Chevy S10/GMC S15-Sonoma: Problems & Solutions
the woods for the past 4-5 yrs. It's four wheel drive with a 4.3 liter v6 engine automatic trans
i put a brand new battery in it and plugs and wires.
i poured trans fluid in the spark plug holes to loosen the rings. let it set for 14 hours turned it
over put plugs back in then tried to fire it up and the darn thing acts like its not getting spark. Any
suggestions? Thanks.
Jason
http://www.autozone.com/servlet/UiBroker?ForwardPage=/az/cds/en_us/0900823d/80/12/a4/c9/09- - 00823d8012a4c9.jsp
http://www.troublecodes.net/GM/
or this 16 pin one:
http://www.troublecodes.net/OBD2/
There's no good proof out there that it extends engine life for normal drivers in normal cars despite claims you will here to the contrary. It MAY be true but there's no proof out there that very convincing.
As for "improving gas mileage", another claim you will here, all the testing I've read seem to indicate that you shouldn't count on more than say 3% better fuel mileage. If that's worth it for you, then there's a reason to use it right there.
Thanks for any help.
Ed
All the GM PCV valves are metal cased, so I can look at where the hose goes into the valve cover and tell if it has orifice or PCV valve.
http://www.autozone.com/images/cds/gif/large/0900823d8018aa8a.gif
Mike
Mike
http://www.car-part.com/index.htm
Good Luck
Canufixit
It's usually an air pump seized after sucking water in through the air intake.
My son was just told that his 96 S-10 2x2 4 cyl with 40K miles needs the clutch replaced. The quote for the work is 1000.00 which seems outrageously high to me
He had a problem getting it into gear. The mechanic said the fluid was completely empty. He said it may just be the hydraulics but he won't be able to tell until he gets the transmission in order to know for sure (450.00 for labor). Does this sound right? My son is 2 hours away at college and I don't know what to tell him to do.
Is it possible that he can just fill the fluid back up and drive it back here 125 miles so I can get it to a mechanic I know or would that be asking for trouble. Any help would be greatly appreciated.
