No, it isn't...!
How would YOU go about designing a brake over-ride system that does not interfere with those times the driver might well intend to closely overlap braking and throttle? Then there is the company that claims to have had brake over-ride for many years. I don't remember the exact design wording but I do seem to remember they made provisions in the design for intentional use of the brakes and throttle simultaneously.
a) The throttle opening is greater than 1/3
b) Vehicle speed is above 5 mph
c) Brakes are applied firmly
d) The accelerator pedal is applied before the brake pedal
So, in the Edmunds test, we have checkmarks beside A,B,C & D. If the brake over-ride feature was installed in the vehicle, why would the test results under full throttle show a 25%+ longer braking distance?
Also, when you read reports that Toyota purchased suspect vehicles, and along with the floor mat official recall delays and refusal of access to EDR data at first - just makes you wonder.
I agree, and you do make a valid point... in that Toyota's resistance to issue recalls/repairs initially suggests a company that is more concerned with profits than its customers and their safety.
And, there are many other issues besides UA that just haven't gotten the same publicity.... Corolla electronic steering issues, Prius HID headlamp failures, etc.
IMO, there's little question that Toyota's image is tarnished due to these mis-steps, but unless the company is run by complete idiots, management would certainly be able to figure out the test could be easily duplicated....cheaply.
All one needs to do is find a used late model Toyota without the over-ride feature , install new rotors/pads, and off to a flat stretch of road he goes...
Invest $20K or less , demonstrate Toyotas are death traps, and sell your story/test results to the highest bidder.
A great way to make a living, if one can get the work...
Neither you nor I am designing anything. Its already designed and implemented, and the specifications were shown a couple of posts back.
With CC engaged the engine might still be operating at WOT right up to the instant the brake light switch circuit closes. Without CC the throttle will likely be fully closed once your foot reaches the brake.
Now listen for the expected level of engine noise at the 45-47 second mark.
http://www.insideline.com/toyota/camry/2010/2010-toyota-camry-stuck-throttle-bra- - ke-test.html
In the first case we must assume that the gas pedal is fully depressed but it is likely the throttle is far from wide open, maybe as little as 10%. Yet we hear LOTS of engine NOISE.
The engine is operating totally without load so the rev limiter would be preventing the engine from WOT, probably via the DBW system.
In the second case absent some sort of BOS the throttle would have been WIDE OPEN with the engine RPM being limited only by the transaxle torque converter stall point, 2,000 to 3,000 RPM. No induction noise even...?
This 2010 Camry had a BOS system installed, puzzling part is why Dan Edmunds did not note same.
http://support.edmunds.com/contactus.aspx?type=error&altref=http%3A%2F%2Fwww.edm- unds.com%2F
https://www.ideas.edmunds.com/Page/Home
As for busiris replying to me:
"Invest $20K or less , demonstrate Toyotas are death traps, and sell your story/test results to the highest bidder. "
I was hoping NASA would do that for RARE UA cases with at least 200 times $20k - but it appears to be a poor job just on the basis of the vehicles and pedals they selected - and not using MISRA for computer code checks.
I suspect the floor mats + driver inability to cope with the emergency is the reason, and in some cases, pure driver error.
I do however, think that malfunctioning cruise control does happen in cars, but that it is easily shut off by tapping the brakes in all cases.
So I guess I'm done with hashing this around personally. It's been most enjoyable sparring with everyone and exploring all the possibilities.
Naturally I know that some of you are not satisfied, so carry on. Should I see anything that re-opens the case I will let you all know!
Shifty, Visiting Host
And if the brake light switch malfunctions, then what...?
How many of us are so inured to "tapping" the brake to shut down CC that in a panic situation if it didn't work would we know to resort to the CC stalk...?
2013 LX 570 2016 LS 460
On I90 in ID I would often shut CC off as I was a bit nervous about entering those mountainous terrain curves with the CC set at a fairly HIGH speed.
Lack of being in control, if you will.
So I modified the system in my Porsche C4 (DBW) such that if I put foot pressure on the gas pedal the CC goes into "neutral" mode. Once I release foot pressure the CC automatically returns to normal operation.
So now "I" can drive those curves even above the set speed if I wish but be much more comfortable that if I want/need to let off the gas slightly the car will instantly respond.
I'm it total agreement.
More and more, at least for most rational examinations, it appears that the UA ship has sailed...
The nature
There are two fuel-air supply paths in a modern vehicle. One is the main path including the throttle and fuel injectors, which are controlled by the vehicle computer and gas pedal, and the other is the Evaporative Emission Control System (EVAP), which is controlled solely by vehicle computer. The second fuel-air supply path is ignored by industry so far in investigating the reason of SUA. The EVAP system deserves a careful examination as a possible cause of the SUA, because existing vehicles lack an effective system to monitor the functioning of the EVAP system.
In a typical existing EVAP system showed in Figure 1, the gas vapor is temporarily trapped in the Charcoal Canister, when the vehicle stops or works in a condition that is different from the predetermined criteria. When the vehicle is running in a ‘good’ condition that fits the criteria stored in the vehicle computer (PCM), the PCM actuates the Purge Solenoid Valve, and then the trapped gas vapor is sucked by the vacuum of the intake manifold into the engine and is burned there. By design, the EVAP system has serious potential safety problem, That is, if the liquid gas in the gas tank enters in the Charcoal Canister for whatever reason, the EVAP system will automatically supply the engine with highly dense gas-air mixture once the Purge Solenoid Valve is actuated, and then the vehicle will suddenly experience unintended acceleration, ineffective brake and other unwanted consequences.
The nature of the unintended acceleration problems is the defective design of the Evaporative Emission Control System (EVAP) shared by the vehicles of all automakers. All vehicles have been required of equipping with the EVAP system since 1971. Therefore the SUA is a common problem for all automakers.
The Plausibility
It is plausible in realistic vehicle running environments for the liquid gas in the gas tank to enter the charcoal canister of the EVAP system. Following is a partial list of possible scenarios:
• People over-refill the gas tank, either intentionally or accidently;
• Vehicle experiences heavy bump;
• Gas tank is squeezed by accidents;
• Fuel in the tank expands due to the temperature effects, because there is big temperature difference between the outside air and the underground storage of gas station in some days and some places.
• The valves supposed to prevent liquid gas from entering into charcoal canister are broken, like the fuel shut-off valve.
• Other cases.
Both the vehicle computer and the driver do not know whether the liquid gas enters into the charcoal canister of the EVAP until the vehicle experiences the unintended acceleration. Since the unintended acceleration is so violent that many drivers cannot deal with it appropriately and promptly.
BY Zhongkui Wang
PHD in Syracuse University
Where does the air come from if the throttle plate isn't WIDE open...?
And with the throttle closed how do we produce enough heat via compression to ignite a DENSE mixture...?
Pour all the liquid fuel you wish into the intake manifold and thereby into the cylinders but absent enough air/oxygen the spark plug will not be able to ignite the COLD fuel.
Inject fuel into a diesel engine without the "throttle" FULLY open and you get NO "ignition".
Did you send the idea to NASA? - they reviewed a few others' ideas
If not contact the other group investigation of all UA causes
http://www.trb.org/PolicyStudies/UnintendedAccelerationStudy.aspx
They just had meetings last week but there is contact info
"How might such a rare event occur? The National Academy of Sciences panel heard one theory Thursday from Ronald A. Belt, an electronics expert who holds a doctorate in physics from the University of Notre Dame.
Belt, who works at Honeywell but presented his report independently, suggested that a kind of short circuit called a "latch-up" could cause a Toyota's electronic throttle to open and stay open - without the gas pedal depressed and outside the control of the vehicle's electronic control unit (ECU). Another electronics expert likened a latch-up to "a faucet getting jammed in the open position."
Lyons dismissed Belt's report via e-mail, saying Belt "admittedly guessed at the design of Toyota's ECU and, as a result, has made a number of incorrect assumptions that have led him to draw erroneous conclusions."
Philly.com
Take any +5 VCC volt logic IC (Integrated Circuit) and reverse bias the chip substrate via any input pin and the circuit will "latch-up", allowing the negative circuit current to flow continously until the negative voltage source is removed.
Provided the reverse current flow is somehow limited such that no permanent damage results then after a power cycle the circuit might return to fully operational status and remain so for the next 100 years.
Remember that I theorized that the Haggerty engine UA resulted from a short internal to the gas pedal hall effect sensor..? Look at page 21 of Belt's presentation.
As wwest said, Latchups (Single Event Latchups, or SELs) in general can be destructive or non-destructive, usually depending of the amount of current that can flow when the parasitic SCR is triggered. A non-destructive latchup goes away, or resets itself (the SCR is turned off) when power is removed. Destructive latchups permanently damage the device.
The more transistors we are able to put on a given chip size the more the parts will be subject to SEL due to such things as ALPHA particle radiation.
PING.....!
Back maybe 30 years ago Intel spend TONS of money on R&D trying to find out why their memory chips were so subject to SEF, Single Even Failures. It turned out to be totally random RADIATION effects.
So today my company only ships systems with FULL ERCC, memory fault error detection and correction. I am currently of the undestanding that even the "X86" cache memory structures now have "on-board" ERCC.
But what's to be done about, with, the random logic structures surrounding these processors as the geometry grows smaller and smaller...?
People ask why the "spat" of UAs and then nothing....strong storm on our sun???
http://www.usatoday.com/news/opinion/forum/2011-03-09-column09_ST1_N.htm
Lawyers for plaintiffs, particularly those involved in lawsuits want jurists who are going to be receptive to their arguments - malleable, to some extent. Engineers, scientists, and the like tend not to fit that mold.
That's why in many cases there is so much shopping around for the right venue in which to file a lawsuit, or to try and get a case moved to a more plaintiff-friendly setting.
As you know, there are three hoses connected with the charcoal canister of EVAP, one to the engine, one to the gas tank, and another one to the outside air. When EVAP purges the charcoal canister, the outside air will go into the charcoal canister and bring the fuel there into the engine. Therefore, the EVAP system can supply the engine the fuel and air simultaneously.
Your further feedback will be appreciated.
I sincerely doubt that the EVAP system can provide enough fuel flow for that effort let alone an A/F mixture close enough for normal spark ignition.
"The new report is a follow-on to similar research these experts conducted last year, which showed that cars were increasingly indistinguishable from Internet-connected computers in terms of vulnerability to outside intrusion and control. That project tried to show that the internal networks used to control systems in today’s cars are not secure in the face of a potential attacker who has physical access to the vehicle."
Researchers Show How a Car’s Electronics Can Be Taken Over Remotely (NY Times)
There are not many systems that are truly secure if someone has physical access to the network. Maybe something that comes out of NSA...
The history of security leaks shows that the weakest point is usually the human. The Wiki Leaks of all the state department cables is a good example.
Not just security, but design and quality defects. Rushing to stay on schedule, using the lowest cost parts and materials, plain human error, and disgruntled employees are major sources of problems. I think the 1 fictional character we all remember who helped turn a highly structured system into chaos, was in the book & movie - Juraissic Park.
In life it's not about IF something will fail; it's WHEN. The improbable and unplanned happens everyday; I still like the recent problem only-Mazda has with spiders; that caused them to have a recall.
To say that Toyota or NASA thought of all the possible failure modes that causes UA is statistically invalid. Like archaeologists they dug some holes in the Sahara desert where they thought they thought they could find something. And if Toyota did have some specific information, and did find something, they might never had made it public, and just fixed it. Several billion $'s will make people do unethical things.
Hope this wasn't the real reason for RARE Toyota cases that no doubt had to be electronics. I just changed my original SYNC password in my (great) 2010 Ford Flex as I haven't since I got it. It is a Microsoft system - darn. I accessed my account and it says there is an update to download from my computer and install it. More work for a non-GEEK. I'm having trouble setting up my new printer.
"History shows again and again how Nature points out the folly of man".
http://onlinepubs.trb.org/onlinepubs/UA/030311Kirsch.pdf
Last page shows that they found errors giving smaller than full throttle openings - they just couldn't find the cause of "large unintended accelerations".
Those smaller ones could explain many of the low crash incidents in parking lots etc. There is no reason why older drivers are misapplying pedals in Toyotas, but not in many others such as GM's that have had very very low numbers of cases per vehicle sold.
GM uses potentiometers. As expected, UA or throttle "issues" are extremely low even though the parts do "wear out" more often.(I'd consider a Hall Effect sensor that's giving bad data to be "worn out" as well, but I guess they mean breaking apart "worn out" for a recall)
GM uses potentiometers for the same reason Chrysler switched the Jeep from front CV's to U-Joints......CHEAP.....!!
But then it does take a decent design engineer, HIGH COST engineer, to come up with a good working Hall Effect sensor set.
A first year employee with a EE degree could design a foolproof system for a potentiometer by comparison.
Potentiometers provide a constant and easy to monitor voltage output. If it drops to zero resistance or goes to maximum and stays there, then they know that there's a problem. In simpler terms for readers who aren't up to speed on electronics and such, it would be like your circuit breaker blowing or shorting out and sending 240V throughout your house - either scenario is *instantly* known by the occupants every time.(no lights or every bulb blows out after becoming 4x brighter for 1-2 seconds)
The instances where the contacts are getting worn also give months or weeks of warning to the driver. This small-scale erratic and/or sluggish behavior (often without the driver feeling it yet) triggers the "service mode" of the vehicle with nearly 100% accuracy. Replace it and you're good for another half dozen years. Nobody gets hurt or killed, either.
note - CV joints are far less robust than U-Joints and cost far more to replace as well.
Today we use Hall-Effect sensors and optical encoders for rotational measurements. Heck, even 43 years ago when I was first getting started, we were using devices called synchros and resolvers to measure angular position. No, they weren't cheap - much more expensive than a simple pot. But the inherent reliability improvement was deemed to be worth the cost.
True, high-end aircraft systems and so on wouldn't use them, but then again they have proper designs as well, with multiple backups and fail-safes. A typical car apparently has only some code and a secondary sensor at best to verify that everything is OK. Given a half-baked fail-safe that isn't one at all, I'd chose the potentiometer based design or better yet a traditional throttle cable every time.
Last I knew there was NOTHING "mission critical" about a game controller...
Lowest common denominator insofar as cheap, CHEAP, CHEAP...!
