Dodge-Plymouth Neon Electrical/Lighting
transducer
Member Posts: 7
in Dodge
I am having a battery drain problem in my 96 neon battery is new starter and alternator test as good cleaned all the conections anyone have any ideas??????
Walking up to the car and slightly touching the outside of the vehicle starts an Electrical current and the Interior light starts to flash.
You can also do this while driving.
It just flashes...you can hear an electrical surge somewhere but cannot pin-point it.
This is starting to effect other Electrical components such as the Radio.It actually disconnects the Battery at some point in the nite then reconnects coz the clock needs resetting in the morning.
Really need a starting point to figure this out.
I have no Manual so I'm not sure what all is connected the Interior or the Door switch wiring so not sure where to begin.
Any help or Ideas would be greatly appreciated.
Canadian Cactus
is it in the PCM my battery goes dead if the car sits overnight everything eles checks good starter alternator and the battery is new????
for some reason my car either isnt firing or its not getting gas
Hope this helps.
Farout
Now for the cluster there is good and bad news. Bad is you have to replave the cluster. Good is there are a lot of 96 Neons in salvage yards and parts are reasonable. the biggest problem is getting the correct mileage recorded so the DMV is ok with it. Check your state to find out.
farout
Any suggestions?
Our car is likely to be totaled. One of these last Texans made a left turn form the traffic lane and not the center turn lane! Maybe that's how they do it in Texas! Any way with only 40,000 miles the front end folded to protect the driver as it is designed to do. Engine is tilted against the firewall, motor mounts torn out, I guess I would call it a pug-nose Neon now!
But to expand your air bag question, you might find that if you needed the bags they would not work. That could really mess up a pretty girls smile, and ruin her evening too.
Farout
Thanks in advance
Emma :confuse:
It was only the battery. WHEW!!!!!! Thanks for the advice!
We bought this car used, about 3yrs ago. In recent months, connection is lost every time we hit a major crack in pavement or bump. (Go figure, we're in Detroit too.) We completely lose power, including hazards; brakes; etc.
Looking at the wiring last night, we noticed that the previous owner must have electrical taped the cables in several areas...wire threads are rusted out, twisted, you name it.
So...thought we'd just replace the cable and end our problems. Now I'm being told that 'special' cables are needed for our 1995 Neon.
Can anyone back this up? Have experience with using universal cables? We don't even have the funds to get this car towed.
Help!
Farout
Friends say starter is bad and to change it out, but it is practically unreachable sandwiched between the radiator/ fan housing area and tucked under the intake manifold!
I've been told I would need to remove the intake manifold , fuel rail, throttle body, air inlet duct, pretty much everything up front to change the starter!
One other person said i could remove the front mount bolt from the front cross member bracket and the engine could be tilted down to facilitate removal of the starter/Solenoid. Boy there doesn't seam to be enough clearance for this to me.
I'm presently strapped for cash and was hoping to do this myself. I'm mechanically inclined, but afraid I might ruin more than the current problem I have!
HELP Any suggestions I need the car for work to support my 3 children living with me
Any suggestions on what to check next would be appreciated, I love my neon, but at this point the hubby is almost ready to give up......
Thanks RJ :sick:
Sometimes the gauges on the dash "reset" at the same time. Example: speedometer goes to max, then steps down in about 1/4 of the gauge at a time. Other gauges do weird stuff too.
Rare but very irritating more intense effect: car dies - nothing electrical works AT ALL. Then, after a random period of time, it will start and work normally.
Battery has been replaced.
Methinks it's time to replace the voltage regulator, that is, a new alternator.
We have a 1997 plymouth neon,bought it cause the truck is hard on gas,anyway we can barley see at night cause the lights are so dulldoes anyone know how to get them clean,it looks like a dirty film? :shades:
After looking around to see how embarrassed I should be, I looked as good as I know how under and around the car everything looked fine.
I drove home about 6 miles away when I got off work.
The next day when I drove back to work, I went through a huge mud puddle.
The car died.
The next day we tried to jump it..nothing.
Then when I had it towed home, when they were lowering it down my brother says oh here's your problem and had a quarter size piece of metal in his hand. He said it was from the oil pan.
Ok..well the week before I was driving and without notice, it just shut down..everything died! All instruments not the engine. There was some sort of weird code "nobus?" was the only thing visible. I pulled over turned off the key.
I sat for a few minutes and then it started but the MPH gauge wouldnt work after that but everything else did.
Also it was a new battery.
Also prior to this I was blowing fuses like every other day. I couldnt play a CD and run the heater or any 2 things together or they'd blow.
I haven't had enough money to have it professionally looked at.
Today though - out of curiosity, I checked the oil and it was on the add mark...visible oil on the stick.
If it was the oil pan or engine block? wouldn't all of the oil have leaked out?
So I put 1 quart of oil in it and a sheet of plywood under the engine..and no oil came out.
I checked all the fuses AND took the positive cable off.
I charged the battery after that for hours and some things worked.
The anti theft alarm sound is weak.
The radio wont work.
The instrument panel and heater were operating.
The car doesnt turn over but there is a distinct click click click sound.
Then it died completely again.!!!
The battery light illuminates and also a round red circle(DOT) in the upper right panel shines.
Thank you so much for your time.
when i turn on the lights one side always is on high lights and the other side is low...
so i don't know what i should do....
maybe i should replace the fuses or the wire harness.... ?????
Replacement parts: headgasket, motor mounts, oil pan gasket, spark plugs 3x, water pump, timing belt, PCV 3x, fuel filler neck, radiator 2x, brakes, battery, rear lamps, headlights, and some body parts --damn deer!
Recent undiagnosed problems:
» I'm driving down the road and my airbag light will come on, then go off.
» Occasionally my radio presets will change without warning.
» This past winter when letting the car warm up then returning to it, there's a heavy smell of burning electric something (happened a few times).
» When the fuel filler neck was replaced we found a wire that was exposed near the gas tank.
» When stopping at stop signs or lights the car will quit at low RPMs (this happens so infrequently it's hard to pinpoint ).
» My factory CD player no longer plays burned mix cds.
Considerations: It's been involved in front and rear collisions, and superbly patched up.
If you've got any solutions or suggestions for any of the above recent problems, I'd love to hear from you.
Can anyone help?
