Ford Crown Victoria/Mercury Grand Marquis Electrical/Lighting
Where is the hazard flasher relay located on a Grand Marquis, 1997. The under dash fuse box has a round space, but nothing is plugged in there, and there is no info in the manual.
If parked outside, this will occur within seconds of starting out. If parked in heated parking, this will occur after 15 or so minutes of driving. Replacing the air filter had no effect on all of this.
Any ideas what this could be, and how to fix.
Thanks in advance for any help out there!!
David
I had that problem in my car an 1987 GM and it was the Engine cooling temperature sensor. It was plastic no it offered a weak ground and always sent th computer into run hot mode. Making the car idle like a [non-permissible content removed] and allowing the car to accelerate because of the higher idle. I also had the problem in an 88 TC I had and it was the TPS. I had the problem in an 84 CV and it was the electronic choke on the Throttle Body FI Carburetor. :sick:
To me, it seems to be something in the ignition system. It is a pretty basic system today - I suggest finding the garage that your local police force may use - they will know a Panther platform very well.
Question: Do all '05 GM/CV models have the radio antenna on the R/quarterpanel? I'm looking to replace my '00 with a lightly used '04 or '05 and every '05 I've seen listed online has the external antenna.
Thanks for any help available.
On the antenna, all 05's have it. Coming from a 94 to a 2002, I'd rather have the 05's antenna - radio reception is poor with the in-glass antenna.
Tracked it down to the headlight switch. The instrument panel dimming rheostat coil was broken and turning the dimming knob would cause the broken coil to short out against the switch frame. A new headlight switch fixed it.
I took apart the column area and can not see any thing binding. A few months ago, the same thing happened for about an hour and then went away.
Any Ideas what is wrong or what controls the release of the shift lever?
Thanks in advance
1. Apply the parking brake, turn ignition key to LOCK, then remove the key.
2. Insert the key and turn it to OFF. Apply the brake pedal and shift to Neutral.
3. Start the vehicle.
LOCK is the one position toward you from the OFF position. If this doesn't work it is possible that a fuse has blown and the car's brakelamps may not be operating properly.
I hope that helps.
If the light is flashing, you should immediately shut off the engine and have the car checked by a qualified service technician.
If the light is glowing solid, this usually indicates a failed sensor or something that is not dangerous to operate the vehicle. Autozone offers a service to read your computer codes for free. This should tell you what's wrong. Good Luck.
However, something else is happening that is new. The inside dome lights are turning on when the car is running and when I park it I have to re-shut the back door for the light to start to fade to turn off. The car has been parked for two days and this afternoon the dome lights turned on by themselves and went off by opening and shutting the door again.
Please help! Any guesses would be greatly appreciated.
Other than that, the car has reached 103,000 miles without any problems. I change the oil,changed the serpentine belt,changed the spark plugs,coolant,and brakes and that's it!
My headlights ('03 CV) were turning themselves off after about a minute of burning. It didn't matter what position the headlight switch was on. Sometimes I could get the lights to come back on if they were off by turning the switch to off and then back to on. But the lights would always eventually go out. I found I could hold the turn signal back in a flash-to-pass position as a temporary fix. Finally took the car in and needed a new multi-function switch in the steering column and when that burned out it also took the lighting control module. This was $900 and not at a dealer, a local shop. Hope this info can help someone else. Overall, car has been pretty good--also had to replace the climate control module (also $900).
