After approx. 1,000 miles, I am fairly pleased with the tires. I did have to get one replaced. The tire shop said I hit a pothole and "broke a band". A bubble showed up on the tire.
With the low profile tires, I highly recommend the Road Hazard warranty. The Versado came with a 40,000 mile warranty.
After 5,000 or so miles, I will post again.
BTW, did you see my post on the chalky dashboard?
Would have been nice to actually drive in some real snow with the Dunlops... Maybe next year.
Yeah, the TL was made for the low profile 17s...
Visit Zainostore.com for a lot of info and check out the Zaino thread here for even more info (just keyword, "Zaino").
My starter kit was Z-2, Z-5, ZFX and Z-6. Last summer, I bought the maintenance pack of Z-7 and Z-6. Z-7 is the car wash, four bottles may have been a bit much as a little goes a long way! Lifetime supply of Z-7!
After swapping my Toyos back yesterday, picked up a nail in one during the 5 mile drive home. Of course, we're driving to DC next week, so perfect timing. Luckily, I noticed the slow leak, had it fixed today...
Drove by my neighbor today with the '08 TLS, he was scrubbing his tailpipes with a toothbrush and I thought of you Zaino guys! :P
Again, I just should not own a darker color car...
But, when it is in full Zaino z-2 shine... :shades:
Sounds like his wife or girl-friend have not tasked him sufficiently. Was he using an old-fashioned tooth brush or a mechanized such as "Sonicare"?
Thanks to all who have given opinions on replacement tires for TL. Decided on Michelin Pilot Exalto A/S and have on order for 04 TL. Will give feedback after putting on some miles. This tire ranked high in its class in Tirerack's tests and customer feedback and has attributes I desire.
Those are made of plastic/nylon and will scratch the chrome.
Stop by your neighbors house, hand him some chrome polish and a couple of micro-fibers.... he'll thank you for it. :P
I ran all-seasons and winter tires on my TL with the differences being obvious.
Now however I have summer performance tires on my GTI since it won't see any snow. My question is: what are the main differences between summer performance tires and all-season performance tires (better snow traction being obvious)?
Which ones are generally quieter? I would be willing to give up a little "grip" for quietness
Check out Tirerack.com tire tests, tire buyer surveys, and tire buyer comments. I had to replace OEM Bridgestone EL42 tires on 04 TL recently. After research on Tirerack, bought Michelin Pilot Exalto A/S. Considered Michelin summer tires since I have 4 mounted snows, but settled on Exalto A/S. My take was that while the summer Michelin Perf would have had better cornering, turn-in, crispness, etc., they probably would be a harder/noisier ride per info on Tirerack.com. I value the minimization of noise and hard ride over the gain in performance of the summer tire.
Gas mileage has dramatically improved back up to my prior MPG. My guess is that the tires had to be broken-in...as it took about a month for the MPG to improve to prior levels.
Overall...I would recommend the Pilot A/S. They drive well....perform well...and seem to be wearing evenly.
Any insight is appreciated. Thanks.
I ask my dealer about this on my 1st oil change and they had someone come in from PA to just repair the rims. It was $ 100.00 each rim. Still cheaper than buying new rims. And they looked like new again. The rims do seem very soft.
[non-permissible content removed] luck
How did they repair the rims? Buff it out?
After reading the reviews on Tirerack.com, it seems like the Bridgestone Potenza RE960AS Pole Position are the ones to go.
Do other TL owners have any previous experience with these tires?
My '05 had 23k on the Michelins when I traded up for the '07 MDX and they were on their way out. I rotated religiously too because of the 19k I got on the first set of Michelins on my "03 TLS. If you got 43k why not stick w/ the Mich's?
I'd stick with the same brand tires; however, they're a bit expensive ($100/ea over the Bridgestone Potenza RE960AS Pole Position). Plus the reviews on the Michelins were lower.
What size wheels and tires do I need for compatibility to a 2005 TL.
I believe Acura still uses these crappy OEM's on the 2009 TL without the tech package and so does Toyota on the camry, Lexus on the ES350, and Nissan on the Altima 3.5SE; these were the worst tires I have ever had and consider them dangerous and unsafe and warn anyone from getting OEM Bridgestone Turanza's EL400; the OEM Michelin Pilots Acura uses are not that great either but they are the better of two evils; try to get them if you can!!!!
AVOID BRIDGESTONE TURANZA EL400 TIRES AS ALL COST!!!!!!!!!!!!!!!!
Questions: Can I replace two tires at a time? What suggestions do you have for tires that aren't a fortune? I live in the NE and my driveway is gravel; but honestly I've had zero trouble with my tires. Today's flat was my fault for banging into a curb.. not once but twice. :mad:
After moving to Minnesota from southeast Michigan I went through one bad winter and realized driving my TL is like running a hot corncob through butter...just slides all over. This fall I went on TireRack.com and purchased the tire/wheel combo you see below for about $900 including shipping. Actually it came to $850 because the mfgr is sending me a $50 AmEx gift card (woo-hoo!). The very next day we had an inch of snow in Minneapolis and the tires performed beautifully. I felt like I was driving my wife's all-wheel drive SUV. Granted, an inch of slushy, wet snow isn't a real "test". But there wasn't a single moment where I felt nervous about taking a hard turn on the interstate that winds through Minneapolis. If I'd had my other tires, I would have been crawling through those turns, and still worried about sliding into the guard rails.
As for going down in wheel size and increasing the tire size, I've asked that question before and been shot down. I too have replaced a couple rims and it's not cheap. I just chalk it up to the downside to owning this car. I love it in all other respects so I just bite my tongue when it happens (though we don't have an abundance of potholes around us).
Tires: http://www.tirerack.com/tires/Sizes.jsp?model=Blizzak+LM-25&make=Bridgestone&
Wheels: http://www.tirerack.com/wheels/WheelCloseUpServlet?target=wheelCloseUp&wheelMake- =Sport+Edition&wheelModel=F10&wheelFinish=Silver+Painted&partnum=F107811260S
I decided to order the wheel/tire combo because we plan on holding on to the car for another 5 years until our daughter can drive, and then give it to her. So I just store the "spare" tires in a corner of our garage and plan on swapping them out every six months as the seasons require.
was told by Acura that hopefully bridgestone would replace them because with all the problems I had they definitely would not wear properly and all that shimmering/vibration in the wheel/pedals and the wobbling/pulling to one side are all signs of out-of-balanced tires
I was completely sold with the Bridgestone Serenity's the first 8k miles I had on them: as soon as I put them on their was a worlds difference; the vibrations/shimmering in the wheel/pedals/seats all went away at high rate of speed, they were a hell of a lot quieter and the ride quality was improved; now I have about 12k miles on them, have had them balanced at every rotation, properly inflated at all times, but have begun to notice the same problems with these tires that I had with the OEM EL42s: even after having them balanced and another front end-alignment done they are now causing some vibrations/shimmering in the wheel/pedals and I'm starting to feel that wobbling ride/pulling to one side when I drive at high rates of speed above 50mph
was told by the tire store I have the rotations/balancing/alignments done that all four serenity's are beginning to show signs of wearing unevenly across the tires despite having them balanced and rotated and inflated properly: I am lucky if I get 25k miles out of them before I'll have to replace them at cost to myself and probably would be even luckier if I get to 20k miles on them before replacement
while I have enjoyed the quieter/smoother ride the serenity's have provided compared to the OEM EL42s, I am very dissatisfied that after only 8k miles they are wearing unevenly and let me tell you how happy I am that I paid only 100 bucks to have all four of these tires replaced and put them on the car: these tires without an adjustment are almost $245 a tire to have put on the TL; I would be freakin livid had I paid full priced for these serenity's, almost 1200 bucks to have all four tires mounted and balanced, and be dealing with these problems; I would have expected more considering the rave reviews that the serenity's have on tirerack.com but I guess these tires are just not a good match for the TL as they are on other vehicles, especially since they are a really expensive tire to get
so despite trying to avoid the same situation you ran into with the OEM EL42s, I will be in the same predicament as you with my serenity's at about 20-25k miles
I do believe the OEM EL42s are one of the worst tires I have ever had on any car over the years and I've read many many reviews on tirerack.com of how poor these tires are and how they wearout pretty quickly or wear unevenly: the michelin pilots you get as OEM on the TLs with technology package, while far from a great tire themselves, are superior compared to the OEM EL42s in regards to people being happier with them and they seem to last longer than the EL42s
I don't know what I am going to do when I replace the serenity's when they come time but I am definitely not putting another Bridgestone tire on the TL, I don't think Bridgestone and TL should be in the same sentence: I'll most likely try Kumho, Michelin, or Yokohama as replacement tires when the time come
Sorry you weren't able to get longer at of your tires then you did: Best of luck on picking new tires for your TL!!!
What is the ideal tire pressure for the tires? My TL's tire pressure sensor is so sensitive and it seems like the tire pressure fluctuates so much, depending on how cold it is outside, etc. Right now, the tires are reading at 34 with the exception of the back left tire at 30. They sometimes get up to 37 if it's warm outside.
I'm confused...any input is appreciated.
anything more then this and the ride really begins to get choppy, at least too choppy for my taste!
actually, you didn't mention what TL you have, I have a 08 base TL with 17inch wheels; not sure what the 4th generation TL tire pressures are supposed to be and if you have a type-s the pressure is different then what I quoted
I had Bridgestones all seasons on 2 of my vehicles and they were very slippery on the road for both vehicles.
I think Michelins are also slick on wet roads and are overrated.
The only all season tire I have had good luck with are Toyos & Yokahamas.
In regards to traction and handling I too have found Yokies to be very good in those regards!
