Suzuki XL-7 Electrical Problems
We bought a 2007 XL7 two weeks ago. The second day we had the car the battery was dead. Had it replaced and then the charging system was not reading over 12.3 volts while running. Replaced the alternator but the car still ranges from 12.3 to 14.2 volts while running or idling. Last Saturday the front control stopped working. Could not change the radio, a/c or any other centrally located controls. We had a 2004 XL7 and it was great. Our vehicle was manufactured Nov of 2006 so it was one of the first out, anyone else have electrical bugs? Oh yeah, I almost forgot that the speakers pop like something is grounding out everytime we open the doors. I ran a Suzuki Motorcycle dealership for almost 10 years and have never seen anything this random in the powersports world. The dealer said he has replaced batteries in 3 other new XL7's. Did I get the only XL7 with Gremlins?
What voltage were you expecting?
SUVs and Smart Shopper
Ivan
The engine is built at the Suzuki plant in Sagara Japan based on GM's aluminum V-6 used in the Cadillac CTS. The platform, while similar to Equinox, is stiffer, longer, and a skosh wider to accomodate a third row of seats. (Note: GM now only owns about 3% of Suzuki stock).
It is assembled in Ingersoll, Ontario, Canada.
I don't own one, but I am in the market for a new vehicle, and this one is quite intriguing. :shades:
One night we were out in the car and all dashboard systems, radio, thermostat and heating went out. Stop in a station, shut the car down and started it up again a few mnts later. It worked fine. Its like Windows having problems with your computer----- "Hit Alt --Ctrl --- and Delete". Sometimes if someone is sitting in the passenger seat the air bag sensor light stays at off position. I saw something on tv a week ago about other car brands having the same problem so they did a recall. No recall on the suzuki. Its the same set-up and system other cars are using. I would check to see if other cars are having the same problem and they had recalls on this. Since all car manufacturers are using each others technology and parts it could happen.
Is anyone else having the same problem.
I have a '04 XL-7, 63k miles, passenger airbag light came on and stayed on whether seat was occupied or not. Took it to the dealer. He said the sensor in the seat frame goes bad. I asked how much the sensor was, expecting something like a micro-switch. He said no such thing, whole seat frame has to be replaced, $1300. That was last month, I've done nothing to it yet. I'm thinking I may take the seat apart and check it out myself, dirt, loose connection? Local Mech. won't touch it due to liability issues. Another issue: clock/temp blinking, won't reset. I suspect the computer? Another issue: clicker (remote door lock/unlock) stopped working, took it in. The dealer said if the little sensors that detect the doors being closed get jammed up, or dirty, the clicker won't work. I took rubber covers off of each one and 3 out of 5 not working. Sprayed with wd40 and that solved the problem.
Thanks again.
Hill
Vehicles are so technically advanced now from when I was a kid tinkering with cars, It's just amazing. I guess the good side is that they are much more dependable, but when something goes wrong, a person has to get a second mortgage to fix the darn things.
Good luck on yours too.
Ken
What a joke! I wish more than anything I'd never purchased this nightmare.
It is in Brea, California if that helps....
Also notice a sand paper sound coming from steering wheel and the air conditioner makes a funny gurgling noise.
I hope this will help you solving your problem.
thanks -patt6-
The strangest thing happened last night. After driving for about 30 minutes, I made a sharp right turn and water (odorless, colorless) leaked all over my right foot near the gas pedal! It wasnt a lot, but it definitely startled me.
I had used the windshield washer fluid to clean off some dust about 15 minutes before it happened but It had never leaked before (even with rain) so I'm assuming it has something to do with the A/C. So strange.
dickdidit@earthlink.net
