2010 Chevy Equinox Problems
191012141547
    gmcustsvcgmcustsvc Member Posts: 4,252
    Hello Ragtop262,
    Just wanted to make sure that you did get some assistance with your concern. Thank you for getting back to me.
    -Mariah GM Customer Service
    ronwelronwel Member Posts: 57
    I'm having the exact same problem. I placed an order for wiper blades with my local GM dealer, and was told all three are on back-order. Yesterday I got an email that they had the left side in (drivers) but the rest are stilled back ordered. I've been trying to get blades for months now.
    Really concernening that GM can not stock wiper blades for their own cars. They are a very important safety device.
    I guess I will check into the after-market part you posted about.
    rockiesfanrockiesfan Member Posts: 3
    "Sticky Steering"....I'm so glad I found this site and others experiencing similar problems. I think my wife thought I was driving drunk when I first noticed the steering issue. You have to physically jolt the steering wheel to keep the vehicle from tracking straight down the highway. At highway speed, this is extremely dangerous. I did take my Equinox into the dealership and they're replacing the steering module and powersteering pump (appointment on 9/20/10). Will post again if I notice a change. This is the 3rd time I've had to take our new Equinox into the dealership and am extremely disappointed in GM. The cruise control has problems downshifting at highway speed, we've had problems with the airbag light continuously coming on, gas mileage not even close to what is advertised, and then the radio/air control module problem that was recalled. Cannot wait to get rid of this vehicle.
    hwytimehwytime Member Posts: 1
    My 2010 Equinox has stalled 3 times, last time was with 18 wheeler coming down the road...not fun. Dealer says no ck engine codes to trace and really cannot re-create the problem. I mentioned the ecm relay replacement on your car and that did not seem to register as something they needed to do. Any more advice out there?
    Hello Hwytime,
    Have you taken the vehicle to a different dealership for a second opinion? Does any codes come up on the DIC when this does occur? Thank you,
    My 2010 Equinox finally stalled this morning on the way to work. For the past yeay...whenever i have come to a stop, and the car was warmed up, it would almost stall. The RPMs would drop...the car would shake, and then it would fight back and run again. It would do this every 10 seconds. It is almost as if the idle RPMs have been set too low. This happens mostly in ECO mode, with the A/C off...but I did have it happen with ECO off.
    Today...it finally stalled when I was wating at a stop sign. The RPMs dropped...it tried to fight back, then it died.
    I am going over to my dealer nwo to see what is going on. I only have 17,100 km on the car. THis seems to be an issue with this engine.
    jimbo1000jimbo1000 Member Posts: 1
    I have a NOX with just under 10k, mine seems to do the downshift thing at 34 mph and has since it was delivered last November. When I took it back to the dealer for the first oil change in April 2010 there was the problem of the center console had gone dead and the heat and cooling controls were dead, the car was still driveable. The dealer reprogramed some module, there was a recall on this, but he preformed 3 other service bulletins and not a problem since. I like the NOX real well.
    kristy8kristy8 Member Posts: 72
    OK ........ WHERE"S THE UPDATE???????
    it's almost the end of September.
    wallyuwlwallyuwl Member Posts: 166
    "My car also bucks at low speeds and feels hesitant and down shifts wierdly I mentioned all that to the dealership
    and he said "I bet it's all related"???????? "
    No, it isn't all related. The engine issues (pinging/knocking), and downshifting issues, are different.
    jsganzjsganz Member Posts: 8
    Yeah, I noticed the exact same thing on my 2011. The actual temperature outside can go up 10 degrees and
    the display stays on the original temperature that was shown at start up early that morning. If I drive down the road a couple miles it gradually climbs but still isn't accurate. The display gradually went up to 75 degrees, but it was really 85 outside!
    tanastanas Member Posts: 8
    edited September 2010
    This is my story so far: (4 cyl. 2010 equinox)
    When starting the engine (not always) I can hear a short sharp noise coming from the engine
    Dealer service department solution:
    - CAM phasres replaced and R&R the CAM actuator solenoid checked for debris (no debris found)
    - CAM positioning actuator (exhaust) replaced and checked for debris
    After that the noise was gone!
    Two months later:
    - When accelerating on uphill from 0 mph, between 1500 and 2000 rpm I can hear a repetitive clatter (knocking) noise coming from the engine (left side). The noise is louder when the AC is ON.
    - When starting the engine (not always) I can hear a short sharp noise coming from the engine. Same problem as two months before. I think came back at the same time when I noticed the other problem.
    First visit at the dealership service: They drove the car and said that they couldn't hear any noise. I got in the car with one of the technicians and after the test drive he agreed that there is a noise coming from the engine area and suggested replacing the AC pump, although I knew this was not the problem.
    AC pump replaced, I took the car and when I got home I heard the same noise again.
    Went back and the technician suggested top engine cleaning.
    Cleaning completed, and according by the service manager they drove the car and the noise was gone.
    BUT when I took my car and went home the problem was still there.
    Back again and when I got there they were upset because I was back with the same problem and almost blame me for the problem. We got in the car (me and the service "manager") and drove the car so he can see that I'm not the liar. He remained without words.
    After that he said: "I will call GM to find out what is the problem but now there is nothing I can do"
    Next day :
    The service manager said that GM is working on updating a software to recalibrate the spark plug which sounds good (for the pinging noise), but I don't think that that kind of noise at certain rpm can came from the spark plugs.
    The engine works differently (worse) than 6 months ago, sounds like a diesel engine, is much louder and mpg is getting worse (was pretty good 6 months ago).
    I have been having trouble with hard shifts between 30 and 40 mph.
    It becomes more frustrating.
    Saying sorry all the time is not helping at all
    ktreecektreece Member Posts: 6
    I also hear a sharp noise sometimes like the starter is scraping or something.
    I have posted on this one twice. Took it to the dealer and they reflashed the ECU worked for about 2 weeks and started doing it again. I have decided that if GM does not come up with a fix before March of 2011 I am getting rid of my Equinox. Better hurry up GM or this will be my last GM purchase ever!!!!!! My father retired from GM so considering getting a GM rep. involved soon.
    colt_herocolt_hero Member Posts: 107
    Wonder what GM is saying to this dealership service department that is (allegedly) changing parts left and right, THEN calling GM "to find out what the problem is".
    As for the "sharp noise" when starting the engine, have you tried starting the car with someone underneath or looking over the top of the engine while turning the key? Have you tried changing the motor oil and running it through a screen mesh (much like what is done to catch a kidney stone)? Sounds like a metal to metal noise of some kind. Misaligned starter motors can cause a metallic shriek at startup when they engage the flywheel improperly, but I doubt that would be your problem on a brand new vehicle. I think this happens on a used vehicle where the starter motor has been replaced but a required shim plate was left off.
    I'd be screen-filtering the motor oil to see if there are any fragments in there from the factory.
    elli2elli2 Member Posts: 15
    I am new on this board, but happy to have found it. I have had my 2010 Equinox LT2 for about 6 months and basically like it a lot. My biggest complaint is the jerky transmission and a hesitation problem. I notice it the most when I'm going reasonably fast (over 40) and then have to brake, like when traffic slows down. During the braking, if I then have the opportunity to accelerate again, the transmission often will hesitate for 1-2 seconds, and then the car bucks forward. This also happens, for instance, when I'm on a highway and want to change lanes if I get behind a slow driver. I slow down a little, and when I go to accelerate to change lanes, it hesitates and then bucks. The hesitation has almost caused an accident for me when it hesitated as I was attempting to change lanes. At first I thought that this hesitation problem was "just how the car is," but after reading this forum, I'm thinking that this is not normal. Have others experienced this? Is there something Chevy can do about it? I have not taken the car for anything but an oil change.
    Another transmission thing: I also find that when accelerating up a highway hill at a reasonably high speed (60+) the transmission whines really loudly until I release my foot from the gas.
    brjubrightbrjubright Member Posts: 2
    They supposedly rolled out the "Fix" for the knock, but consequently there induced more problems as well. Since updating the cals on the ECM in my 2010 equinox, I know am getting "Service Power Steering Soon" displayed in the DIC, and my "ECON" switch is indicating a high voltage situation which in turn sets a DTC and the CE light comes on. Up until this point I was really satisfied with my 2010 Equinox, but I think when and if its fixed this time, I will drive it directly from the Chevy lot to the KIA dealership. I am really fed up with Government Motors and there lack of customer focus.
    Yes - I as well have experienced the "bucking" problem with the transmission.
    jgjb2499jgjb2499 Member Posts: 2
    When was this update released, I was just at the dealership yesterday for the "spark knock" update and they said that nothing had come out yet, but that it should be soon?
    I just picked up my car from the dealership where I had them look into why my car was stallling. They replaced the exhaust acctuator and so far it is running a bit better. Will keep everyone informed....
    Call from a GM customer specialist (more like a middleman) today:
    "Spark knock" update in the next 6 - 8 weeks
    If you ask me I don't think that something will happen before New Year
    Last fall they approved a new transmission calibration in late Sept. I got it from a GM engineer literally the day after it was approved. It started to go into production vehicled supposedly the week following that. It was supposed to be available to dealers by late October. If you look at the technical service bulletins, this particular TSB (for the tranny cal) is dated as being available on Jan 1, 2010, about two months after it was supposed to be. That is, of course, if the date is right. I have no way to know if it is or not.
    I'm not worried about the knock sensor update, though I'll probably get it when it comes out. It is fine using premium, and Shell V-Power has way more detergents in it to keep injectors and such clean. So I'm OK paying the extra $4.50 per tank for that. Replacing bad injectors (which is necessary withing 100k miles if you use bad gas) is very expensive (often $1000 or more).
    What I REALLY want is for them to come out with another tranny calibration that makes the thing drive normally. The six speed in the Malibu, for example, is silky smooth, but it has a normal calibration. The downshifting characteristics, (including the "bucking", as some have called it, at times while downshifting) are the only complaints I have about this vehicle.
    Update on the sticky steering. GM replaced entire steering rack, module and pump and so far..........no sticky steering. Airbag light continues to come on and GM is having trouble locating a new part (airbag sensor). Had rental car for over a week while they worked on steering and tried to fix airbag light issue. Was pushing 2 weeks when GM called and had me come pick up my nox until the new part arrived. I also reported that transmission is not shifting correctly on interstate while cruise control is on. The 4 cl is having trouble upshifting into the higher gear after passing or cresting hill. They drove and couldn't replicate. Anyone reading all these posts, looking into buying one of these, heed the warnings. DO NOT BUY THE EQUINOX.
    nbildannbildan Member Posts: 4
    hi ,i am from canada i have this noise from the engine too, the dealership said is normal for this car ,i do not trust them, this noise sound like problem engine , i see so many people in this forum having this kind of problem .
    Anyone with this problem ,fixed the car yet?Did the GM came with the software that they were talking about?Can some one please, reply with any advice or info.... Thanks.
    Hello Nbildan,
    I apologize that you are experiencing a concern with your vehicle. If you don't trust your dealerships opinion you could take it to another GM dealership for a second opinion. Thank you,
    I have already just this past week had my update done......it was done so
    unofficially, according to my dealership the official update to the software for the misfiring spark is out in November. I had mine done because I had made so many complaints to the consumer action council here in my state and I think they wanted to shut me up and get rid of me. I have to say since I had the update done the noise is very, very, very minimal and I hardly notice, I think I may have heard a slight knock and I had also went back down using the lower grade fuel. I also have to add since the update was done it doesn't seem to down-shift as much and less bucking. We shall see
    though I have not opened it up on the highway yet since I got my nox's back.
    I had mine done already unofficially, the official update is due out in November
    I have to bring mine back in November again for another update, since the update so far so good!
    I wanted to keep you posted since we have spoken before regarding the spark/knock problem.....I had my software update this week, Now the dealership said pretty much I had the "unofficial update done and I will have to return back in November for the official update" whatever they did it definatelty is running better and so far I haven't heard the secondary noise that we have spoke of in the past. I did mention that it down-shifts weird( before the update was done ) it bucks and also vibrates like crazy......have you experienced the vibrating? He said well lets see how it runs after and let us know. Since I just got it back this past Tuesday I really have not had a chance to "really" test out the car and have not opened it up on the highway to truly to test the downshifting and the bucking/vibrating. BUT i do have to say the noise that was there is gone so far...I thought I may have a heard a slight one knock? but that's debatable. I also went back to the lower grade gas. So far so good...let's see
    read my post ....we have had the same problem,
    I had my update for the software, next update is in November
    I went through the same hassles as you....keep on them :shades: :)
    I had my software update for this problem done already Unofficially
    the official update is coming in November., maybe I was their guinea pig
    Hi
    I have too dealt with this same issue...I have been complaining and complaining and finally the dealership had just completed the "unofficial" software update for my nox.
    The official update is due in November
    POSTING ON MY OWN POST
    *************UPDATE*************
    had the software update done
    so far so good...according to
    the dealership the official
    update is due NOW in November :confuse:
    thank you for your info kristy8 but i like to see MARIAH GM CUSTOMER SERVICE what is her opinion, did she know about this software update ????? thank you
    i complain to GM canada costomer service and they said they will do a research on this matter i have with my dealership , but did not told me anything about a update in a softwre ,i will be happy to have my car fix and end this engine problem ,like you kristy8 thank you
    Well when Mariah and I conversed through via email, she also informed me that the update was due out soon, and that was back in September. GM made a statement to my dealership that the software would be in fact ready late September. So I waited patiently and around the 28th I called back the dealership, no update. called my local consumer action council where I have a file pending with GM...The consumer action council contacted the dealership which in return got the ball rolling for me. Dealership called the very next day and scheduled the update. It took them several days to load the software into my nox and I just got it back this past Tuesday. Now the dealership said this is an unofficial update and that the official update will be in fact ready for November, which they said I will have return for that and leave again. I don't know what what actually was done or performed but the knocking....we'll so far so good. I also mentioned to the dealership before the update was done that the nox's vibrates at certain speeds and feels hesitant and bucks and downshifts odd, they seem to think it's al;l related to the timing. However after mentioning this on this post site others on this post from what I have gathered that it is 2 separate issues, so now I am hoping that GM recognizes the other issues and makes the corrections. I have a 4cyl base model.
    I think but I don't know for sure that others with a 6cyl have experienced tranny issues, I wonder if the 4cyl has the same tranny system as the 6cyl. I which I knew more in the car area.
    kwnoxcakwnoxca Member Posts: 8
    edited October 2010
    although I do not hear knocking (due possibly to the low mileage on my nox...just over 7k km), I do find vibration issue, especially when speeding up from 50 - 60 km/h on freeway ramps. the vibration lead to resonance on instrument panel...very annoying :mad:
    hi kristy8 ,i am glad that you have a good news and they updated the software for you .Could you please, gave me the phone nr. of your dealearship from USA because I would like my dealership to contact them and resolve my problem also.
    I have an appoitment on Wed .oct.13 ,and I would like to have the phone nr. by that time ,my dealership workers dont want to listen to me so I want them to talk with your dealership to convince themself that are other people with this kind of problem.
    Maybe they have 1800 nr.Thank you very much .
    Hello nbildan
    I posted the info..but it got deleted
    edmunds site said all I can tell you is the name
    of the dealership.
    Commonwealth Motors, MA
    Sorry I can't help you further
    e2137e2137 Member Posts: 8
    Hey,
    I'm also having issues with my audio quality. I can be driving with the radio turned off and I get static coming from the left channel speaks. During radio and music play sometimes the left channel will get static and then go in and out. I have had the speakers replaced but the issue keeps coming up and my dealership is completely useless on just about anything.
    kynoxkynox Member Posts: 18
    I`m having same issue except it is coming from the right side front . It sounds like someone playing a Kazoo. Took to the dealer and it could not be replicated in the shop. It immediately returned when I got back out on the road . Turned the radio off and it continued to make the noise. I now wonder if it is not a vibration resonating thru the speaker opening. I have to return for a window motor replacement and will take it up with them again. First problem with my NOX . 12000 miles and 31mpg on the road. 24.5 mpg combined .
    dmazzonedmazzone Member Posts: 20
    Kristy8, did you have your update done at Commonwealth Motors? I am experiencing this as well and I live close by to them where I could have mine taken care of. Are you happy with the update? Thanks
    Diane
    Was the noise like a whinning noise coming from the right side when you go over 20 MPH and comes and goes. If it is, I had the same issue and it ended up being the chain tensioner which had a bulletin out on it. Replaced it and the noise went away. It was a very annoying noise, they heard it but took awhile to diagnose it. Thanks
    Diane
    Diane....... Sounds alot like what I have. It gets louder as you increase in speed and less when you decease in speed. I certainly will bring up the issue when I take it back in. Thanks for the info . I will take it with me.
    It definitely could be a vibration noise resonating, it seems to be worse over a rough road or bumps. I was also reading online it could be a probably with the speaker not being grounded properly. Let me know how your next visit goes, i'll keep you updated on my progress. I'm going to make them replace the stereo if they can't figure it out because this is supposed to be an 8 speaker premium stereo package, this noise is unacceptable.
    tuck9799tuck9799 Member Posts: 2
    Hello everyone. My wife and I purchased a 2010 'Nox with the 4-cyl last December. We love it. The only issue we have is with the "pinging/rattling" that everyone here is describing. After researching the posts here I found the one from "kristy8" about the "ECM flash" service at Commonwealth Motors. I looked them up and contacted them right away. The gentleman in the service department knew exactly what I was referring to and had some interesting information. He stated that they went as far as having a GM Engineer arrive to deal with the issue. All in all, the engineer told them the 4-cyl Equinox is set on the limit of its ignition timing to maximize fuel economy. In doing so there will be a point of engine operation where pre-detonation will probably occur. In the case of our vehicle, it occurs between 1500-2000rpms. The gentleman proceeded to tell me that the GM Engineer did in fact re-program the ignition timing in the ECM ....... the noise disappeared. There is a downside though ...... loss of fuel economy. The GM Engineer also went on to tell them that any kind of top-end cleaning or other services will only mask the symptoms and they will eventually return. Switching to top-tier gas has helped a bit in our situation. Our fuel mileage increased 1-2 mpg on 87 Octane from Shell and/or Exxon. As long as there is no more than a .20 cent difference between top-tier and "bargain" gas, and the MPG increase is no less than ours, you break even (not to mention the increased detergents in top-tier are beneficial). Moral of the story: Live with the noise or get it re-programmed and lose fuel economy. I hope this helps anyone that is experiencing the same issue.
    e2137.........The window motor came in. I am returning to the dealer today for install. Will take up the noise with them again. I will post with a update
    This most definitely helps. I live not far from Commonwealth Motors and my car was also purchased at the same time you purchased yours. I didn't buy it there, but I know I can have it serviced there. I am willing to sacrafice 1-2 MPG and not have that noise anymore, because I was using the 93 octane so I wouldn't have to listen to it and that was almost 30 cents more per gallon. Thanks so much for your update.
    Hello dmazzone. I think you might have misunderstood me a bit. We did not have ours re-programmed. I was just giving out the numbers that we found on our 'Nox when we switched over to a better quality fuel, so I cannot speak to the exact number of MPG that you will lose after the re-program. As for you wanting to get yours re-programmed; I am not sure if it is something the dealership can even do. As I mentioned in my previous post, they had a GM Engineer come in to deal with it. If the dealership is in fact able to do the re-program, please let all of us here know how it went and what kind of fuel economy you lost.
    Took the NOX in Thursday for window motor and noise. We have to drive about 65 miles one way to dealer. Could not replicate the noise I was having in the right front door going there. We took it for a test drive and still could not replicate the noise. I asked them to remove the door panel and check that everything was tight and nothing was in there that wasn`t supposed to be. Everything was as it was supposed to be. Needless to say without them hearing the noise there is not much they can do and I understand that. We discussed several variables but came up with nothing concrete. Will wait until it gets worse . The only thing different about the first time I took it in and yesterday was the temperature . We have noticed that it doesn`t make the noise when it is cool out. So could it be a expansion issue or heat buildup under hood causing it? Time will tell. Sorry I couldn`t be more help.
    roho1roho1 Member Posts: 318
    Where is this infamous dealer? Is it just coincidence there are so many near that dealer here?
    All I can report is that my '10 Nox 4cyl. is running smoothly after 6 months with no issues what so ever. (knock on wood)
    I completely understand, it's very hard to replicate at the dealer and some days I will barely hear it but other days it's like a crazy kazoo coming from the speaker area. Since I had the left pillar speaker replaced for a second time, so far I only heard it a little bit once or twice but the fact that i'm hearing anything other than music on a premium stereo package is unacceptable. I'm going try something new and try to record the sound using the video camera of my iphone, it picks up sound really good in the car and then i'll play that for the dealer to see if it helps them at all. Either way i'm not giving up on this, any noise other than music is completely unacceptable. I'll keep you updated on any progress I make. Thanks for your update.
    tarverleetarverlee Member Posts: 5
    Hello everyone. Have a few issues with mine. Remote start doesn't seem to work right. Could be a fuel issue but the dealership has twice told me nothing is wrong with it because they can't duplicate the fault or get a fault code. In the mornings, I try to remote start and it doens't start and occasonally hangs and turns over for upwards of 10 seconds and then dies. Not good for the starter. I even have video footage and they said it wouldn't help them out a bit. Im going to get some more video footage and then go see my salesman and let him have it.
    Secondly, Combined i'm only getting 18.5 or so combined gas mileage. I have about 900 miles on it. It has NEVER said more than 19.5. I would greatly appreciate anyones opion/insight.
