Unless you REALLY think you're going to need them, suggest you add some suspension/tire mods then see how it goes.
I have gone back through a lot of the posts related to the FJ-80 and have copied and pasted them to a Word Document, so I feel pretty comfortable knowing what to look for in terms of future problems. The dealer also offered the car with a 2-month / 2,000-mile warranty, and with a month or so left, I am planning on taking it back in to get some things looked at.
I do have some questions that if anyone can provide answers for, I would be most appreciative:
1. The owner's manual says that I only need to let the engine warm-up for 10 seconds in non-freezing weather. I let it warm up for roughly 3 minutes anyway, but I have noticed that the transmission hesitates to shift from 3rd gear to 4th gear when I am in the 40-MPH range UNTIL THE ENGINE HAS WARMED UP ALMOST TO "NORMAL" TEMPS! Up before the shift point, the engine RPMS run almost as high as 2,500 RPM when normal shifting from 3rd to 4th in that MPH range takes place before 2,000 RPM. In terms of strategy, i.e., dealing with the dealer and what is essentially an unlimited warranty, what do you think I should do? Any idea what the problem may be? (When the car is "warmed up" to the middle level of the temp gauge, it shifts fine.)
2. My serpentine belt (I am calling it that because that is what it looks like at the front part of the engine) is squeaking significantly. The quality of the belt looks quite new actually, and I have heard bad things about using belt dressing, as supposedly it tends to hasten the belt's wear. Any idea of what may be causing it? What remedies do you think I should / could seek from the dealer?
3. I bought the car with 265/70/16 tires, not the recommended 275s. I noticed at a radar trailer that we have around town that my speedometer was 4 mph BELOW what the posted speed on the radar trailer readout was. Does that sound right, and are there any potential risks to running the 265s? The wheels are stock TLC wheels. I plan on getting the 275s in roughly 10-15,000 miles unless something necessitates an earlier purchase.
4. The "Check Engine" light came on soon after I took possession of the vehicle, and I took it in and got it fixed under the warranty. They replaced two oxygen-related sensors but said that the light remained on. Then they said that they cleaned out the throttle body and it turned off. Does that sound right?
Do you think that I have any recourse concerning the first two questions?
Again, thanks for any help!
2. Sounds like you just need to have the belt tension checked.
3. The 265 tires are slightly less in diameter than the 275s and will result in a small variance between actual speed and what your speedo says.
4. I think the oxygen sensor replacement was probably a warranty item. I believe there have been some cat warranty replacments on the 80 series. Don't know what realtionship the throttle body cleaning has to the check engine light, but.....maybe they forgot to reset the light the first time and reset it after cleaning the throttle body.
Based on the limited info you've provided here, it sounds like the dealer has been responsive to your concerns in the past. Suggest you go over the items that you've noted here with them and see how they respond.
I don't think you've got any thing major going on or any reason to be worried. Seems like some minor tweaks are all you need.
I am pretty impressed with the vehicle so far -- also some of the technology that is in it (I'm not really into new cars so things like VSC and traction control go way over my head).
What is your take on using the "Power" button? I know what it does, but I can't figure out why the vehicle has it. Also, even though I am in NC, I am eagerly waiting for some snow to drive in. Does the "2nd" button really need to be used in snow since the vehicle has full-time 4WD?
Again, thanks.
Thank You
Re: tire sizes with stock suspension 285/75/16 tires will fit and shouldn't rub. Not sure about 295, 305. Some lift is probably a good idea for anything larger than 285.
HTH
I need some help here. I have a 2000 LC I bought for $27,000 in May 03 with 50,000 miles. I have 76,000 on it now. It's a great vehicle. I live and work in town and when I leave town it's on a motorcycle or a plane. So I drive the beast to the post office, grocery store, etc. Put some work related miles on it too. I don't have kids but have a large pooch who loves it. I like to hit dirt roads, logging roads, powerlines, etc here in VT on weekends and use it in the snow, like today! It'll be paid for in a few months. Last month's gas bill was $275.
Am considering: a) keeping it forever, getting an around town car, like a used Toyota Matrix, Honda CR-V, etc, or b) selling LC and getting new 250hp Subie outback.
Problem is, I hate to get rid of such a great vehicle, but don't really need two. I know, good problem to have.
I you have any opinions, would like to hear em!
BTW-had serpentine belt replaced today ($90) and mentioned to mechanic my lousy (12mpg) mileage..he thinks I over-oiled K and N filter and mass air flow sensor is gunked up, giving poor fuel mileage. Sound plausible? Thanks for any thoughts here too.
Only today I was on the Freeway and noticed the BMW SUVs, MB SUVs and Porche Cayennes and how FAKE they and presumably their drivers are. These folks are all just imitating the REAL DEAL.
BTW, the gas mileage you're getting seems pretty low to me. While my mpg (also 2000 model, 65k) has dropped slightly along with the temperatures, I rarely get fewer than 15 mpg around town. I get as much as 19 on longer trips. I'm driving it softly, though.
Pull down your driverside sun visor and its all discribed there for you
H- is High, good for on road and most all conditions, and will duns all four tyres with the center differential unlocked (open).
N- Nutral Switch gears only while in park or put the tranny in N and set the parking brake
L- Low, this is for off roading or very low traction surfaces. The Low function will automaticly lock the center differential spliting power 50-50 front and rear.
A/T P light and DIFF LOCK light will come on as will as Anti lock brakes light i cant rememeber. This is supose to happen, nothing to be worried about.
Word of advice, never use Low on the street or any high traction area, it will damage your center differental as well as rub your tyres alot. Use it only in mud or off road.
http://members.tripod.com/ri_rav4/rattle.htm
http://members.tripod.com/ri_rav4/rattle_tsb.htm
-Ironside
On a recent trip that included driving through far NE California, our AM radio reception was really hurt by ignition interference. It was just like years ago. I wonder if there is anything I can do about that. In the old days I would have gone to resistor plugs and changed the high tension wires but I don't know what to do here. I am afraid to get at all frisky, partly because the computer intimidates me.
We don't think it is worth upgrading the radio but is there anything in the way of an ignition oriented fix in this day and age?
any idea and input is very much appreciated, thank you.
The other choice was a used Mercedes ML320; but the reliability was definitely a concern with the ML320. In order to reasonably afford the Land Cruiser (I'm trying not to spend more than about $18-$19K) - I'm looking at buying one with about 80K+ miles; perhaps even closer to 100K miles.
Anybody that could give advice on specific model years (98 or up) - dos and don'ts - stuff to look out for - where to buy (dealer versus private party) - maintenance or repair hassles - etc; I'd greatly appreciate it.
The one expense I got hit with was the timing belt at 90k which if I remember right was about $500-$600. You should ask if that has been done since the mileage you are looking at is right about the mileage that requires the timing belt change.
Other than that, I think you'll be very pleased. I was so pleased I got another one, a 97 to play in the woods and mud.
I got a 2000 LC in July, private party, with all records. I would take a private party, original owner with records over dealer any day. With the dealer you have no idea where the vehicle is coming from, most are from wholesale auctions, and who knows what it looked like before the mechanics and detailing people got their hands on it. I don't ever believe the "it's a trade-in, I know the previous owner personally" line. If you run a Carfax report on that "local" trade-in, more often than not it was listed at an out-of-state auction just a few weeks earlier. That's probably why they never show you service records, you would be able to tell that the car was registered somewhere across the country before.
In my case, after looking at the records, I called the dealership where the previous owner had it serviced. He always brought it to the same place, so they knew the vehicle since it was new and were able to tell me from their records that I'd be hard pressed to find a better maintained vehicle. Great if you can find one that has had the 60/90/120 K service done recently, I hear they can run over $1,000.
Dealers are offering $19K in trade. Seems to me that a 2000 LC in good condition might sell for around $24-26,000 in a private sale. I paid $28k in May 2003, 50k miles, at auction (local used car dealer got it for me).
Questions for anybody that has sold an LC: what kind of price did you ask and what did you get, and, was there much interest in the vehicle? I'm not in Greenwich, CT where the LC is probably in demand..here in Vermont most people are driving Subarus.
Last question, do you think there is better or worse time of year to sell the cruiser? Thanks again for any responses!
This might be helpful also: TMV new car prices, used car pricing, used car values at Edmunds
Conventional wisdom has it that SUVs sell better in the winter. I personally can't say that I have seen much of a difference in how long they stay on the market between summer and winter, or in price for that matter. The one problem a private seller will always face when selling a used vehicle like an LC is that the stars have to align perfectly. It has to be a cash buyer, for most banks will not finance a private party sale. And then the buyer has to be willing to pay as much for a 4-5 year old LC as he would for a brand new (albeit lesser) vehicle like an Explorer, which comes with low financing, factory warranty, and so on. I never sold one, but I know from the perspective of a buyer and watching private party listings being up for months on Autotrader that there aren't many buyers who fit that mold. If your car has a clean record (check your own Carfax if you didn't do it when you bought it yourself), then I would recommend pointing that out in the listing. If it qualifies for the Carfax warranty, point that out as well. Extended warranties that are transferable also seem to be attractive to private party buyers. Like I said in an earlier posting, if you have service records then that can be an advantage over dealer listings as well. And you'll want to make sure that yours is quite a bit lower in price than any dealer listing (and preferably other comparable private party listings as well).
Unquote
A further point on financing, its my understanding that in some states banks cannot legally lend against a vehicle over 5 years old or 60,000 miles at the date of the loan - so if wintercruisr's LC is over that threshold it'll be harder to find a buyer with just cash.....
link
A co-worker is looking to sell me his '96 TLC with 70K miles. Since I know nothing about TLC and SUV, what should I look out for?
1) This is a silly question, but what kind of mpg do you get? 15?
2) How is the A/C? Is it strong?
3) How is the transmission?
4) Do the brake pads wear out easily?
5) Is it expensive to insure? I live in CA.
6) Anything I should be aware of?
7) What can go wrong at 70-90K miles?
TIA! (Thanks in advance)
The more I hear about used ML320's...the more I want to stay away from them! Pretty much everything I hear about the Land Cruiser has been positive. I like the BMW X5, but they are just too darn small - not to mention too pricey! Even a used one with a ton of miles still runs mid to upper $20's!
If so; will the "old body style" 98-04 models take a hit in value on the used market? Not sure if it's a good comparison or not; but that's what happened when the "new body style" Tahoes/Yukons came out in 2000. Everybody wanted the new body; and the old (pre-99) values sunk like a rock.
I'm looking at buying a 98, 99, or 2000 model - so if that's true; I'd be better off waiting until the new body style comes out...true or false?
A bit of history on this subject - I myself bought my Fj80 in 1990 when the body style changed - my expectation was that the new shape would continue for 15 years or more - and I was right. (btw, while there were engine and other cosmetic changes through the years - the basic shape was the same between 1990 and 1998/2004) As I recall the value of the model prior to 1990 didnt sink like a rock at all - became a collectors item if anything.
http://www.supercars.de/data/toyota/2003fj%20cruiser/480/009.jpg
On a positive note; I didn't realize that a lot of banks can't or don't lend money on vehicles that are 5+ years old or have a certain # of miles on them. I am saving up and planning on paying cash for a used one - so knowing that bit of advice helps me out in the bargaining department quite a bit!
The FJ is, IMHO, designed for another niche ala the Scions etc. The Highlander seems to me to be a compliment or mabye competition for the Sienna?
LX only version of the LC has been rumored for a long time. People thought this was going to happen when the 100 series was introduced
2007 Toyota FJ Cruiser 4X4
Check it out.
You're right--if that happens..............well, I don't want to think about it =(
My gut feeling is that it's not going to hapen, but what the heck do I know!
http://www.toyota.com/vehicles/future/ftx.html
It might make sense to have the two versions (LX and LC) sold by one "brand". It might simply be called Landcruiser and Landcruiser LX? And let Toy continue with the SQ? The LC/LX platform has obviously become the luxury sport ute for Toy as it's gone from FJ to wagon to luxury SUV over the years.
I'm far too guilty of "forcing" my own preferences into my speculation! But I just find it hard to believe that Toy will reduce the luxury content of the LC/LX. Just have a feeling they're going to wow us all with the new one--whenever it comes out.
Here in Connecticut its so cold that the middle seats will not stay down - I am guessing that the metal bars in the floor and on the clamp mechanism at the base of the seats that usually grip around that bar have shrunk below the minimum and cant grip anymore (I am sure that explanation is as clear as mud!). So the middle seat passengers pitch forward when the car stops... I dont have my third row in right now but this might happen back there as well if installed.
Also, anyone ever use a block heater - I seem to recall that some LCs were made with a block heater capability.
