Also, can I unlock the steering wheel and shift the auto transmission into neutral without power? I need to move it from its current location.
On the fuel filler problem someone mentioned: this is a common problem. They had a TSA on this and fixed my filler nozzle for free. You might want to check into it. This problem still occurs for me, but pretty infrequently now. It helps to pump more slowly.
One question I had is on the cruise control. Mine stopped working recently but I think it is just because the switch is stuck. Does anyone know how to get at that switch in the steering wheel? I'd like to try and clean it out without paying the dealer $300. Any ideas?
I have a 04 Tribute with 31K miles on it (warranty ended 8/1) that has pulsing of the breaks occasionally. I brought it in to the dealer and they told me that the exciter ring was cracked and to fix it I would have to replace both axles... $1K to repair.
They also told me it was time for a break job and that would be another 450 because the rotors need to be replaced....
Can anyone give me some advise? Is it possible to repair the exciter ring without replacing the axle? Also, why would both axles need to be replaced??
Thanks for any information!!!
i think the exciter ring is part of the ABS system.
my non professional opinion is that you would also get a warning light.
when you say occasionally, what does that mean?
I think you are right. The dealer is trying to get this covered under the warranty that expired in August (not sure how hard he'll try).
It only happens at low speeds about every 20 times that I use the breaks. If I release and let it reset it will stop.
I am reading that Mazda can not replace only the exciter (or tone) rings and they have to replaced the front right and left axles. It really sounds crazy to me for me to shell out a G note for a vehicle with 31K miles on it.
If I can't get the rep to warranty this I will take it elsewhere forever...
I may be able to find someone that can install them.
Has anyone else who owns a Tribute or Escape had this issue?
Thanks to all!
Just curious... what state are you in? and what milage did your exciter ring go at?
Thanks for the info...
THanks! Tom
Here are some the problems I've had.
O2 sensor failed leaving me stranded on highway.
Brakes: dealer (Phillips Mazda, Laguna Hills, CA) reported rotors were not turnable and had to be replaced at first pad change. No way did I run the pads to the rotors. $600 for a brake job?
Alignment & OEM Contintental tires: really bad road noise, bad tire wear Took to dealer many times but they didn't find anything wrong. Finally, took car to a Big O, they found alignment to be WAY off on all 4 wheels - required two shim kits to fix. Conti's were destroyed. Yoka Geos perfom much better.
Catalytic converters: There are three. One behind the engine cracked (or was venting?) at 79K, thankfully dealer did the right thing and replaced the unit. However, right after 100K miles I started noticing a major power reduction (had to drop to second to get up hills). Dealer diagnosed the problem as the alternator. Turns out it the other two catalytic converters were disintegrating and clogged the exhaust flow. $1300 not covered by warranty. No one knows how that happened. Hopefully, engine was not damaged.
Transmission: at about 105K miles, check engine light went on at the start of a road trip. Trany was burned up and one of the OD gears was broken - I have trans cooler. $3900 at independant shop
Brake calipers: warped and needed replacement $600
I really like my Tribute. I've done all the scheduled maintenance, but it has seemed to have a LOT of expensive repairs. My last car was an Acura Integra that never had an expensive or major repair in over 200K miles.
I'm in the market for another small SUV and I'd considser buying another Tribute or Escape, if they have solved these problems. Are the later models more dependable?
I have an '05 AWD 6 cyl with 52K. I drove it on the highway yesterday (in very rainy weather) and I used the cruise control for about an hour. Everything was fine, but on my return trip home, the cruise control wouldn't shut off. Even though I pressed the Off button, the car still ran at 65 miles per hour all by itself. When I got off the highway, l braked as hard as I could, and I could barely hold the Tribute back from going through the intersection. When I put it into neutral, the revs got to 4000 and stayed there. I managed to get it home.
This morning, I started it up in park, and it was not revving, so I put the car into drive. I didn't press the gas pedal, and the car coasted along slowly. I braked and put the car into neutral and it didn't rev high. Then I put the car into drive, put my foot on the gas pedal, and the lurching/high rev problem started again.
you asked some good questions and got no reply.
hope this helps.
Ignore the guy who thinks you are "making it up"; he must be either very young and foolish--or very lucky.
I traded my RX-8 ("internal engine failure" :lemon: ) in yesterday for a 2005 Mazda Tribute. This is my third Mazda, and I have never received a single TSB or recall notice from Mazda. This is especially troublesome when I purchased new, but now I am wondering where/how I can get my hands on the TSBs or recalls for the Tribute. Any suggestions? I know from experience that mazdausa.com is worthless as far as posting them.
Thanks for your input!
Deaun
TRIBUTE BULLETINS
In anyway, here is the Ford part number and price.
Part# YL8Z-7E395-BA
List $64.99
2-Hour Labor at $85.00 (average) = $170.00
Part - $64.99
Labor - $170.00
Total - $234.99
I think your are getting overcharged.
I think your getting screwed on the price....just my $0.02
Thank You.
once I am stopped. Did you all ever find out the cause of the problem? I have no confidence in my dealer either. I don't want to spend a $1000 just for them to misdiagnose the problem and be without my car for a week.
