Chevy Silverado/GMC Sierra - Owners hangout
Wish my truck would have an increase like that
Occasionally, around here, you see people that try it. Normally, their rear bumpers are almost on the ground. I would think it would severly screw up your truck. :sick:
BTW, both throttle bodies were trashed and black with gunk as I had checked and cleaned them when I removed them. Hadn't noticed any hp or mpg improvement with these expensive bolt ons.
kcram - Pickups Host
BF Goodrich sold the automotive tire business back in 1988, to a company by the name of MNA, INC.
NMA, INC also owns the Uniroyal brand.
That is why the recall of the Liberator also included the BF Goodrich and Uniroyal brands.
BTW - MNA stands for Michelin North America - Michelin owns MNA, INC - which owns the BF Goodrich and Uniroyal brands.
So your dad is right - Michelin does make the Liberator -
I have a friend with a tire shop that put me into these deans super cheap so I went for it. He said even at normal price, they're only about $425 installed/tax/everything. That's a steal for a 16" truck tire IMHO, particularly one that's this good. I've got about 8k miles on them so far and love them. They've burned about 1-2 32nds though, so I don't think they're going to be a real long-life tire. But I am hard on them and drive a lot of twisty roads so I go through tires quicker on most all my vehicles.
btenvy
Kind of like the Silverado - which is NOT manufactured by Chevrolet - it is made by General Motors - GM is the company - Chevy is the brand.
When the Walmart tire shop manager told me the Liberator was produced by Michelin I though he was giving me a line of BS - at that time Michelin did not even sell a 285 75 16 tire under the Michelin brand (BTW they do now). So I gave Michelin customer service a call on their 800 number. They confirmed that Michelin produces the Liberator for sale exclusively at Walmart.
I installed Rancho RS 5000s all the way around last weekend and am happy with the new feel. Still rides like a HD truck but the ride is a bit softer. I got them on-line thru Auto-Zone for under $200.
I gotta do the replacement step bars Westin gave me under warranty, the black powder coats didn't hold up so now will try the chrome plated instead.
Ray T. :shades:
I have almost 55K miles. I did the rear brakes last fall (early part). Think I had 48K miles? I just changed my tires back to the Mud Terrains and I inspected them and I have plenty of front pad left. The rears wear much quicker than the fronts. I am about even on pad wear now. I see doing another rear brake change before I do the fronts.
I put on new nerf bars last fall. Black lifetime westins.
Does anybody have any real idea if the new incentives will be better than the current $4000 rebates.
Malcolm
I am going to hope that better incentives come out next week, and hope to convince the dealer that my truck is worth more than $5000 with a new tranny and fuel pump.
--Malcolm
I am new to the form. Glad I found this place. I have a 2001 Silverado 1500, 5.3L. Bought it used 31 months ago, and she had 33,000 miles on her. Well, lately, a few problems have come up, and I was wondering if you all could help me.
First off, the gas gauge fluxes big time. I have heard that this is a sensor, and it would cost about $700.00 to repair because the sensor is part of the fuel pump, and that it is inside the gas tank. Is this true? Am I sunk on this?
Second, the transmission will occasionally jerk on take off. Not often, but once every few days to a week. What could cause this?
Any help would be appreciated. Once I wash the Bomber, I will post a pic of her on here. She is a beauty, even if I do say so myself
Hard to see many people willing to pay more for a used vehicle than a new one - so if you throw a $5,000 rebate on top of low (or no) interest financing on new vehicles then the value of 1 year old truck would be reduced. Which would ripple down through all the model years.
My impala didnt even have a cabin air filter from Sept to April.
I was up in your neck of the woods (Detroit) a few weeks ago.
I dont think you have one Honda
I also recall one truck with 285 75 16 - but they claimed to have a slight rub when they had a load on the truck & made a sharp turn. But this truck did not have stock wheels.
You will see two large steel rods about the size of broom handles (these are the torsion bars) - one on each side of the front end - on the end of the torsion bar you will see an adjustment bolt -if you tighten these bolts it raises the front end.
But before you start turning the bolts mark them with paint (or use a small drill bit to put a small mark) - put a dot on the bolt head and also on the frame so that the dots line up. Then you know the starting point - and if you mess up you can always go back to the exact set up you had before any adjustments. You will need to turn the bolts 3-4 complete revolutions - so you must keep track of how many turns you make on each.
Also a good idea to have the truck on level ground so you can measure from the ground to the frame on each side - but you will want to take a short drive between adjustments - gives things a chance to settle.
You should jack up the front end of the truck before you start adjusting - it will be hard to turn the bolts if you don't do this.
You would think that if you turn each side the same number of turns (say 3 times each) that it would raise the truck the same on each side - but that is not 100% true - you may need to adjust one side a little more / less that the other in order to be level.
I have always been told to get a front end alinement done after making adjustments - a good idea for sure - but if you only go up a little bit (1 to 1 1/2_ inches it is not always needed.
