Nissan Rogue Start and Stall Problems
Ok I do not think this is transmisson problem Last Friday while driving around 35mph my 09 rogue stalled without warning, tried to restart at least 10 times car would start for about 3 seconds and stall again. Had it towed to Nissan dealer where they did not look at until Monday, of course it ran fine and had no codes stored so was returned to me. With no explaintion of why it happened. Of course I think it is sure to happen again, has any one else had this problem 2009 SL FWD
http://wheels.blogs.nytimes.com/2010/10/28/nissan-recalling-747000-cars-in-the-u- -s/
its the ipdm, there is a fuel pump relay in the ipdm that can not b accessed...if it sticks u will prolly have 3v at the fuel pump fuse as the problem is happening or no voltage at all. Replace the IPDM(independent power distribution module) and ur having no more problems.
I have a 2013 Rogue and lately after I've been driving it for a while sometimes when I come up to a red light and then I want to start again I accelerate slowly and it starts jerking like popping then I have to press down on the gas pedal for it to go. Also when I've been driving it a while and sometimes uphill I'll press the gas the RPM revs up but the speed will not go up and it'll actually decelerate. And I'm about 3 days ago what's happening now is after I've been driving it a while for example go to a gas station turn it off and then when I come to turn it back on again it'll crank and crank and crank with the lights on and everything but it will not start. Only when I wait for about half an hour then it'll start up again. Does anyone know what's going on if you guys had these problems what are the issues what are the fixes please help
Today with 115k, it got the 2nd problem. It stalled at about 35 mph. After pulling to shoulder, it fully died. Cranking was like it was not getting enough gas. Cranking after waiting 5, 10, 15 minutes and more, it acted like no gas was getting to it. It is at a garage now.
