Visitor Agreement.
I'm wondering if the present 5 speed is a proven transmission? A sales person I spoke with stated that he thought it was basically the same tranny except Toyota modified the existing transmission for the added 5th.. While being mechanically minded, I'm not in the know at all about transmissions. His statements seem unlikely.. Any feedback appreciated.
Toyota makes the world's most rugged offroad vehicles and light trucks. The LandCruiser is Toyota's premier heavy duty offroad model. The transmission in the current model is not only heavy enough for you to use in the tame US environment you will drive in, it will also hold up in its applications in the rest of the world - including carrying miners around abusive mining operations, oil pipiline maintanance vehicle, and carrying workers and military personnel around the deserts and jungles of the world.
The bus transmission you refer to was in the 80 series LandCruiser from 1991-1994.
IdahoDoug
The durability should be excellent, as all Toyota transmission. However, it does NOT have a history yet.
I think new shocks are in order. That being the case, would you recommend the stock replacement shocks or Bilstein shocks? I once owned a Range Rover and the Bilsteins made a "big" improvement in ride and handling.
Thanks for your input.
BTW, I have yet to see the black garnet color. I'm dying to take a look at it. It sounds like it was be out of this world.
I've done some suspension development from the manufacturing side and I'm always amazed that people will put on an aftermarket shock and declare it an improvement. Shock selection at the factory produces virtually a custom shock absorber tailored for the vehicle's characteristics. Among other things, here are a few of those characteristics that drive the factory choice: high speed behavior, low speed behavior, emergency fully laden behavior, emergency fully laden max braking behavior, center of gravity, suspension travel, suspension geometry, max vehicle weight, min vehicle weight, shock stroke length, vehicle roll center, blah blah. On the LandCruiser, there are even different shocks based upon the vehicle's options.
Aftermarket shocks are not tailored in this way, in fact they often sell the same shock for several different vehicles the shock maker deems as similar. Financially, it is simply not cost effective for an aftermarket maker to develop a shock for each model on the market.
To me, the best shock to replace your original equipment shocks with is another set of original equipment shocks. I also think there's a good chance your perception of the LC's change in handling is the normal owner tendancy to feel it is deteriorating, rather than reality. LC shocks are very high grade and always have been. I believe LC shocks are still made by Tokico - one of the world's most durable shocks. At that low mile, I'd be surprised if they're damping much different than when they were new. I put new shocks on my 80 series at 100k after a life of heavy towing, rough offroading and lots of fun. The new shocks made hardly any difference and the old shocks were in fine shape - I installed them myself.
The only exception to my "stock shocks" exception is if you're going to replace both springs and shocks as a matched pair such as offered by OME.
I'm sure this will give me a flurry of "my LC handles so much better" replies, but I'll disagree unless you can provide me with the data results of thorough track testing. And before I shift it to replies saying "my butt tells me its so", I'll tell you I have a well tuned track certified butt and would never rely on it to tune my suspension in a world of unblinking computer sensors and the data they produce.
IdahoDoug
I have a 99 L/C with the same problem. The dealer says it's normal but I found the TSB. I like to no what you found out.
Can you pass along the TBS or how you found it?\
Transfer case buzz is the Transfer case shift lever buzzing when cruising along. It goes away if you touch the lever.
IdahoDoug, Intmed99 or Cliffy1, you seem extremely knowledgeable regarding LC's. Please comment?
(BTW, I hoping this is normal. I have no desire to deal with transmission problems)
Thanks again
To minimize operation noise from the transfer case during low speed moderate acceleration and high speed light acceleration, the high speed output gear, shift lever assembly, and center differential case have been modified.
Then it gives VIN numbers, and what parts are effected ie. High speed output gear, shift lever and linkage, and center differential case.
They add a note at the end saying:
The snap ring is used to minimize axial play when installing new High Speed Output Gear. The thrust washer is used to establish proper oil clearance for the differential side gears inside the center differential case
I got this straight from NHSTA.
I can email more if you like.
Sorry for such a long explaination.
Tom
So far, I think it was worth the difference for my usage. We bought a mountain cabin that we need to drive about 4 hours of interstate/2 lane blacktop through the desert to get to, with the last 8 miles on icy, snow-packed mountain roads with a 13% grade to get up to about 7,000 ft. elevation. The vehicle fills this role admirably. It is rock-solid and comfortable at 80+ on the freeway. On the 2 lane black top, the V8 gives enough kick to get around semi's in the few safe passing zones, quickly.
The traction in snow is fully what I expected it to be from the reputation of this vehicle. I even seem to be averaging 17.9 MPG at an average speed of 75 mph (some bursts over 90, and 80 - 85 mostly on the freeway.)
I don't know if I would be as pleased with the 6 on the mountain roads or not, but I am happy beyond expectations with the the V8. This is one fine truck for my purposes.
Cheers,
DDW
Thanks is advance.
Scott
scott@mobi-arc.com
I don't know if the aftermarket shocks offered are custom-made for the LC, or simply fit its dimensions (along with a few other similar-sized SUVs). Anyone have some research/opinions on this?
I find it impossible to conceive that Toyota would physically embed a pair of $35 sensors in a $950 part such that if either went bad you have to replace it. I also find it hard to accept that a dealer with the Toyota diagnostics software cannot find a code or trouble indicator by hooking it to the LC's self-diagnostics indicator. I'd be guessing, so I won't. But it seems to me you've hit it on the button - the dealer has a part in stock he'd like to sell you. Find another dealer.
As to the 97 LC in snow, you're better off in high range unless you've become stuck. Underway in high range, the viscous center dif function is used and better allows for maneuvering in snow and such. This is based on many days of offroading in snow as well as living in a winter climate where we're permitted to have steel studded tires. Be sure to check the tensioners on your cable chains frequently. They can make a serious mess of the body in about 10 seconds if they get loose.
As for the comment above regarding complaints about a Trooper's suspension shortcomings, I have little to say. It's no LandCruiser, that's for sure. And perhaps that's why the Trooper is going away this year.
IdahoDoug
Also, when we received 18 inches in NC about 3 years ago, we drove around in 4 wheel high, no diff lock, just like on a normal street. This was in a '95 LC. It was absolutely no problem what so ever.
Reply to 2387 - As far as the throttle position sensor, I had it replaced at my local dealership for $262 dollars, labor and parts. Do not let your dealer rip you off. I can send receipts if needed. They hooked up the Onboard Diagnostics and it told them exactly what the problem was.
Later,
fj100
'99 LC with Stuff
Hope this helps,
Frank.
Chains on the rears are generally the safest recommendation. Clearly you can steer better with them on the front, but in a braking situation this would cause the rears to come around in a spin. Since you can generally decide or control when and at what speed you turn, but you cannot predict when you'll need sudden braking, I go with the rears. I also agree with you that the truck is quite capable w/o chains if you air down to 20psi or so.
IdahoDoug
I read somewhere awhile ago that rear chains only on an full-time 4wd vehicle was a no-no.
As far as capable, when the 18 inch snowstorm hit NC, I was out in Jackson Hole, snowboarding and my wife was home by herself. She called and she asked about driving around in the '95 Cruiser and I told her to get out there. She drove around the entire time, no center diff locked, no aired down tires, she thought it hilarious because she was the only women out. SO the '95 lc without chains is very capable.
Reply to 2392- The 100 series is a different vehicle than the 80, as far as on road and family use (size and comfort), yes it is an upgrade however as far as hard core offroad use it is not upgrade unless you are only doing light trails and really fast dirt roads. I bought the 100 because I wanted something different (my former LC's were a (91, 92 and '95) and I wnated a v8, heated seats and center arm rests (silly options but very useful). I would recommend a '99 because rear ac was available and you can still get the rear diff lock. In 2000 they went to a traction control system that utilizes the brake system for sending traction to the wheel that slips. When I am done with my '99 it should be pretty capable - the last upgrade is front and rear arb lockers. That is a couple of years out.
I have the OME shocks and springs and sway away torsion bars and they make a difference, the vehicle does not lean as much or squat and dive on braking and acceleration and it gives you a 1.5 inch lift over stock.
fj100
OEM is defined as "Original Equipment Manufacturer" for some reason - would make more sense to call it "Original Manufacturer's Equipment" to me too. But go with the flow - om mani padme hum :-).
Te audire no possum. Musa sapientum fixa est in aure.
fj100:
At what mileage did you modify your suspension with the OME (got it right this time!) stuff? It looks like they have some good products.
Added info - I would suggest larger tires because if you change out your suspension and not the tires it could look rather funny. I am running BFG AT's, 285/75 R 16 which is basically a 33 inch tire.
Scott
scott@mobi-arc.com
HiC
Also, does anyone know if "Glass Breakage" can be added if it didn't come installed from Toyota/Port? Is this possibly a relay that is a simple plug in?
That was two months ago when I received that feedback. Since that time, I have been using Lucas Oil Stabilizer in my crankcase and have not seen any further evidence of oil leakage or loss of oil pressure.
How long I can delay the recommended repair if I continue to see no visible oil leak? Please advise.
bucdaniels
Install chains on the rear tires as tightly as possible. Do not use tire chains on the front tires. Retighten chains after driving 1/4 to 1/2 mile. (not to exceed 30mph)
I have a 97 LC with 60K, when driving over semi-rough pavement I hear a rattling/squeaking sound coming from my front end, probably the front left tire area.. Could this be a noisy shock absorber? Is there an easy way to rememdy this annoyance?
Also for interior rattles around the dash board area, do you think the dealer can fix those?
Thanks in advance.
