Mazda CX-9 Brake noise
Bought a new CX-9 GT AWD on 18 Dec. Love it so far.
Noticed one small (?) problem with the brake. Say I am at a complete stop in Drive with brake pedal fully pressed. As I start to release the brake pedal, I hear a audible "groaning" sound from the front of the car. The same sort of symptoms typically found in older cars that need some sort of brake repair job.
Any idea what the issue might be? Is it just some mechanical component that needs to be "broken in"? Anyone with the same experience?
It seems like some parts of the brake is not properly lubricated.
Take it to the dealer if you can consistantly reproduce the noise.
The warranty on brakes is ONLY 1yr/12K miles (not like other parts).
1) When you press the brake pedal, there is an audible "soft clicking" noise that appears to be coming from the brake pedal itself, or somewhere in the front of the car. I'm not sure if this is a problem because my 2000 Toyota Camry brakes produce the same soundd. The Toyota guys repeatedly told me its not a problem. I had left it at that because its heard only when the surroundings are quiet and it was not a safety issue. Anyone else experiencing the same kind of noise ?
2) I too am able to hear the groaning sound when releasing the brake when the car is stationary.. not normal and will talk to the dealer. Hopefully its a minor issue ..
jbhatra ,vikasa,
Please let us know how your problem was resolved.
Every vehicle has that sound, just a matter of how noticeable it is.
Nevertheless I am taking it to the dealer this afternoon and will report back the findings. Please share your findings as well.
ceric,
Thanks for your response, appreciate your posts on the forum!
Do you think i should take it to the dealer to be checked?
After a car wash, the first few times you hit the brakes, they make a groaning sound, which sometimes sounds like the grinding that you describe. The sound goes away after a few minutes of driving, so from a layman's perspective I guess it could have something to do with water over the brakes ?
Ceric - any thoughts ?
What does the dealer mean when he says its a normal noise but he can "take care of it outside the warranty"
Take care of what if he does not acknowledge there is a problem ?
Sorry, just a bit confused when I re-read your post.
Or maybe I am giving him too much benefit of the doubt and should push more.
To be honest, I had a 1-month all-you-can-eat car washes deal at a local shop so I used to keep washing the car especially after all the bad weather we had in the Northeast and I guess I was noticing the noise more than I would otherwise have. :-)
The dealer claims its not a safety issue, but can't tell me what is causeing it. First off, I dont think it is brake related. It only happens when i go forward and aren't accelerating.(ease off gas) to me that would suggest something in the drive train. Since they dont know what is causeing they noise, pretty hard to define as not being saftey issue or not, although im sure it probably isnt for now. But any squeak means something is rubbing and grinding and goes away when heated up enough from the rubbing. That isnt good and means wear and tear on something.
Anyone else have this squeak when leaveing home or work after vehicle sits for couple hours?
This shouldnt happen to this new car..
U.S. probes Mazda CX-9 for brake problem (Detroit Free Press)
"The agency says people have complained about increased brake pedal effort and reduced brake effectiveness. Some have heard a hissing noise when they step on the brakes."
There's a TSB from Mazda on "brake groan" --
Bulletin No.: 04-004/11
Last Issued: 04/21/2011
Subject: REAR BRAKE GROAN
