i avg around 22-24 with 80% city driving.
Not all but maybe quite a few.
It has recently developed a problem where the steering wheel vibrates/shakes when I go above 65 mph on the freeway. This vibration was not present earlier and the car was very smooth.
I feel that this problem started after my car got stuck in some thick snow in front of my apt once or twice and we pushed it out a bit and handled it roughly. I don't know anything about cars. What could be the reason for this ? I have not yet asked the dealer. Kindly shoot an email to rampaps@yahoo.com also.
Thank you very much !
How do I check and remove the snow/ice from inside the wheels ?
Do you mean to say the inner surface of the wheels under the car ?
Will a carwash help to get rid of the snow/ice ?
Kindly let me know.
If you have steel rims, I guess you could take off the hub caps and knock the snow out.
Hope that helps!
Dinu
1. he has all the necessary tools at his disposal
2. and the factory manuals, tsbs, etc.
3. and I usually do not like to get my hands dirty ie no grunt work( I only like to use my brains)
in all almost all the case, i end up going to the service center and clearly indicating what I want to get done. I don't go there and say "dude, see if there is anything wrong with the car. if there is fix it". No sir.
I go and say "Dude, this is what is wrong with my car. So fix it".
needless to say, i benefit from the much needed "inside" help from Malt.
Usually, they have the least experienced techs do these jobs, as they're fairly easy. After having a couple of drain plugs cross-threaded and the wrong amounts of oil put in (and having lost 2 of 4 screws on my air filter cover), I decided I'd had enough of these types of mistakes and started doing them myself.
Usually, more experienced personnel work on the more challenging jobs. They still make mistakes though, so document, document, document. For instance, as preventive maintenance, I had all the wheel bearings replaced on my '89 323 somewhere past the 100k mile point. The tech forgot to put the grease seals back on, resulting in leaking grease and grease all over my wheels. Careless. What really ticked me off was the dealership service department didn't apologize and charged me for fixing their mistake. I avoided them for something like 2 years after that. They've changed service managers since then and have been better, so I take my car in for stuff I won't do (like coolant changes, belt replacements (timing, and the acc. belts in my Pro...much harder to get at than in my 323).
Some homeowner associations won't let you do car work outside your garage either. Some folks just have nothing else to do. It's not like I'm putting my car up on cinder blocks.
thanks for reading this "DUDES".
Some people were raised with amazingly practical parents. In return, the ones I know were recently rewarded with a free valve job for their parenting efforts.
I never stated that your experience wasn't valuable. I'm sure you can find a problem faster than I can. However, that doesn't mean I can't find a problem. I take real issue with people that feel that if you are ourside their profession you are suddenly not capable.
But presuming from your attitude, i certainly believe that ur more than just an average tech. and will certainly be a pleasure to meet in person and work on a "tech" project sometimes together.
No offence intended, if one was percieved.
--Dale
Also note timing and sequence and any other circumstances (such as the environment: cold, hot, humid etc.).
And you can mention what YOU think might be the cause.
Having access to the service manual, with its diagnostic charts is a big help.
U need to provide intelligent data to him so that he makes the right calls.
I started this conversation when someone suggested they remove their door panel and replace the door lock actuator themselves. Good idea but I've seen too many of these home projects go awry. I know that anyone who can use their noggin for other things besides a hat rack can logically determine what component is at fault and attempt to replace it. In todays cars however, with multiplexing and CAN wiring harnesses, the fault could be with a number of components. Also just by mistakingly removing or not removing the proper item one can cost his/herself extra $$. I will be the first to admit that I am not perfect, and I make mistakes(rarely ) and the learning process I go through benifits every car I work on after that. Thats why I get paid the money I do and my customers are always,for the most part, satisfied.
I am was definitely not referring to oil changes and the like. Anybody who takes the time to do these things themselves is definitely going to do a more careful job than the lube tech who guessed wrong as to the size of the drain plug and now you have to use visegrips to remove it!
Thanks in advance for any assistance
Brian
People have reported that they've had luck by changing to a 75W90 synthetic manual tranny fluid.
Dinu
reason is sometimes the car revs so smooth that u think u r using butter for lubrication and sometimes i can feel it is not smooth and I know very well that if I take it to the dealer, he is never going to notice the difference I am FEELING on day to day basis.
So how much does the MAF cost?
where is it located?
all help appreciated on this one.
Charge lamp illuminates and/or MIL. A noise prevention condenser was added to the D terminal circuit of the generator to prevent malfunctions of the voltage regulator due to excessive noise that is emitted in the B terminal circuit during charging. Beginning VIN: JM1BJ2*****421942 New ALT P/D January 12, 2001 ( Part number did not change) Rebuit Alt P/D February, 2001 4 digit Lot No. (located next to amp rating on stick on tag) Example 1112: First digit: Year 1=2001 Second digit: Month 1=Jan (1:Jan, 2:Feb,...X:Nov, Y:Nov, Z:Dec) Third N Forth: Day 12 = 12th
It is almost like a 50:50 chance of happening everyday.
Nothing else i.e climate, time of day seems to be affecting it. I know taking it to a dealer would only bring me stares because they would find the car "normal" by all means since it is my "feel" ...the car does not hesitate nor does it ping & neither does it backfire nor does the CEL come on.
The dealer (Gunther in Ft. Lauderdale) replaced my mass airflow sensor for my 1.6L this week. The car is running a lot better now, the idle is smoother and the power band is more consistent.
no CEL, no herky jerky, no pinging....just simply rough on the edge when u push the gas pedal...
I did notice that there is a pipe underneath the driver's seat. What is it, and what is its function? Would the water come from that pipe? Or from somewhere else?
Thank you very much for your thoughts in advance.
