Toyota Sienna Audio/Entertainment Questions
124
    semenzatosemenzato Member Posts: 41
    As other folks have noticed, the volume of the Sienna DVD player through the speakers is quite low, and during quiet passages in a movie even the MAX setting may not be enough. So I am buying more headsets. There are several wireless IR headphones on the market. Does anybody know if any of them is compatible with the Sienna DVD IR transmitter? Many thanks! ---Luigi
    Am I the only one to be unhappy with the factory-installed Sienna DVD player? I own a 2009 Sienna with the JBL speakers (and almost everything else). The player works, but it has the following basic problems.
    1. It turns on when the car is turned on, even if it was off when the car was turned off, and even if the screen is in the closed position.
    2. There are no controls on the dashboard to pause/play the video etc. Full controls are available through the touch screen only when the parking brake is activated. (Mmm, if I could only find that wire...)
    3. The volume through the speakers is too low and often insufficient even at the MAX setting.
    4. The volume cannot be controlled from the back, so the driver (me) gets frequent requests to adjust the volume.
    For the amount of money they charge they should at least get the basic things right. I am very unhappy with this system.
    airmanmj2001airmanmj2001 Member Posts: 15
    I have just been owner of a 2010 LE for a couple of days, but I kind of agree with what you mentioned. To add to the list, the Video input can't get the sound to the in-car audio system is really inconvenient, especially for kids who don't like wear headphones.
    FYI, from Amazon reviews and other info, it seems that the BRAVO IH-03A Kid Friendly Infrared Wireless Headphone will work on the Sienna. Newegg has them for $20. I ordered a couple. Also the IH-01A and IH-02A should work. There are many others that will probably work, but these are the cheapest and apparently the quality is good enough.
    gedgoudaslgedgoudasl Member Posts: 21
    The display goes blank and none of the controls on the dash work, cannot change whatever is playing with them or control volume, the steering controls work however. I was changing something which initiated the blank screen. Sometimes it goes through random character display before it goes blank. Radio is in a 2008 XLE. If you had this problem what was the fix? Thanks.
    greytautumngreytautumn Member Posts: 38
    Trip to the dealer time. My JBL (07 Sienna) did that this morning on the ride to work. I'm into the dealer tomorrow.
    Randomly spit out all 5 of my cd before dying totally. Then after a few minutes I could turn it on again, but the display was blank and none of the controls excpet the wheel mounted ones worked.
    Ironically, my wife is at the dealer today getting the registration and inspection on a 2009 Rav4.
    jsambo1jsambo1 Member Posts: 2
    I just purchased a 2010 sienna CE and now find I miss the stering wheel audio controls. Is there any way to buy an aftermarket controller for the stock sienna radio? If not how much would it cost to get the controls added by the dealer or buy it and install it myself?
    Go aftermarket instead. You can get an in-dash GPS with touch screen controls.
    You saved enough on the CE to pay for it, even.
    jsambojsambo Member Posts: 5
    Why would I install a GPS when I am interested in steering wheel controlls for the radio? How hard would it be to buy a steering wheel with radio controlls and install it?
    I'm just saying, why stop there?
    If you're going to customize it, go all out and add a GPS and a backup cam as well. You can do it for 1/3rd the OE prices Toyota charges, and probably recover more than half at resale to boot.
    nboernernboerner Member Posts: 8
    I just ordered a 2010 Sienna Limited with dvd and nav and now after reading some posts I have some questions about the entertainment system.
    1. If the kids are watching a movie in back with headphones can I (driver) listen to something else on the radio.
    2 If I am driving and the kids (aged 1 and 3) need their movie started rewound or the volume turned up can I do that while driving.
    3. what does another post mean whent they say the dvd turns on every time they start the car, is that only when there is a movie in the player.
    4 Does anyone have experience using the system with young kids and how do they deal with these issues, thanks so much.
    My 2010 Sienna Limited appears to ony have 4 cd player. Can i plug in a mp3 player to the aux jack and control it through the steering whell controls? How have people worked around the limited disc spaces and still controlled through nav or steering wheel and can music be sorted in to folders or playlists or do they just play as on elong string of music
    skluzskluz Member Posts: 5
    Answers to your questions based on my 2009 Sienna XLE:
    A. Yes. This works quite well, although with youngsters under 2 it's pretty tough to get them to keep the headphones on.
    2. If I am driving and the kids ( aged 1 and 3 ) need their movie started rewound or the volume turned up can I do hat while driving.
    A. There is a remote control that allows you to control everything like you would on your DVD player at home. It doesn't work great as the driver as it seems to need to be pointed at the front of the DVD player. We've had varying success while using it as without seeing the DVD screen it's hard to know what the current options are.
    The DVD player volume when played over the car speakers is quite soft. You'll have to crank the volume up to double the volume that you'll use when listening to the radio. ( setting 22 verses 11 ) This does cause issues when you eject a movie to put in another the entertainment system switches to the radio when no DVDs are present in the DVD player. Maybe I shouldn't mention that I've switched out the DVDs while being the only adult in the car and while driving on the highway, but it is do-able. You'll learn where the eject button is on the front of the player and be able to press it catch the DVD and replace it with a new one while driving.
    If your kids have the headphones on you will not be able to change the volume for them. Each headphone has it's own volume control on the unit itself. The fact that they are wireless makes them much more toddler friendly.
    3. What does another post mean when they say the DVD turns on every time they start the car, is that only when there is a movie in the player.
    A. The DVD player will always be on while the car is on. If there isn't a movie present it just will just show a static screen on the player if the screen is down ( I believe, I didn't double check this ). If the screen is closed it will be as if the unit was turned off.
    If there is a movie in the player it will resume playing from the position it was in when the vehicle was turned of. This works great for us. The movie "Cars" is this month's favorite. Each time we get into the Sienna it's right were we left off and thus we're not stuck listening to only the beginning of the movie every time we get in for a while trip across town.
    4. Does anyone have experience using the system with young kids and how do they deal with these issues.
    Well, my oldest son was about 20 months old when we bought our Sienna and we also had a 1 month old at the time. Our oldest had previously dealt with our poor man's solution of using an iPod Touch as a video player so jumping up to the larger screen was a major bonus for him. He loves getting in to the Sienna for any trip short or long. Our infant still isn't able to watch the video's yet although he'd love to. He's now 10 month old and still has to ride in a rear facing car seat which makes seeing the screen impossible. We're only about 2 months away from being able to turn him around and then we'll have to worry about finding a movie that they both want to watch.
    The only problems we've run into with the entertainment system is:
    1. The audio video jacks in the rear of the vehicle are not hooked up to the main entertainment system in the front of the car. The audio from these inputs will only be audible through the headphones and will not play over the vehicle's speakers.
    2. The remote is a little flaky. At times it just will not work.
    3. Audio playing over the speakers for the DVDs is very quite and causes radio blasts when DVDs are ejected.
    These are fairly minor problems and wouldn't steer me away from going this route again. We did look seriously at buying a lower level Sienna and having screens put into the headrests but opted to go the full Toyota route and we're still happy with our decision. Next time we take the Sienna in for maintenance I'll mention the audio/video jack issue and see if they're able to do anything about it. I've heard a few different solutions such as running a cable from the DVD player to the auxillary jack in the main console ( which seems like something that a toddler would love to pull on) or attaching small speakers to the DVD player that hang from the ceiling. I guess if we were desperate I would just run a long cable from the rear of the Sienna where the jacks are to the front running it under the carpet and then up to the auxillary jack in front. Then you just wouldn't use the audio portion of the jack in back and would use the cable to hook it directly to the port on the front console.
    In your other post you mentioned being able to control an iPod or other MP3 player from the steering wheel. In our XLE this isn't doable but I'll let someone else answer for the Limited. The MP3 player uses the Auxillary jack which is only a headphone jack basically. It isn't able to control the device through it.
    I hope this helps and I'm sure you'll love your Sienna. We're still in very happy with ours.
    Thank you so much for your detailed answer, it has really helped me understand the logistics of using the system. I appreciate your time.
    tanker5tanker5 Member Posts: 36
    Answers to your questions based on my 2006 XLE Limited system
    1.Yes, no problem
    2.No, unless you are stopped and emergency break on. Then you have control over the DVD. Some have found ways to work around this issue. They bypass the emergency brake.
    3.Yes. Eject the DVD or take off the emergency brake.
    4. Mom,dad or grandparents intercede when kids scream. I find the 5 year old can handle the remote better than I.
    You'll love the entertainment unit and the kids will not keep asking "Are we there yet?" The 2 and 5 year old can not take their eyes off the screen.
    Tanker5
    how do you bypass the emergency brake. are ther ways other than purchasing the somewhat complicated accessories that unlock all the dvd and nav features while driving. it wuld be a lot easier it would seam to bypass the emergency brake if that is possible. i had heard that the unit must receive some signal to let it know the car is braked and that you cant just disconnect some wire, anyone have any opinions. I would also love to hear from anyone tht has used the lockpick or prestigious society products. I have some questions about usnig them,
    duke88duke88 Member Posts: 3
    To add what to skluz said, you can't ff or rw while a dvd is playing from your steering wheel. But the up/down buttons on the left side will let you advance or go back in the DVD chapters. If you have your NAV sceen activated to view the DVD chapters while the movie is playing, you can see what chapters you are changing to on the screen.
    I just purchased a 2010 XLE with package #4 and the stereo is XM Radio capable. I have a hard time paying the dealer $500 to put a receiver in the vehicle for XM Radio. Is there a less expensive alternative out there?
    ann2tieann2tie Member Posts: 1
    Hi, Duke88: Like you, I just bought a 2010 Toyota XLE Sienna with Pkg #4 (Satellite ready). We've had it 6 days and love it. However, I, too, would like to put an XM Radio in it but don't want to pay hundreds and hundreds of $$. Have you had any response to your posting? :
    I just bought a 2010 ienna CE and forgot to order the steering wheel audio controls. DOes anyone have any knowledge about getting a steering wheel with the controls or adding a aftermarket controller? What make is the radio in the sienna?
    The high end stuff is JBL, but I'm not sure about the CE and base LE models.
    laval1laval1 Member Posts: 1
    You can have an ipod interface installed in your 2010 sienna. Works great just have one installed yesterday. This is a Toyota part. You can control all functions of you ipod from the Nav screen, Playlist, Album, Artist...
    batavia02batavia02 Member Posts: 38
    Is it easier to change out the whole radio if one wants to install xm/sirrus on a 2010 new from dealer, or Does anyone know how the dealer does it,I would like it to look like one unit not have various units wired in all over. thanks
    2010odybuyer2010odybuyer Member Posts: 6
    Hi, Did you find how to work out the option to play the Audio in the speakers if we connect iphone or other device to VGA inputs instead of running the Auxiliary cable all the way to the Auxiliary port. We have a 9 month old baby and she is all over the cables when we were testing this feature & so I would need some other alternative way to have this feature.
    I'm sorry to say that we haven't found a better way. The Sienna is my wife's vehicle, so she's been doing the communicating with the dealership and hasn't felt the need to ask about it.
    Someone else mentioned an upgrade to the 2010 Sienna that allows iphone/ipod controls from the navigation screen. I'm not sure if this would allow the iphone content to be displayed on the DVD screen or not, but my guess is that it would not. Even if the auxiliary jack in the back of the vehicle worked as we would have expected it to, I think you're still going to need another system tweak. How do you expect to control the iPhone from the front of the vehicle? It might be easiest just to have a cable run from the back inputs to the front of the vehicle...just cover it with mats.
    By the age of two, my son could control our iTouch better than some adults... So it could be as easy as running the cable from the back to the second row seats so that the youngster can control the iphone video once she is old enough to control it herself. My son who is now 3 actually really likes the headphones and doesn't mind us listening to the radio while he's watching the Backyardigans. Now I just have to wait until my 1 year old, that can now face forward and watch the DVD player as well, can wear the headphones without wanting to toss them.
    Good luck with your Sienna and solving your video watching problems. I'll watch to see what you come up with.
    davemcdonald4davemcdonald4 Member Posts: 6
    Is it possible to hook up an Xbox 360 to the dvd screen in a 2010 Sienna?
    Yes. There is a component video connection with an AC plug in the rear seat of the Sienna. You'll be able to plug the XBox 360 in there... You will need an adapter as the plug in does not have the ground portion of the plug. You also will only be able to hear the audio via the headphones. There current setup does not allow the audio from the rear composite jack to play over the Sienna's speaker system.
    Cool. Thanks. We test drove a Town & Country as well and that was one of the features I liked on it.
    We seriously looked at the Town & Country as well. At the time they were knocking rediculous amounts off the vehicle's price, but I still couldn't bring myself to buying it.
    Take yesterday for example. My folks drove our Sienna to the airport to pick my family up after a week long trip. We were able to get all of our luggage in the back, sit 4 adults comfortably and still had the 2 car seats for my 1 and 3 year olds.
    Try sitting in the Fold and Go seats in the Town & Country and convince yourself that you could sit in those for a 30 minute car trip across a major city.
    I can't tell you how tired I was of hearing it from salesman, but the second major point was the cost of ownership... We've had our Sienna for almost a year now without any problems. Two of our friends have Town & Countries and have not had as good of experiences.
    Six Flags is sponsored by Dodge/Chrysler so that had a loaded T&C at the park. It was open and you could crawl all around it.
    I didn't like the stow-n-go seats either, but I've sampled Swivel-n-go and those seats are much better.
    This one also had twin screens, but it retailed for $41k. :surprise:
    At that price the small amount of leather they put in the center of the seat only just doesn't cut it. That van was at least $10 grand overpriced. Chrysler has built-in enormous rebates in the price to begin with. Crazy.
    They are way overpriced. I went in and told them what I was looking to pay (lowball) and they have not called me back. It has been a week today. Meanwhile, I've had 2 local Toyota dealers fighting each other for my business. Crazy.
    Let's see how Fiat ownership changes things.
    wu8wu8 Member Posts: 6
    When I was growing up, FIAT stood for Fix It Again Tony. Hate to say it but dont get one build on a Monday or Friday and you'll be ok.
    rgrorgro Member Posts: 3
    Anyone have experience (good or bad) with having an aftermarket DVD entertainment system installed intheir Sienna. I'm toying with the LE with EVP #2 and having the entertainment system installed by the dealer since I don't need everything in the EVP3 but want a DVD player for the kids. Any advice?
    Aftermarket all the way. I replied in another thread, so let you know if you don't see my response.
    apparelrepapparelrep Member Posts: 1
    Does anyone know the maker of the six disk standard sound system on the
    06 sienna ?
    Not sure...the upgrade is JBL so I bet it's a partner brand owned by the same parent company (that's usually the case).
    I have an 07, and it actually sounds decent for OE. Mine reads MP3s, too, but I think that was the first year it did.
    jpalecjpalec Member Posts: 1
    Our car is a 2006 Sienna Limited. The fault we are experiencing is that the audio/DVD sound periodically switches off on it's own (no access for any mode, radio, CD, DVD, etc.); while full on-screen controls and access remain apparently intact. When this does occur, the very faintest ghost of a sound can be heard coming through the speakers, which led me to the suspicion that there was a fault in the switch that "mutes" the audio/DVD, which would properly be done when there was a telephone call through the bluetooth.
    This has occurred with no user interaction, both with bluetooth on and off, and with the navigation off. For example, we experience faulty radio silence, despite system being turned on with high volume during a trip, and on it's own, volume switches on; and under similar conditions, the volume switches off on it's own from a working level.
    I'd really appreciate any leads as to whether this is a common problem, what is the source of the problem or any recommended fixes.
    buffettologiebuffettologie Member Posts: 3
    I've got a 2005 Sienna XLE w/ DVD (no Nav) and JBL Audio system (6-disc CD). The CD player seems to be dead - ques on "wait" after pressing load forever - and I'd like to replace it.
    Ideally I'd like to replace it with an XM radio but that seems very expensive unless I go with one of the ones that sticks on the outside of the dash. Alternatively, I'd like to replace the CD w/ a new unit that also includes an AUX jack so I can plug in my iPod. My worry is that just swapping in some aftermarket CD player will mess with my DVD player and my ability to hear the DVDs over the speaker system.
    Thoughts? My main concerns are (a) AUX jack, (b) not spending tons of money, (c) maintaining status quo on DVD which works fine.
    I'm sure you will have issues like with the DVD player.
    Another is the steering wheel controls. You may need an adaptor.
    These are questions you could ask the pros at Crutchfield. They may not have the lowest prices but they can offer advice, install kits, adaptors, etc.
    I got a Dual stereo for my Miata with an iPod input and they supplied the harness and good instructions. I had to crimp a dozen or so wires, but I managed, and it worked like a charm.
    pgrunnerpgrunner Member Posts: 25
    "Trip to the dealer time. My JBL (07 Sienna) did that this morning on the ride to work. I'm into the dealer tomorrow.
    Randomly spit out all 5 of my cd before dying totally. Then after a few minutes I could turn it on again, but the display was blank and none of the controls excpet the wheel mounted ones worked."
    This sounds exactly like what mine is doing right now. Did you ever find out the problem? I want to get it fixed but it's random and I can't seem to reproduce it. I'm afraid it will die on me right out of warranty.
    lfnlfn Member Posts: 1
    What type of place is my best bet to install an aftermarket DVD in my Sienna - a Toyota dealership, random autobody shop??
    I'd go to an electronics retailer.
    Your dealer will outsource it anyway, and just add their magin of profit on top of the shop's normal cost.
    I went to Circuit City, but they went out of business. I think Best Buy offers installation as well. Ask to see the shop and meet the installers. Make sure the operation is clean and well supplied.
    No problems with mine in 2 years of abuse in our Sienna.
    rustyleverrustylever Member Posts: 1
    I have a 2006 Sienna XLE w/ NAV & JBL audio system. All my music is MP3. With the in-dash d disc changer, I can play several hundred songs per disc in each of the 4 slots & also able to display the name of the artist & title in the proper lines in the display. Being retired & just the two of us, I really did not need the overhead DVD player. However, I am presently using it as a fifth CD changer & can thus play the same CDs on it as I do, in the dash changer. But, I would like to go a step further & be able to play MP3's on a DVD. I am wondering if there is by chance any software available that would convert the MP3 audio to play on DVD that would work in that overhead video player? I play DVD MP3 all the time on computers, which allow me to have several K of songs on a DVD. It would be neat to have that quantity on a car system as well. I am presently running a Kenwood music keg, in the van, but the tiny display leave a lot to be desired. I use the Aux audio jack on the dash to handle the sound, but hate having a cord hanging from it.
    If anyone has any ideas, I would appreciate hearing from you . Thanks much.....
    jkamjkam Member Posts: 15
    Hi- I want to install a 12-15 inch overhead DVD system in my 2011 Sienna. Does anyone have recommendations for both an installer and a type of unit? Thanks in advance.
    -joe
    I went with Circuit City, but they went out of business.
    Check out the local Best Buy, ask to see the shop itself, talk to an installer.
    That should give you a pretty good idea of how good it'll turn out.
    auto99auto99 Member Posts: 1
    See http://www.audio-dvd-creator.com/
    Try out the trial verison before you buy. Audio DVD's worked on my 2005 sienna.
    flynk9flynk9 Member Posts: 1
    I have an 06 Sienna XLE. I use both satellite radio and an iphone. You need something called a ground loop noise filter. About $15 at Crutchfield. I had a very loud and annoying hum/interference before; with the addition of this filter the aux inputs work very well.
    HTH. Here's the link at Crutchfield:
    Noise Filter
    eddieraseddieras Member Posts: 49
    thanks- i did pick up a filter - works good. but toyota should take care of this - they had a recall on a fewl other models and put a filter in, but wouldn't do it on the sienna.
    ygloveryglover Member Posts: 1
    Hi Joe.
    Did you find an aftermarket DVD? I am looking for one with wireless headphones for my 2011 XLE. Any suggestions?
    -Glover
