyundai dash forums dot com
FWIW, my other main gripe is road noise (GLS) but most people blame that on crappy OEM tires and limited undercoating in the wheel wells (to save weight for better fuel economy)...
Sorry, but a new radio won't change this.
Edit: The reason some may see this more than others is that the issue will not appear linearly, ie slowly get worse with temp rise. Up to a point, there will be no effect, then it will degrade rapidly over just a few additional degrees temp change. Great technology for low power consumption, but does have it's limitations in an automotive application. One thing that will aggrevate the issue is whether or not the sun is shining directly on the radio. You can get even higher temps in the display in that scenario.
Vehicles affected Production date 12/11/09 - 09/10/10 VIN Range 5NPEC4AC6BH000216 - 5NPEB4AC8BH151446
Best of luck to all. I still like my car even with the minor headaches. I have only had it for 3 months too. Karen
http://www.familycarguide.com/blog/1049730_2011-hyundai-sonata-steering-recall-a- ffects-139500-cars
http://www.businessweek.com/news/2010-09-25/hyundai-to-recall-sonata-sedans-in-u- -s-on-steering-issues.html
The official NHTSA page and release:
http://www-odi.nhtsa.dot.gov/recalls/results.cfm?rcl_id=10V426000&searchtype=qui- cksearch&summary=true&refurl=rss
I find it curious that they say it happened on the assembly line during a particular month, yet they are recalling all US-made Sonata made from Dec 2009 to Sept 2010. Isn't that all of them?
The Sandman :sick: :shades:
2023 Hyundai Kona Limited AWD (wife) / 2015 Golf TSI (me) / 2019 Chevrolet Cruze Premier RS (daughter #1) / 2020 Hyundai Accent SE (daughter #2) / 2023 Subaru Impreza Base (son)
Sad to say, I dumped the Sonata for a variety of reasons the other day and went with a TSX instead.
There is a posting on another forum from a Hyundai dealer service tech. He said that fixing the dealer inventory was top priority, and that no cars could be sold until it is done. If in doubt, ask your dealer to show you the service order for the fix.
I'm bringing it back in on Thursday (assuming I can make it until then without needing a tow) and any thoughts on how to get them to identify the problem would be VERY welcome.
MODERATOR /ADMINISTRATOR
Share your vehicle reviews
I will question them on the software upgrade.
My Sonata from about 2007 or later has for the first time this year been leaking water into the backseat and not in the middle seat. Has anyone had this problem and how did you fix it?
http://www.bobistheoilguy.com/cms/
Doubtful you can find the hyundai filter at any place but the dealership. FWIW, I keep a spare filter (Supertech ST3593A, walmart $3) in my trunk just in case the oil change place doesn't have our compatible filter in stock. There's plenty of opinions about the quality of oil filters (and oil) but it is safe to say that you cannot go wrong sticking with the OEM brand. Costs a bit more but that is life...
Chomping at the bit to see if you can get any detail on the software upgrade. I called my 3 local dealers and they were clueless about the contents. In total, they have done over 100 inspections and only found a couple slightly loose bolts (none mis-instalIed). i then called the Midwest Customer Service office and that guy didn't know much more. He did say he thought it would stop the wheel oscillation in the unlikely event of a "mommyt" incident. He also denied knowing about that incident. I checked my installation and it was properly done. Not sure if i want the software upgrade if they can't tell me what it does!
Yeah I'm trying to verify that information as well. According to "the news", the recall affects all Sonatas manufactured from Dec. 11, 2009, to Sept. 10, 2010, but then the number and info fluctuates all over the place.
where did you go to verify ? Directly to the dealer or online?
I guess the dealer would probably the best way to figure out.
Online:
CarFax recall Database
I will stop by the dealer on Monday morning and hopefully they've seen this before and have a quick fix. I'll update afterwards.
With the Sonata being one of Hyundai's most popular cars in the USA, it would be very surprising (and a marketing mistake) for them to rename it as an i45 here.
Incidentally, on Hyundai's "worldwide" site it is still listed as the Sonata.
I did run it on your the CarFax link and came up as one in the recall.
Maybe the SE is not one in the recall. I have a Limited.
Have you checked to see if your dealer offers discount oil changes for customers? Mine does, and it is less than the franchise shops around town.
They both have a base 4 and a turbo 4.
Okay, thanks for that info. I purchased my Sonata from an out-of-state dealer and the closest one to me is still quite a ways out. Perhaps I should just buy a filter and keep it handy....
1. The Sonata is much cheaper.
2. The Sonata gets significantly better gas mileage.
3. The Sonats has more power. (The non-turbo Regal reportedly lacks sufficient power.)
4. The Sonata weighs much less. The Regal is designed to accommodate a V6 and it is, in my opinion, overweight at 3600+ lbs.
5. One thing I dislike about FWD cars is excessive font-end overhang. To my eye, the Sonata has less overhang than cars designed to accommodate a V6 (including the Regal).
5. I love the [somewhat overdone] chrome exhaust tips on my SE. The non-turbo Regal has frumpy hidden exhaust tips.
Don't get me wrong. I think that GM is producing some nice cars these days and I hope they survive and prosper. But the Sonata just made more sense to me.
Long story short, sounds like a simple glitch, though it was a nerve-wracking couple weeks before this was fixed. While it could have been handled a little better the first time in, HMA and the dealer did what they could to remedy the issue. This is the fourth Hyundai in our family and the first problem we've had, so I'm willing to roll with it as part of buying a very early version of a completely new model.
