Lincoln LS Climate Control
Hey everyone, new to the forum... Can anyone help me out, I just recently purchased a 2004 LS V6 on saturday, I have a couple things that are going on thats bothering me...
1. The Heat doesn't work very well, it only comes on after im doing over 40+ mph, and not even that hot neither, even if I have the heat set to 90 degrees!
2. My Side view Mirror control button doesn't work properly, it can only set the mirrors downward but can't raise the mirrors upwards are turn them in or outward.
3. The Transmission feels like it engages hard sometimes coming back down from 5th to 4th or 4th to third im not quite sure, I drive with the shift selector on D5.
The car has 27K on it and it is a 2004, can I take it to a Lincoln Dealership and have this stuff checked out at no charge at all? Or will this stuff cost me a couple of $$$. I love this car and always wanted one, but little things like this turn me off about the car.
Thank you guys, your knowledge is appreciated.
#1 sounds like a stuck thermostat or a blend door problem.
B.
But good luck getting it fixed. When mine had 60 degree air out the side vents and 110 degree air out the center stack, [non-permissible content removed] verified by Lincoln field engineering, Lincoln factory engineering's response was "Within Spec". They of course refused to show me the spec and refused to fix the car.
I'm assuming you want cold air on both sides? And it's not set on dual operation? IOW, one temp set point is displayed.
Sounds tricky to me. Cause there are two 'heater control valves' - one for driver and one for pass. So if driver's stuck on heat, why pass doesn't get cool? Could be some crossover heating effect? Anyway, my guess is that the dealer should replace the valve for the driver side. It's probably fairly simple to replace if you dare. Try not to get an air bubble in the system though.
its seems after reading many issues on the ac air conditioner on the LS, people seem to avoid the answers or suggestions. Maybe if I put it in more detail someone will catch the drift and find a problem to this ongoing problem.
My 2000 LS which by the way is a joy to ride :shades: is a 3.9L V8.
The ac blows hot air with the setting at maxium cooling. Now I have the dual control temp. I have searched up and down for the low side valve and is still MIA thinking it could be low on R-134a (freon). Now after reading endless forums I heard it may be an electrical problem. The compressor does no sound when turning on the ac. Has anyone had this type of problem and have you solved it already?
I thank you in advance. :sick:
78k and still running though expensively. thx.
I have a Linclon Ls 2000 V8 3.9 and my climate control blows on high even if I turn it down. What is the problem and can I do the job myself? Thanks.
Sorry bout dat...Temp only goes down to 65, but it did stay on for 20 miles last night.(40 miles round trip)..Tom..
Since I mainly drive this vehicle alone it's not that big of an issue as one option is to close the vents on the passenger side. However, went on a trip with wife and daughter recently and wife got obsessed with it.
We are planning another trip soon and she wanted me to get it fixed. Happened just yesterday on my commute home in 95 degree weather. I try turning the A/C off, changing some settings, running the desired temp up & down. Took awhile this time but eventually got cold air again.
Since Bonnie already had it checked out at the dealer with no success, I don't know that my local mechanic would be any better (nearest dealer is 45 mins away).
Anybody else had a successful repair??
I'd buy another Linc but with the price of High test I looked for a regular gas auto, and some Impala owners say they get 45MPG on the open road. That's where I do most of my driving. See ya in the funny papers...TFC... :lemon:
New Impala looks pretty nice. Hope you have good luck with it!
Visiting Host
