Like anything else, each car can be different like people. What may happen with some cars, doesn't mean it will be exactly the same for you. Best to check with Ford headquarters in Detroit on the ratings of your local area dealerships as to their quality of service😁. Like a draft pick In sports, dealers with good overall ratings with Ford seem to get first choice cars off production lines
4wd'd into the parking lot at work today through the pile the plows had deposited at the entrance overnight.
From across the lot I saw some snow sticking under the front fascia. Took a look under there and noticed some sort of air intake (???) I guess. It seems to be part of the plastic, under-engine, cover on the passenger side of the center of the lower grill opening and appears to maybe route to the back side of the engine?
I don't think it's an intake for the air cleaner as there appears to be one of those at the top of the grill. It doesn't seem like a vehicle sold as having snow-going capabilities would have something important hanging down there. Any ideas? Turbo cooling? Fresh? air? (I'd think "fresh" air intake would not be located facing the exhaust pipe of the driver ahead of you)
My '13 Escape has the HID headlamps along with the LED running lights, both of which (to me at least) look great with the "pure white" light they emit. However, it seems that the fog lamps are some sort of standard bulbs that emit the more typical off-white light that you'd expect from an incandescent bulb, and it makes it look a little odd when you have the fog lamps on along with the headlamps as the fog lamps and the headlamps are two very different shades of white. I'm wondering if anyone has found any sort of a replacement for the fog lamp bulbs that more closely matches the color of the headlamp bulbs.
Then just to add to my frustration the tailgate started to wear a hole through my bumper!!! Talked to my dealers body shop and determined the door is made incorrectly,(too big for the hole it must go in) and they would try to adjust it to fit it better so not rub on bumper. I then checked the other new Ford Escapes on the dealers lot and everyone is the same! NONE OF THE LINES FROM THE REAR FENDER AND TAIL LIGHTS LINE UP TO THE TAILGATE!!!!!
Just called the BBB and started lemon law action.
THIS!!!!, for a car coming from Ford!
Fog lights have a completely different purpose than normal lights; it may be intentional that they used the softer light, since a bright light in foggy conditions might actually make things worse. You are concerned with ascetics, but the lights have a specific use.
I don't know if this is the reason. I have not seen any articles or studies on this question. But I thought I'd mention it.
And be sure that your auto insurance is up to date, looking out the side window while making a turn...
Did you ever get the DashCommand or another app to monitor your gas mileage?
You had stated earlier that you get 28-32 MPG on the Highway but get poor city mileage on your short trips in hilly terrain. Sounds like that may just be normal.
Tonight I did a 21 mile round trip errand. Including my cold-start I averaged 31.0 MPG on the trip. Partly city, mostly highway, max cruising speed 62MPH.
2.0FWD
I don't consider it defect with the materials, just something to watch out for, and take care of when you notice it.
http://www.leftlanenews.com/in-pictures-the-10-best-selling-cars-of-february-201- 3.html
I couldn't resist...
Escape: 24,210 in Feb 2013 and 44,048 YTD
CX-5: 5451 in Feb 2013 and 16,695 YTD
I would like to hear from anyone who has a ford in dash defective gps that ford has fixed. I have been waiting for 3 weeks for ford engineers fix the problem, but no answer let.
I would feel better if no one has a defective gps. At least I would know that i'm the only one.
Lemon law states 3 attempt to repair a problem and one more chance by ford to repair the problem and you can apply for relief under the lemon law.
I was replying to someones post that said the engine had to be at a static comp ratio of 13:1 to be economical and more stuff.... It must have ended up in the wrong place. At 13:1 you would need to run methanol for fuel instead of gasoline.
My unit is 3.15(not the freshest software version), but the email reply from the scangauge folks is that it's probably not worth paying for an update, the vehicle might just not report this info.
Temperature wise, I can read Ambient temp, Coolant temp, Intake temp and Catalyst temp. These are the 4-temps that come pre-programmed. Others may be possible, depending on what is available from the OBDII port.
Not sure about Cylinder Head Temp.
I mainly got mine for reading boost pressure, but I really enjoy looking at dozens of other variables available.
I purchased 2013 ford Escape 1.6 Eco Booster but EXACTLY same issue with you. I dropped dealershop this morning but they said it is normal they have nothing to do.
Anybody has idea what can I to do for this issue?? :mad:
Today, I saw one more thing, though not related to transmission. My reverse camera did not show the "Active + Fixed" mode which I keep usually enabled. This happened after I had shut down the engine while in drive mode. My ford touch seems to be a bit buggy in some areas.
http://media.ford.com/images/10031/March13sales.pdf
So my question is, does anybody with an SE model have one of those illuminating rings around the ignition key hole?
Mine looks like there should be one there but it was ripped out.... Just want to confirm this with other Escape owners.
i'm conflicted about all these switches/paddles/levers.... on the steering wheel that obscure the view of the ignition and headlight switches, but I guess they are at least a little handy once I figured them out.
I certainly knew I was pulling a trailer, but the vehicle never strained at any time. Generally very pleased.
Also, after connecting the trailer lights and starting the engine, an information bulletin came up on the screen saying "Trailer connected, BLIS system is disabled". There was also an orange information icon on the dash, notifying me that the BLIS was disabled. Nice touch.
