From your experience, does what I posted sound like the flare issue or is is a different issue? Could it be related or caused by a similar malfunction? I say this as the dealer did the TSB TC007-07 which sound like people with the flare issue had done as well.
The flare only happens on some 6 cylinders, it normally only happens once when the engine transmission is cold, and it occurs on the 3rd gear shift. One poster had documented it on a video, and posted a link a couple times here on Edmunds forum. As second gear is winding out to the next shift point, you see the rpm's flare up about another 1K before dropping down lower to third gear. Many of those that have had this problem, have had numerous attempts to repair including software loads, transmission replacements, etc.....and end up getting a lemon law out. A couple of the problems were resolved with some fix. My perception (right or wrong), is that the attempted resolutions are marginally successful, but worth a try.
I've worked on a couple of my own manual transmissions and clutches over the years, but leave the automatics to the pros.....so I am by no means qualified to talk about the inner workings of an automatic. However, I did have a Ford which was slow to shift into 1st gear, which ended up being a bad solenoid. The symptoms were that we'd shift from park, reverse, or neutral and put it in drive, then attempt to begin to go, the rpm's would rise, the transmission would effectively be in neutral for a short period of time, and then drop into first while the engine rpm was up chirping the tires. Problem was it was not consistent, so you never knew whether it was going to shift correctly (most of the time), or not.
From the symptoms you wrote, I don't believe that is the 3rd gear shift flare....and you probably some other 'normal/regular' transmission problem.
I did see the flare video a while back.
I have an appointment with the dealer next week and hope they can find a fix for it.
Does the 3rd gear flare happen on a hard acceleration, a normal or gentle acceleration?
Does the car move in reverse? Does it move forward in other settings on the lever? 1st? 2nd? or does it act the same? Does it engage if you quit trying the instant it doesn't engage right and you just let the motor idle and the motor and transmission warm up a few minutes?
The rough and erratic engagements of the lower gears as you slow down sounds like something a few others mentioned in the past but hasn't been commented on lately.
See if you can detect patterns in these symptoms. I recall some transmissions in another brand a couple decades ago that had nylon washers that were pressure seals along a shaft and those would wear and not quite seal. Then as they and the fluid warmed they changed enough they could seal against the pressure well enough to operate the transmission. Replacing them fixed the problems. And if I recall reverse worked.
This sounds like another problem with the transmission than the flare. I'd have to look through the discussions about the downshifts that occur to see if they are related to the flare complaints or not. I'm thinking not.
You need to push your dealer for help with your transmission. I would think in the other forum you mentioned if you said a specific tranny with an engine didn't engage when cold on an erratic basis and reverse did or that it would after idling rather than trying to shift to engage, etc., someone would post suggesting the problem causing the trouble.
I am in the Chicago area and we have had some cold temps in the single digits. It seems to also do it when it is a little warmer. It has also been in the garage and must be a little warmer and no wind cooling.
I told him I had checked here and other places so I know it is a much bigger problem than a quirk and Toyota needs to address it. Finally, he agreed that they had software that could "recalibrate" it and that it is much bigger than an isolated incident. They reloaded the software and it seems to be running better now.
This is not to to defend the Accord, I just need to say that it bothers me a lot when people try to make any kind of point using the numbers of posts in any given discussion about any vehicle. You just can't do that. You can't know how many of those posts were by single individuals with an actual issue vs. multiple posts by the same individual vs. multiple defensive posts by people who do not believe that the car they own which has no problems is presenting problems for someone else. And you can't know how many posts in any given discussion were off-topic, just as you can't know how many posts were placed elsewhere that relate to the topic where you are post-counting.
The numbers of posts signifies nothing at all about any given vehicle no matter what vehicle is under discussion.
Just had to get that off my chest.
Chuck28 which problems are you having and what have they and you done so far? Does your trans slip on first start when cold? Which model is yours SE, LE, XLE, I assume a V6? Is your dealer aware of the issues. One dealer on the south side I checked with had not had any reports, yet, about this issue.
They then had my car in for service and said couldn't find the problem. However when I got the car back the flare was gone and has been gone for 6 months now. I have strong reason to believe they went ahead and reprogramed the ECU with the latest TSB and didn't want to tell me so they don't have to count it as a fix attempt and they protect themselves
from possible lemon law buy back.
I happy the flare is gone but the trans does not shift smoothly and has a downshift problem in 1st and 2nd gear.
My Gas mileage has also dropped and I get no where near the MPG I should be getting.
To say the least this experience with this car has been my worst ever!
Keep in touch, Chuck
My original problem with slippage in the first gear has not continued and I am sure it has to do with the weather getting warmer. I have an appointment for the flare issue which may be easier to replicate as it seems to happen each time.
Has anyone heard if Toyota has issued any kind of statement about the transmission problems and a once and for all fix for the problem?
Eric
Never, NEVER, talk technical aspects with a salesperson, that is unless you are the one "directing" the conversation. And ten to one odds say the salesperson will get it entirely wrong when relating it to the next person.
Toyota has eliminated an important part from their transaxles and that required them to use DBW, E-throttle, to delay the onset of rising engine torque for certain fairly common driving situations(***). So DBW is used to make it "easy" on the transaxle clutches at certain times. Say when a downshift is required but cannot be quickly accomplished due to the "abolition" of the transaxle component and therefore the loss of its functionality.
*** Driving situation/circumstances described quite adequately in a TSB issued for the Camry in the spring of '03.
There is a software update (TSB - Technical Services Bulletin), which the dealership can apply free under warranty. It makes substantial improvement in power, driveability, and cruise control smothness. It's been previously posted in these forums.
It takes about 1/2 hour for the dealership to reload the ECM software with the upgraded release, no big deal. Runs great.
in Toyota forum site.
Or are we talking just 4 clynd.?
Thanks for any updated, Chuck
Only a conversion to a true CVT with mostly transparent, non-obvious, up/down "shifting" will improve upon this matter.
I did a search on google with EG8025 and all other search parameters, but could not find it .
As you know from my postings in the past, I am on the road most of the time with regards to my career. I own a 2007 Camry XLE V6 vehicle that has none of the problems that I have seen on these boards. (That does not mean that the problems do not exist, rather, it simply means that for some reason my vehicle doesn not have these issues.)
Recently, I had the opportunity to speak to a person who also owns a 2007 Camry XLE V6. His vehicle has the transmission "flare issue!"
NOTE: ----- According to this Camry owner, the "flare issue" disappeared after he had the throttle body cleaned! ------ Question: ----- Could a malfunctioning throttle body, on a "drive by wire vehicle" be causing the "transmission shift flare?"
Best regards.
Dwayne :shades: :confuse:
If the transmission was fully engaged and in gear......and then the engine throttle had a problem......you wouldn't have a +1K engine RPM flare.
forum.autocd.ru/download.php?id=2812
Confirming my previous post, this recalibration of the engine and transmission has turned one of the worst performing cars I've ever had into the best. Fixed in my 4-cylinder 2007 Camry are:
1. no more sluggish downshift -- punch the gas and it goes like you expect.
2. no more so-called 'trying to find the sweet spot' between gears on slightest incline. The road trip mentioned earlier found me on I-20 between Birmingham and Atlanta. In cruise control at interstate speeds on quite steep inclines the car held in 5th gear with a smooth increase in rpm, in many cases where I would expect a properly functioning transmission to down shift. In fact, it took a very steep incline to finally get an opportunity to see how it would perform when it clearly needed to down shift. Answer: smooooth! When it got very steep the transmission smoothly down shifted to 4th, and then consistently held it for as long as the incline demanded it, finally almost seamlessly leveling back into fifth when I crested. Previously it would have been down to 3rd and back up then down, etc., but this time it functioned just as I wanted. Other clunkiness issues are all basically fixed as well.
Now even after 150 miles my car jerks in 1st and 2nd shifts. My car is a 07 Camry 4 Cyli Auto Trans bought in 2006 Apr.
Is there any problem with my torque conertor or transmission? Please help me anyone, bcos I want to ditch this car if it is going to be fixed after my warranty expires.
I am also facing the same problem. Most of the transmission issues are resolved after the TSB but the jerk when its shifting from 1st to 2nd gear is still there.
Cruise has improved, The hesitation has gone (except in first to second gear).
Am i correct?
anybody any clue what could be done for this problem?
And absent being of a reasonable level of help it would be needless to have to add the extra ATF cooling capacity the modification would undoubtedly require.
Apparently that's what was done with the '01 to '03 RX300's and even with the extra ATF cooling capacity provided by the towing package it still resulted in overheated ATF indications in as little as 40,000 miles.
QUESTION: ---- Are there any owners out there in "Toyota Land," who have a V6 Camry with the "famous" and "infamous" 3 to 4 shift flare problem, that have NOT applied the TSB fix to the transmission, and have experienced a total transmisssion failure as the vehicle accumulated miles?
I am sure that there are many V6 Camry vehicles out on the road that have the problem, but for some reason, the owners do not notice the issue. With that in mind, I was wondering if the issue with the "3 to 4 shift flare problem" does eventually cause a total transmission failure, at a higher mileage as the vehicle get older?
Best regards! -------------- Dwayne :shades:
