Frankly, I think this absolutely sucks. The LC should be offered in wagon format and we should get the world vehicle, like we do today. The sequioa is a ford expedition in toyota clothing, a LC is a LC is a LC.
Luckily they will bring the 100 series in for 2004 so there will be used ones around for a while. The 2003 models are awesome with all the factory features that they should have had since '98.
Later,'
Andrew
Raleigh, NC
ARB Winch Bar
OME Lift
Sway away torsion bars
bfg AT's 285's
PIAA Fogs
Black Lab hair
baby gear
cheerios
http://www.pbase.com/roane10
Mine is the one under AR-LC. There are also some other modded 100 series up there. The green one is now running 35's.
Sway away torsion bars are heavier duty torsion bars used to raise the front in. I purchased them at www.sleeoffroad.com, look under products, suspension.
Later,
Andrew
Thanks for the help.
I have the 96 and until just recently, the 97 models. I also have the 94 model. I have a friend that has the 95 model. 94,95,96,97 models have performed very very well. If you want to buy on price go for the earlier models, if you want to buy on mileage that is ok also.The 80 series has been know to consume brakes (fronts) faster than say the 60 series. I could get 60k from a 1987 TLC and for the 80 series 45 is about tops.
If Toyota wants to kill the Golden Goose that helped build the company, then so be it. I just find it hard to believe these rumors. The Land Cruiser has been winning awards, Edmunds Editor's Pick, and God knows what else acolades from auto critics. It simply does NOT make sense to kill off an extremely popular model that took many years to develop a rock solid reputation. This has me scratching my head...go figure.
My spin on the LC here is......lots of rumors are saying no more, but these same rumors were around toward the end of the 80 series run and we got the 100 series. And as you say, why would Toy/Lexus get rid of such a legendary vehicle? They sell lots of them worldwide, so it's not like they've got to re-tool to make just a few for the US. My hunch is, we'll see a next generation LC here with a bigger engine, side air bags, nav sys, 18" wheels, rear viewing TV camera etc, etc as an '05 or '06 model. They may dribble in a few 100s in '05 and make the new series an '06?.
If the LC sales were so lousy, I think we'd be seeing some LC advertising and incentives. Don't know about your area, but here in CA, I've never seen any ads ala RR for the LC. Toward the end of the model year, I've occasionally seen 1 or 2 LCs discounted in a dealer's ad, but that's pretty rare.
Another thing, I don't think that Toy would just give up the luxury SUV market to RR. I've heard talk of Toy splitting off their truck/SUV lines for separate sales facilities. To me that "FJ" concept will be another vehicle in the Toy lineup.
I'm very guilty of inserting my own wishes here, but I hope I'm right and we'll see a next generation LC.
Maybe the marketing "problem" here is the fact that to some shopping for a Toy SUV, there isn't anything that separates the LC from the larger Sequoia?
Also, has anyone tried the Bridgestone Revo A/T tires? I am looking for a more aggressive off road pattern than the Michelin LTX M/S or Cross Terrains for snow, sand, and mud in the mountains. Tirerack doesn't give many other optioins. What is the equivalent tire size for the LC in the standard measurements (ex.: 33 X 10.5 X 16) to the stock 265/70/16? Thanks.
Stock tire size is ~31x10.5.
BTW: 275-70/16's are stock. You can run up to 285-75's without any suspension changes. No reason to go to flotations since there are quite a few decent off-road tires now available in LT metric.
HiC
Also, a tip on changing out the diff/Tcase. Loosen the fill plugs first, then the drain plugs. You don't want to drain the oil if you can't get the fill plugs loose. (24mm) As mine is lifted, I can access all of these without jacking, though the front one's pretty tight.
The best FREE off road mod for the 80 or 100 series is having a driver selectable center diff lock. Go under the truck, unplug one wire on top of the transfer case, tape up the end of the wire and tape up the connector on the transfer case.
This mod allows the driver to select center diff lock in high range or low range. In low range with the center diff unlocked, the vehicle turning radius is just like normal. This is crucial in tight offroad spots with these large vehicles.
2 Notes
1. Do not forget to engage the cdl when in normal low range situations.
2. If your 80 series did not come with cdl button, it can easily be added. The switch is $50 bucks and the install takes about 10 minutes, just make sure you tape up the end of your flathead screwdriver before prying the dash apart.
Later,
Andrew
Thanks for the response. That is exactly why I asked the question and the benefit I see of 5 tire rotation. I will probably try the Bridgestone Revo's unless something better comes along.
http://www.pbase.com/roane10/slater_rd_plt
Andrew
What is the brand on the boonie bar or whatever you call the black metal bar on the frond of your LC?
Thx. Bob.
It is an ARB Deluxe Winch Bar.
CHeck it out at www.arbusa.com
They're on the web too.
I've never gotten the first year of any car I've ever owned
I'm trying to figure out a fair offer for a used 2003 and I don't know what rationale or formula to base it on.
Some people deduct a number per mile. Anywhere from 15 cents to perhaps 50 cents.
You could ask the dealers who hang out in Real-World Trade-In Values. They'd know. Read back a page or two in there to learn what info they need to give you a good guess (miles, color, zip, etc.).
any help here would be appreciated.
When seeking parts or sources, it's a good idea to divulge year, model and country as there are some models that require specialty vendors some on the board may know of.
Bryan,
What you heard was most likely a vacuum being released as opposed to a pressure being released. When a sphere of warm air such as a hard working differential is submerged in cold water such as a stream or river crossing, a vacuum is formed that would pull water into the diff vent if it were submerged. Toyota put a one way valve atop the rear diff vent to prevent this.
Personally, I do not agree with this approach, as if there is a worn seal somewhere else on the rear axle it will pull water in instead. But I digress.
What this means is that both the one way valve on the breather, and the other seals on your rear axle are in good shape since clearly they did not even allow air in - essentially showing such integrity that they held a vacuum. No worries.
IdahoDoug
Thanks for the help,
As far as the clunk goes I have more info. I was reading in the Tacoma board and they talk about "Axle wrap" which is the axle torquing after a hard stop and giving a clunk when starting again. Also someone said that they put the tranny in neutral prior to going than no clunk, I tried this and it's true. If I come to a semi-hard stop and put the tranny in neutral I can feel some tension being released and then back in drive (very smooth no clunk). Does this tell you anything about my 99 TLC? Thanks, Bryan
You have an electrical problem that I think warrants taking the vehicle to a reputable auto electric shop for diagnosis. If the shift interlock does not get the signal (from the brake lights) that you have your foot on the brake, it will not let you come out of park. Probably not telling you anything you don't already know, but in my experience an electrical problem is best solved by a pro.
Bryan,
As you likely know, the Taco has a part time system, transfer case and shares no drivetrain components with the Cruiser's full time/center diff system. That their system also has a similar clunk lends credence to my feeling this is a normal characteristic of a 4WD system - slight binding after a brisk stop is relieved upon startup and causes a clunk wherever there is slack. And every system has slack.
The neutral thing is an interesting and simple step I'd never thought of. Had my head spinning trying to figure out what part of the system would be under tension and why it could not relieve itself without removing engine torque briefly. Interesting. Off the top of my head, I think the binding is in the differential(s).
Stop your truck briskly as would normally cause a clunk on startup. Apply the parking brake firmly. Let off the brake pedal. See if you feel that same tension being released, and have no clunk on startup. I'm just curious, so don't extend yourself or inconvenience yourself to do it.
IdahoDoug
Some Toy lit I have from when I got my 98 says up to 30". I guess that's doable - the air intake is inside the left front fender at least 30" off the ground and has some protection from wave splash and temporary (very temporary) submersion. Sucking water in the air intake can equal instant engine death so never enter any water unless you are sure of it's depth.
HiC
1. Would a 2 ton floor or hydraulic jack suffice?
2. I'm wondering if there is a better jack point or if anyone else has run into this situation. Having enjoyed every other aspect of this robust vehicle, I feel sure that Toyota must have designed a jack capable of fitting under the vehicle and raising a flat tire off the ground. Please reassure me that I'm not wrong.
That's interesting. I'll have to give that some thought.
Ukroma,
Are the wheels stock? That does seem very un-Toyota ish. Was this on absolutely flat pavement, or were the right wheels in a runout area? Interesting.
A 2 ton jack would be enough, though if you can find another one with a higher rating that's still able to fit you'll have a safety margin.
Of course if it were to happen again you might gently run the flat onto a board, pile of gravel or small rocks placed in front of the tire to lift the axle enough for clearance.
IdahoDoug
The wheels and tires are stock, as is the entire vehicle. I was parked on the road surface, at the side of the road - there was the usual camber designed to channel rain water towards the gutter. I could have jacked the left (inflated tire) wheel easily by placing the jack to one side of the differential EXACTLY AS ILLUSTRATED IN THE OWNER'S MANUAL. It simply would not fit under the other (deflated tire) side. I'd be more than happy to demonstrate this apparent shortcoming to any TLC designer in the Malibu area.
Thanks for the tip on jack specs.
I'd really appreciate your thoughts on this matter.
