Pontiac Grand Prix Traction Control/STS/ABS
All at once, each of those systems is out and needs service. Anyone hear this problem or have this problem with their GXP? Mine is an 05 with 14k miles.
SEE ALSO: Diagnosing Traction Control Problems
I saw this at the nhsta TSB site. Does this sound like it?
Hope it helps,
Gary
Make : PONTIAC Model : GRAND PRIX Year : 2006
Manufacturer : GENERAL MOTORS CORP.
Service Bulletin Num : 050525009 Date of Bulletin: OCT 01, 2005
NHTSA Item Number: 10017755
Component: SERVICE BRAKES, HYDRAULIC:ANTILOCK
Summary:
BRAKE SYSTEM LIGHT ON, ANTILOCK BRAKE SYSTEM (ABS) LIGHT ON, TRACTION CONTROL LIGHT ON, SERVICE BRAKE/ABS/TRACTION/STABILITY MESSAGE DISPLAYED, DTCS C0241, C0550, P0856 SET. *TT
http://www-odi.nhtsa.dot.gov/cars/problems/tsb/tsbsearch.cfm
Cheers,
PS the full report I think costs money.
I was told the cleft front ontrol arm bushing separated on my 2003 Grand Prix, but I have not feeling anything abnormal while I am driving except when I press brake I can feel some vibration like ABS.
Should I repair it immediately ? what's the consequence if I delay the repair?
Any ideas?
I think I also have a same issue.
On end of January, I bought 06 Grand Prix GT with 16,000 mi ( at that time it was great, my best car ever). I have nothing problem with it before the mechanic replaced the intermediate steering shaft. They said it was recall thing and of course it was under the warranty. After that, tapping and knuckling started through the steering ( actually the vibration also came up while braking).
When I took in, the mechanic replaced wheel baring because it worn out ( this really did not make sence). the vibration was gone but the tapping remain.
I had taken my GT 4 times for tapping issue. Last week, they finally fixed. What they have been done is re-adjusting steering intermediate shaft, and injected grease which is the newest version.
The ABS service light still on, after replacing the wheel baring, However, it still needs to be fixed.
Hpe it helps to anyone.
for me steering var, tapping was really anoying because I could feel while accelating and braking.
In one instance after the trac light came on my oil light came on and the car shut off!
There is oil in the vehicle.
I went to re-start it and it took 3 times of hard starting to get it started....HELP!
Jim
I am from GM Customer Service. I can look up to see if there are any recalls on your vehicle. Can you please email me so I can get more information from you? You can access my email by clicking on my name. Thank you,
Mariah GM Customer Service
My email is socialmedia@gm.com. Please email me, and I will get some information from you to check on any recalls and answer your questions. Thank you,
thanks, Chris G
So now the Service Variable Effort Steering light pops up and I'm thinking it has to do with the Service ABS System light.
I apologize that no one has gotten back to you. Can you please email me your service request number and your VIN number so I can look into this further? You can get my email by clicking on gmcustsvc. Thank you,
I apologize that you are experiencing a concern with your vehicle. Have you had anyone look at the vehicle to have it diagnosed for the concern? Thank you,
It all seams to be fairly simple. I found at about.com instructions on how to install the new wiring harness.
Look what I posted just below your post.
I will let you know what happens to me with my efforts to cure the problem.
Mikeodo
