About the Maintenance and Repair Message Board
Please consider reposting your question here:
Zaino Car Care Experiences
We have a VERY active Zaino topic here in Maintenance. There are also several archived topics that are referenced in the first post of the conference.
Your host, Bruce
1. Is it true that Hondas & Toyotas routinely (if maintained)last 15 years/250K miles?
2. If that is true, it is probably based on Civic & Accord, can one extend that to newer models like CR-V?
3. Can the same thing be assumed about other Japanese/Korean cars such as Subaru and Hyundai?
Today I went to my Honda Dealer for the first oil change and was surprised to find out they use Penzoil. Comments???
We are fortunate to have an experienced Honda tech hanging out in our Honda Accord problems topic. It would be a good idea if you reposted there to see what he thinks.
Just click on that highlighted link to get there.
Pat
Anyway making a long story short. They gone from 2700.00 to 1700.00 to replace the engine to 680.00, because I got on the phone and found a motor for 550.00.
Is there any one out there with a similiar story Thanks
Chris
GM Info
Check engine topic
I'm sure it would be better there.
Service at this dillership is notoriously bad. I have another VW car - new beetle and any time I went there to do something they managed to screw it up. And I had to leave car with them for an extra day.
p.s. I had the transmission replaced 8k miles ago,and the timing belt changed 3k miles ago
thank you for any information you have
I have a 93 galant, afterdriving it a while and put it in park the engine revs to 1700 rpms, i also noticed the temperature started getting on the hot side. I changed the antifreeze and the thermostat and the fan is working. a machanic checked the battery, I changed it it was 5 years old.
fyi i replaced the water pump 3 months ago if this means anything. Im going back to the shop this weekend so if anyone feels lucky I'll appreciate your input.
"siesserg@gruntal.com"
There are some folks discussing scratch removal right now in Store Bought Waxes (Topic #1038).
You might also like to look through the posts in Paint and Body Care (Topic #20) and maybe even Zaino Car Care (Topic #1319).
I'm sure we've discussed scratch removal at some point in Paint and Body Care. Zaino is a specialized car care line of products. There has been discussion in that topic (and its precedents) of a particular Zaino product designed to address fine scratches.
Pat
Meanwhile, I have one more thought - if you do a "Topic Search" (left side of the page) on windshield I think you will find some archived topics on how to get scratches out of windshields. Maybe they would be helpful with mirror scratches as well?
Hope you can get it taken care of.
Pat
Here we go guys, my engine started flipping out after I drive for 20-30 min and put in park, the engine starts reving crazy, eg:2100rpms to 1500rpms to 2100 rpms and so on. In the morning its perfect. One machanic sayed a new idle/air control motor would solve the problem for only$450.00, sorry kids no dinner tonight. I would hate to go to the dealer we would'nt eat for a month.
Has anyone had the same expirence, or can anyone recommend something else.
I dont think its the IAC-motor cause its fine in the morning???
ANy machanics out there???
Mitsubishi Code retrieval
Hope it helps.
Thanks Again
complete tune up done and fuel filter changed last
year. The air filter is new too. However, of late
the car has been hesitating and sputtering (as if
it is almost going to stall) at idle, low as well
as high speeds of 45-50 mph. However, once I am at
55-65 mph, the car runs steady but is not as
smooth as it used to be. The ride is a bit rough too. I suspect that the air/fuel line is dirty. Not sure what is the exact problem. This also happens almost everytime it rains. I plan to add some additives to the fuel and clean the air system. Not sure if I have to clean/replace the filter in the tank. If anyone has any idea what the problem could be, I would appreciate a response. Thanks.
If not, you might want to repost there. It would be a good idea to include your model year, by the way, and any other pertinent details like whether it is a 4 or 6 cylinder engine, or any other descriptive data.
Pat
You might want to look through the posts in this topic: airconditioning (Topic #194).
If you don't find an answer, you might even want to repost your question there.
Pat
Thanks, Jackie
engine would shut off while I was driving. The
electric would stay on but my motor would shut off.
Pretty scary! They narrowed it down to the
computer malfunctioning and replaced it. No
problems so far. I had an alarm system with auto
start and a cd player installed within a week after
having the car. The dealership said the wires on
my alarm system were just tied together not sotered
and that this could have jolted my computer. I
temporarily have my alarm and auto start
disconnected to see if the new computer acts up.
Does anyone have any input on the situation? Please
help me!
By cleaning your engine,how are you referring?
Cleaning it externally?Or these ripoff flushes,that supposedly flush the oiling systems?
First the car started stalling and engine check
sign lit up. The car started stalling and low oil
pressure sign came up. I checked under the hood and saw coolant all over with very little oil.
My mechanic says that there was a oil leak at the
distributor o ring area and the fact that I lost
so much oil ( i did not see any puddles in my
driveway) says that the car was burning lot of oil
and the reason may be due to clogged up air
filter. Can a clogged up air filter make the car
use lot of oil???? I would appreciate your input
into if the mechanic is right. ALso do you think
using synthetic oil is better???
Thx,
Jyo
There are a few topics in this conference that may interest you. Here are links to the ones that come to mind:
Honda Accord Problems Part 2 (Topic #1398)
Synthetic motor oil (Topic #543)
Engine Oil - A Slippery Substance Part 2 (Topic #851)
Take a look at the posts in the Accord topic - it could be you will find something helpful already discussed. We are fortunate to have an experienced Honda technician hanging out in the Accord topic, so if you don't find anything helpful in the previous postings, I encourage you to post your question there to get his input.
The other two topics both contain a lot of discussion about the merits of synthetic vs. dino (regular) oil.
Two of those links have "Part 2" in the topic title. This indicates that there is a previous discussion in our archives - the previous discussion will be linked in post 0 of the current topic. So there is lots of information for you to read up on.
Good luck, and again welcome!
Pat
Have a look in this topic:
MAZDA PROTEGE PROBLEMS
and you may want to repost your question there.
Your host, Bruce
