Thanks again.
However, in view of the cost and difficulty of repair, I'd use a full synthetic to be on the safe side, maybe RedLine.
The transmission that replaced yours from '90-'00 was the AX15. After '00 it was the NV3500 or the NV3550. Any of those would be a good choice.
Stripping and rebuilding a manual transmission (yours is an Asian AX5) isn't hard, but do try to have a workshop manual to guide you. If you're really lucky you'll just need the first and second synchro rings which cost about $20 each. However, if there's a lot of wear and tear an exchange rebuilt unit may be more economical.
Good luck!
-Paul
Mine: 1995 318ti Club Sport-2020 C43-2021 Sahara 4xe-1996 Speed Triple Challenge Cup Replica
Wife's: 2015 X1 xDrive28i
All of it!
Ok, change all fluids, no exceptions (remember gas is a fluid too!).
All rubber components will be suspect, especially brake hoses, wipers, coolant hoses, belts and tires.
Change all filters, i.e. oil, air, and fuel.
Renew all consumable ignition components, i.e. plugs, wires, cap, rotor arm, etc., etc.
Get a new battery, grease the steering and suspension zerks, check the brakes, clean the carb (inside).
Finally, expect some leaky seals and possibly some minor component failures in the first thousand miles or so. After that it should be good to go.
Congratulations on your new Jeep!
the engine code on the pass side of the block is hard to read but the last several digits appear to be 4CL25. I haven't found anything on line to tell me what that means.
anyone's assistance or experience with this would be a great help.
thanks!
Steven in Oregon
Q The owner's manual for my 2007 Jeep Grand Cherokee with a 3.7-liter V-6 gas engine recommends 5W-20 motor oil. The manual isn't clear whether synthetic oil can be used. Can it?
A Chrysler says that under terms of its warranty synthetic oil can be used in only its diesel Grand Cherokee, not in any of its gas versions.
You think this includes the Jeep Wrangler V-6 also? If so, why? I though all auto companies favored less friction via synthetic oils?
Any suggestions? :confuse:
Thanks for your time.
Before I have my son drive back, should I have him change the backup bulbs? Any suggestions?
There may be a post in the main Jeep Wrangler board relating to this fix, or you can search the web for the YJ front axle disconnect repair.
I wouldn't bother if the bulbs are functioning.
SUVs and Smart Shopper
Thanks!!!!
Yes I finally got the answer I needed after changing ALL the sensors and relays. It was my computer, it's in the shop now waiting for a new one from Detroit. The way it was explained to me was that after having my key turned on long enough (only on a nice day that is) the computer finally made the connection it needed to start. But the mechanic first checked all the grounds and connections first, he explained to me computers rarely go bad, thats why it will take time to get one. I hope this helps you.
In addition, my synchronizer for 5th gear has been slightly grinding when shifting. Should I replace this? Should all sync be replaced? Is is worthwhile? Do you have a ballpark figure for the needed parts and labor to fix the sync?
I know this is a lot of questions but I would like not to have someone put-it-to-me as deeply this time as some have tried and succeeded in doing in the past. thanks for your anticipated professional response, I do appreciate it. Mike
"12" = "Battery Disconnect" - Direct battery input to PCM was disconnected within the last 50 key-on cycles. I have this code often because I disconnect the battery when I change the oil. I don't think it is significant.
"54" = "No cam synch signal at PCM" - No fuel synch (camshaft signal) detected during engine cranking. I have never had this code, but I think the motor would not run at all if this signal were not detected. I am not sure, though.
It's barely attached just resting on the distributer housing. Any advice or help appreciated
