The Corvette may be a nice piece of hardware, but it has no relationship whatsoever to any other Chevy except the pickups.
The Viper's distance from the rest of the Dodge lineup is even greater.
ENJOY!!!!!!!
johnnycsk, enjoy the new CTS! If you like music and spend alot of time on the road, you'll love XM radio. FAR more variety than FM can ever dream of. And very few to no commercials. No more screaming cars dealer ads or endless blocks of commercials.
That's what I always thought was wrong with Honda's halo cars, NSX & S2000. They've almost nothing to do with Honda's other models: RWD, different platforms & engines. That has to have something to do with Honda not replacing the NSX in nearly two decades.
When talking about dealers and other geographically related subjects it would be nice if people included their approximate location such as city and/or state so we could get an idea of the distribution of CTS's. Also, I wonder who has accumulated the most mileage on their CTS.
johnnycsk congratulations on your new CTS. Enjoy your navigation system, it has some amazing features. I've had mine for over a year and I am still learning new things about it.
Remember you also saved adv. fees ($500?) and DOC fees using that GM cert...............geo
New Vehicle “Break-In”
NOTICE:
Your vehicle doesn’t need an elaborate
“break-in.” But it will perform better in the
long run if you follow these guidelines for the
first 500 miles (805 km):
 Don’t drive at any one speed -- fast or slow.
 Do not exceed 70 mph (113 km/h).
 Don’t make full-throttle starts, also refrain
from using the full throttle while driving.
If these procedures are not followed your engine,
axle or other parts could be damaged.
 Avoid making hard stops for the first
200 miles (322 km) or so. During this time
your new brake linings aren’t yet broken
in. Hard stops with new linings can mean
premature wear and earlier replacement.
Follow this breaking-in guideline every
time you get new brake linings.
Don’t tow a trailer during break-in. See “Towing
a Trailer” in the Index for more information.
How many times have we been at a dealership and seen an employee start up a car, pull onto the highway and put his foot in it?
Sure hope he uses it on a new CTS! Haven't seen him post either way yes or no.
Well at least 6 outta 8 got a new GM!.......geo
Gm says to call every day so if I dont get it by Wed will buy anyway.
Have $4100 MC credits plus $750 loyality and maybe another $500 and the GM in the driveway certificate from sonjabb. I will use it before Sept 2!
BerryCherry
I think there's a fair consensus now that you should NOT 'baby' an engine during the first few hundred miles, as the rings depend on compression pressure to establish their wear pattern and if not adequately loaded they may never seal properly. In other words, not sustained full-throttle but don't putter around at 2000RPM all the time either.
As for the brakes - once again, you may not want to use them too hard at first but don't be too easy on them, either, as you then risk 'glazing' the pads and not getting full grip out of them.
As of Aug.1 employee/family deals can only use/get 1% towards purchase instead of 5%. BUMMER!
Not sure about that cert. deal tho. !
Don't forget to tell the dealer if you have the "OLD" GM card.....Or else they will limit you to $1500 max. I believe.
Berry sure you don't wanna save 7K and get that base one with the 3.6 for under 30k?
Don't forget that GM loyalty bonus too !
At least your gonna use it ! Sorry Red and others !
There are really two questions. One, will the CTS-V be gross margin profitable? Two, will its profits generate an ROI in excess of GM's WACC or internal ROI targets. My guess is that in the current environment, the car would never have been built without the answer to question one being Yes. As for question two, that's much harder to judge without access to proprietary information.
a) The M5 was built on the line at Dingolfing with the rest of the E39s, the need to 'deck' the car without slowing down the line was why it uses the same exhaust manifolds as the 540i (reputedly costing ~25HP.) The engines were hand-built at Garching.
b) If we assume CTS-V pricing at $48K, that's realistically $16K above base CTS pricing and $25K less than E39 M5 pricing.
c) I'd guess (and this is *only* a guess) that the net cost difference between the base 3.6 CTS and the CTS-V is around $10K. There are a lot of model-specific parts in that car, some (wheels/tires, brakes, final drive) are going to be much more expensive because they're more costly designs, some (exhaust, cooling, subframes)are going to be somewhat more expensive because they're beefier, and everything will be pricier just by virtue of low purchase quantities.
d) The LS6 is quite a cheap engine to build, though that 3.6 is apparently cheap enough to build for GM to use them in US$20K Aussie Holdens.
are costing about $3000 more.
If the old retail rule of 4 times cost is used that would account for a $12,000 difference.
But I am sure the V will have a higher level of equipment vs. a base 3.6L.
I am not factoring any development costs into the 3K, just the cost difference of substituting different parts.
A great price.
BUT now I know how they make money, at the end, before I wrote the check,the FINANCE officer wanted $2000 for a 3 year warrenty extension, still 50000 miles, and $800 for a teflon coating, then $800 for LoJack.
I said NO for all the extras. Later might consider Lojack.
California apparently charges tax on the credits/rebates, not sure why. Is this common?
Some large LA dealers only charge invoice plus $150 on the 2004 CTS, but not sure what invoice it was, probally had advertising in it.
Spent the last several weeks going through the LA/OC dealers on the 2004 trying to find what I wanted. Looked at a site similar to GM Buy Power but can look at the 2004 like the dealers.
By this week I found many of the ones I liked were sold, and dissappeared from the screen. So I got desperate today and found a local dealer who had just got one in that I liked, then bought it RUSH.
On CarsDirect.com then charge in this area plus $750 over invoice, with advertising, so this was a great buy for us.
Will drive to Canada later and will report on how it worked.
BerryCherry
The San Fernando valley is full of CTS's today, I saw one Black and three White Diamonds. At one point we had my car and two other White Diamonds across three lanes of I5. I don't know who the other cars belonged to, but one of the owners is reading this please let me know. I saw the Black and the other White car at Lowes in Burbank.
I don't even have to comment on how much a ripoff Teflon coating is. You're better off buying Mother's or Mequire's car wax and spending a nice weekend day taking care of your car.
Whether you want an extended warranty or not is up to you. You also have to consider how long you are going to keep the car, who's offering the warrenty and who will honor it.
LoJank is hidden in the vehicle but people who steal a vehicle will just rip it apart and find it. Experts can probally find it in 15 minutes after all the seats or car engine compartment is ripped apart.May prevent some problems if kids take it. And LoJack has many other options that cost more money.
Not sure about the area coverage that that LoJack has, or do all police deperments in the USA and Canada use it?
The brochure I have read does not say any thing about coverage.
It's all a RIP OFF.
Hope some body who really knows about this will respond.
Yes I am worried about theft, it is a beautiful car.
BerryCherry
Glad that coupon deal worked out for you.......
Did you get black? My favorite !
Yup..The same deal in NY ....The tax is computed on the deal price of the car...minus trade if any...Then rebates etc. are deducted.
Did they charge you adv. fees or DOC ? Hope not..
They aren't supposed too........
ENJOY it ! IF the BOSS lets you drive it! LOL!
.......geo
Supposedly a supercharger is coming withing 6-8 months,and other parts soon...
What do people use for cleaning the dash and insides of the doors? I'm thinking about trying a wipe, such as Meguiar's Gold Class Protectant Wipes, for speed and ease, but I'm always leery about putting anything on interior plastics (my wife once used a household cleaner on part of her car's dash and thereafter you could always see where the droplets landed when she sprayed it on). I want to avoid leaving a shine, dull when dry is good --less glare (maybe I should just use a Swiffer or other dry cloth to lift the dust?).
Finally, does anyone have a spray-and-forget tire cleaner they can recommend? I have the base model CTS with the regular issue painted wheels, so my concern would be avoiding anything that adversely reacts with those wheels.
By the way, I've had my CTS since April and I still get excited each time I get a chance to drive it. Even enjoy my daily short drive to and from the park-n-ride commuter station. Just a wonderful car to drive.
It only seems like yesterday that I bought my CTS and now to think that it's OLD. Keep us informed as you drive and cruise in it.
However, we do have property taxes on automobiles.
Don't feel bad guys, we pay 15% sales tax up here on new cars, 8% prov tax and 7% federal.
For your scratches and swirles, use Mequire's ScratchX. It does a good job on most minor scratches and can be found at most auto parts supply stores like Pet Boys or Autozone. It won't get everything out (sometimes professional care is needed), but it does a good job.
For long term care, I'd recommend that you wax the car yourself or find a detailer that you trust that will do it right. Most automatic car washers will damage your vehicle's finish over time. My CTS has never seen a wash machine and probably never will while I own it. I just take it down to the coin op place and do it myself.
NEVER take your black car through an automated car wash! The dealer gave my black CTS the "courtesy wash" (I didn't realize beforehand they were going to wash it) and it took me over an hour to buff out the surface scratches.
I've tried almost ALL the auto care products and like Mother's the best. They have a cleaner pre-wax that will remove surface scratches which should be followed up by their pure carnuba wax w/or w/out cleaner. Mcguire's is also decent stuff as is Zymol...and for inexpensive wax I actually like Turtle Wax. The best shine can be obtained by using Zaino products but they are so non-abrasive they won't take out surface scratches and provide almost no protection against rain and dirt.
As for cleaning the interior...as crazy as it may seem all you need to do is use a mild soap (even hand soap works) and water then dry with a towel. The 3M microfiber cloths work good to pick up dust and there's a non-amonia glass cleaner that you can get at Costco that works well. Avoid using ArmourAll...I've never seen it ruin anything (like people claim it does) but it adds a shine that's hard to get rid of and there's really no reason to use anything other than soap and water.
Lastly, don't let ANYTHING with synthetic fibers (wash mitts, brushes, etc.) to touch the finish of your car. Costco also has real sheepskin wash mitts and chamios that work great to wash/dry your car.
This guy rebuilds LED brake light bars and taillights for most newer Caddies. I am sure he will have a fix for the CTS soon.....
E-mail me for contact sonjaab@aol.com (Won't post here cuz it will anger the host) I have shot him a e-mail so he might stop by!
Note the applications on his web site are NOT updated tho. with all his new goodies ...
So its best to call direct!..........geo
Definitely the guy to contact if your LED's take a dump.
