Cougar Support Group - Modifications
Going from 3rd to 5th is no big deal. Once you reach over 45 mph, you can put it in 5th. Although I don't generally skip gears except on a downshift.
However, a friend of mine has a '95 mtx Corvette. It's got a light on the dashboard indicating when to shift to 3rd gear from 1st gear (so you're supposed to skip 2nd gear). His car also has 6 forward speeds, so maybe that's why it does that.
But for the Cougar, there's really no reason to skip gears. I wouldn't recommend it.
Well not really, I am away working and using someone elses Internet account.
Anyway, I am now glad that there is an affordable aluminized tubing alternative to the Borla. I will probably order one after my wedding (5 August).
I remember when I had my aftermarket muffler installed on my car. The guy told me that Borla is usually the first on the block with products for new cars, that way they can charge the prices they charge and get away with it.
Road racers wil also use this technique for fuel conservation if not being pushed hard by teh competition.
Ain't stick shift fun????
Skip G.
Skip G.
I thought that if you were in too high of a gear for the speed you were traveling you end up being less efficient because to accelerate you push the pedal down farther to get moving quicker. I know you could downshift for those occasions (which seem to come up often). But then I was thinking that it might be harmful for the engine (not the shifting), because if you dump that much fuel into the mix it won't burn off properly, right?
I'm theorizing here, so set me straight. I would like to believe the Duratech is technologically advanced enough to protect itself from that, but I know older engines would suffer some.
Set me straight Skip. :^)
2. Downshift if necessary for better accelleration. Trying to pick up the pace in a higher gear while moving slowly lugs the engine (an old term) and may cause pinging or knock, even though the computer should prevent this by retarding the spark until the revs are up in the proper range for effecient operation.
An automatic transmission always keeps the highest gear until you step on it, and then it downshifts for better accelleration
3. Downshifting for accelleration is what the stick and clutch are for!! While the fuel mixture is richened, it is correctly burned as more air is also supplied, and the spark advance is also advanced to provide more power and an efficcient burn.
Carbs supplied the extra fuel via a part called the accelerator pump, the throttle plate opened, and the vaccum advance provided the spark timing. This is now done by the computer.
Easing along in a higher gear causes no problems or damage, and is the best thing to do for fuel economy. Use a light foot, and be prepared to shift for the demands of whatever occasion comes up.
Don't jump on it untill you need to, and just cruise around nice and easy. It'll last longer that way.
(Professor puts away pointer)
Skip G.
I've been called one of the world's largest storehouses of useless knowledge, but once in a while it comes in handy
Skip G.
Although I believe they could do a lot better for us if they had Automotive Jeopardy. They had Rock n' Roll Jeopardy, so it's not unfeasible -- they just need to put it on Speedvision.
As an alternative to a 200hp V6, what do you guys & girls think about a 6-speed MTX in the Cat? If this was geared properly, I believe this would improve the pick up of the car, thus improving the overall performance.
Any thoughts?
PS
Does that make Badulah as Giligan???
A 6-speed sounds cool, but the Duratec engine doesn't really rev that high compared to V-TEC or VVTI (in Celica). I'd still prefer more horsepower than extra gears anytime.
Do you think the 6-speed would have any benefit over the current 5-speed? Keep in mind that the Duratech is currently rev limited very low. If the 6-speed were ever put in, I think they should raise that limiter to 7,200 rpm.
I know some of this may sound outlandish. I'm just trying to gather new ideas.
More power. More power everywhere. That'll do it. Either that or 500 lbs. less car.
As was noted, though, it won't happen. Too bad.
I think in 2003, they're planning on changing the Focus chassis to a larger platform (one that's going to be shared with the 2001 Mondeo due out in September in Europe). Since we've heard rumors about the current model Cougar going away in 2003, I think it's feasible that FMC would redesign the Cat to fit on a slightly smaller platform than it's on now, and with less car overall, that might reduce the weight. If at that point they decide to keep the Duratech V6 for that car, then it'll have shed that 500lbs. and you'd feel that difference even at 170HP. There is no truth to the above, it's just my speculation.
What do you think?
I meant other than the "S" that's coming out in September.
I wonder if that engine would fit the Cougar and what the weight differential would be!?!
http://www.newcougar.org/images/FO-302etc.jpg">
Side markers are $39.00 for a set. Three colors to choose from: Clear, Smoked, Black. Prepaid orders only. If you are interest, send email me to orders@newcougar.org
Side markers are $39.00 for a set. Three colors to choose from: Clear, Smoked, Black. Prepaid orders only. If you are interest, send email me to orders@newcougar.org . Please put 'Side Marker' in the subject line.
I think you're right.
All:
Since when were yellow blinkers not enough? What's next, clear Cougar tail light lenses? Yeah, right ...
You know what they say, three is a charm.
Those markers are not DOT approved, therefore are illegal here in the US.
The stock orange lense is ugly and looks like a pumpkin decal on a black cougar. Whereas the clear/grey lense gives a nice contrast on the colors of a cougar. (I don't care for the black lense)
Now if the stock sidemarker was the SAME color as the reflectors in the headlights, then it would have looked alot better.
Sorry, I have never seen one.
Where are these pics posted?
www.your1source.com/couga...etter1.jpg
www.your1source.com/couga...etter2.jpg
http://www.your1source.com/cougar/mods/images/DualPacesetter1.jpg
http://www.your1source.com/cougar/mods/images/DualPacesetter2.jpg
They look really good. I'm excited now to hear them! Badulah, when is your kit coming in?
It appears that the Pacesetter is really a large single muffler with dual tips as opposed to a single pipe splitting via a Y-pipe into two mufflers like the Borla or the Dynomax.
I could see how the Borla could increase flow but I wonder if the Pacesetter would give much better performance than my current exhaust that consists of a removed resonator, and and aftermarket muffler.
Also, in the NECO message board I even read a post that said the Pacesetter LOST horsepower. I don't know if this is true or not. If anyone has any other information, or opinion I would appreciate it.
It's a really eye-opening topic, although I think I gained something by bolting on the Borla. I'm probably just blowing smoke up my own kilt, because even Borla says they won't make a kit for a car unless they can achieve proven gains in HP and/or torque.
I also read that Pacesetters rust.
Based on what I have read, and seen, of the Pacesetter and Dynomax systems I might be better off paying to get a custom dual done at the muffler shop. I think (if I recall the right price) I could get it done for about $120.00.
$120 sounds like a song! I remember when I had a 67 Mustang that the pipe rusted through. It was an I6 with one pipe, and I had Meineke make me a custom Y-pipe split dual for about half of what it would have cost to put original equipment on it to replace the old pipe. Interesting that two mufflers and some custom bent pipe cost less than one muffler and a pre-bent pipe.
Good luck, keep us informed.
I don't want to become a poster boy for the Beaterz site. Yellow = performance
