Maxima 5-speed Problems
Joe
"The drop in RPM between 3100 and approx. 1500, is
done by the TPS, not the ICV, and is not a
"glitch" (as he put it). It has something to do
with the variable intake which, so it seems, opens
to a short runner about the 3100 RPM mark."
I thought about what this for a while and read up on the VIAS in the service manual. I also did a little experimentation and I am certain that the VIAS is not responsible for the "fuel-cut" driveability problem.
For one thing, the VIAS opens and closes at rpms above 3100. The stationary test alone shows that the fuel cut seems to be a problem in the mid 2000's. (When testing the VIAS, the service manual requires that the engine be operated at 5000 rpm, at which point the VIAS is supposed to have opened. Maybe 5000 rpm is recommended just to be certain that the valve will be fully open.)
Second, I actually disconnected the wires that attach to the VIAS control solenoid valve, and then drove the car. There was NO difference in the cars driveability. I also did the stationary test, and there was no difference. With this connector disconnected, it is impossible for the VIAS to open and close, and it must remain in the closed position. This test is easy to do if anyone else wants to try it. The control solenoid is located on the right (drivers side) end of the intake manifold and is black in color. The control solenoid can be recognized because it has a vacuum hose attached to its front face and the black connector is directly below it. (I can send a digital picture by email if anyone wants a visual of it.)
Third, there is only one path through which air can enter the engine (excluding the EVAP system which I have also checked out). The air either has to pass by the butterfly valve which is controlled by the gas pedal, or it has to pass through the idle control valve. There is no other path available. At the instant that the fuel-cut occurs at "closed-idle" on the TPS (ie the butterfly valve has reached a closed position), the engine is still producing too much power (ie. air is still entering the engine). If the butterfly valve is closed but the engine is still acquiring air, then air has to be entering the engine from the only other path that is available, which is the idle control valve.
I don't need to bore everyone with these details for a second time. For a full and more thorough explaination, just re-read my post #2 in this thread.
Therefore, I do not believe that the VIAS is responsible for the fuel-cut driveability problem and I stand by my original findings in post #2.
It is frustating that Nissan does not fully understand the fuel-cut problem. If they don't understand it, then they certainly can't fix it.
Joe
I did read your #2 post in detail, I'm just not sure yet if I understand exactly what the car is doing from a seat of the pants point of view, as well as when it happends, at what speeds, what gear(s). My experience is that it feels like a harsh driveline lash, and only in 1st gear. Now THAT I've felt myself, but never in any other gear, and only at very very low speeds. The fact that the car won't pass a 3000RPM to 2000RPM really means nothing as far as drivability goes.
I'm sorry to make you go through it again but, I feel I really have to understand the "problem" fully in order to be able to explain it with any oomph. Maybe I've just driven too many to even notice it.
I'd appreciate your E mail...Thanks, and again, I apologize for beating a dead horse.
Joe Joenissan@aol.com
(I think I'll post here for the benefit of others.)
The "fuel-cut" at closed-throttle is not THE problem. I think we are all in agreement on that. What is important to note is that it is a SYMPTOM of the REAL problem.
The REAL problem is that an unloaded 2000 Maxima Engine will not willingly slow down as the gas pedal is released. As the driver eases off the gas pedal, the engine continues to produce more power than desired, and the engine never slows appreciably until the "closed throttle" position is reached on the TPS. (Remember, at closed-throttle, the fuel-cut event occurs.)
Digging a little deeper... The reason that the engine will not slow down is because it continues to receive AIR (and fuel) even when the butterfly valve is nearly closed. At the very instant when the butterfly valve is on the verge of reaching a "closed" position, the engine is producing a lot of power with air that is being acquired from the idle control valve.
Therefore, the REAL REAL REAL problem is that the idle control valve allows too much auxillary air into the engine, independent of the butterfly valve.
The net result is that the car cannot be slowed by easing off of the gas pedal. Instead, it continues to produce power right up to the very instant when the closed-throttle "fuel-cut" event occurs, at which point the car will suddenly compression brake without a smooth transition from "power" to "fuel-cut".
That would have been much more appropriate and less confusing for the Nissan techs. The "fuel-cut" title implys that the closed-throttle fuel-cut event is to blame, but it is only a SYMPTOM of the REAL problem.
There it is in a nutshell.
My e-mail is mh3023@hotmail.com
Anybody else want to join in? Dave Z? Warren?
Bruce...
Mark
I passed by a BMW dealership to look at the new 3 series. Very nice, and the 330 has 225 HP and 0-60 in 6.4 sec. Too expensive for my blood though unfortunately. I didn't test drive one yet, but I know their whole throttle control system is done electronically. It might even by "throttle by wire", but I'm not sure. BTW, all 2001 BMW models are spoken for. In order to get a car, it has to be factory ordered with a 2 month waiting period. Guess BMW has no problem selling their cars.
Dave Z
I still believe that the idle control valve is letting too much air into the engine, independent of the butterfly valve.
Maybe you can "yank his ear" again on this issue.
And waiting . . . and waiting . . . and waiting . . .
I had a chance to do the neutral test on 3 other 2000 5 speeds and one 2001 5 speed this weekend. Each car dropped to 1500 RPM convincing me that my drop to idle has to be related to the severity of my problems. I can use that in any judgements with Nissan, and maybe I have a defective IAC and/or ECM that is causing the drop to idle. I won't let them try to replace either part at this time, though.
I know all the cars will have the idle motor problem in regards to the excessive air intake, but I have a strong feeling that the neutral test on cars that stop @ 1500 RPM might help to mask the problem a little more. I told my rep about this as well on the message, and also said that the Nissan engineers have no idea what they are doing and how they have to look at the idle valve and how this is a safety issue since you effectively cannot control the throttle of the car.
The 2001 model was real nice. I liked the new rear view mirror and the steering wheel radio controls. I don't think it is possible to hook up the radio controls to a 2000 MY. You would probably have to get the controls, a different clock spring for the steering wheel with wiring for the controls on its printed circuit board, harness to the radio, etc and that would be expensive. If I could get a 2001 model out of Nissan, I would be happier, but not satisfied.
I think I have a true "lemon" or a Friday afternoon produced car since besides the fuel cut, I also have multiple rattles (even with a-pillar foam), horrendous rear bumper paint scratches (that even extend below the trunk lid surface!), and whine from blower motor with 4400 miles on the car so far. Seems like most of the TSB's relate to my car.
A car is just a machine, so there will be defective ones out there, and I think I have one unfortunately. It sucks that I have a lemon, but what really gets me is Nissan's attitude that I have received from their salespeople to the service managers to the engineers and the corporate people.
I might be used to excellent customer service since I was a tech @ Saturn for a while, but Nissan is truly at the bottom in regards to customer service. I'll keep everyone informed with my progress, but I am in full "fighting mode" now.... lol
BTW Joe, is Carlos your District Rep? He should remember my car if so.
Dave Z
and....if I'm understanding this right...the problem is causing an "uncontrollable throttle", meaning when you let off the gas (at low speeds in low gear(s), the car will not slow down ? I myself, after reading what you wrote, tried this while paying attention to the engine braking. I didn't feel or experience any such thing...i do feel the sharp on-off throttle responce... though haven't found it to be of any problem. Again remember...I may just be so damn used to it that it may seem normal to me but...that's what I've found.
Joe
Thanks guys,
Mark
Joe
Even so, I was just as unhappy with the way the car drove before AND after their "fix". I my opinion, the difference that Davedzny is concerned about (ie. some cars drop to 1500 rpm and others drop to idle during the test) is not particularly relevant to the main problem (which is the idle control valve). However, I do not dispute that this difference might make Dave's car a little worse than others.
I don't think Nissan service is as bad as Nissan-USA technical support. The service people can fix defective parts & adjustments, but they can't re-Engineer everything. If Nissan-USA is unwilling to communicate problems back to Japan, then there isn't much the service departments can do.
"if I'm understanding this right... the problem is causing an "uncontrollable throttle", meaning when you let off the gas (at low speeds in low gear(s), the car will not slow down ? I myself, after reading what you wrote, tried this while paying attention to the engine braking. I didn't feel or experience any such thing...i do feel the sharp on-off throttle responce... though haven't found it to be of any problem. Again remember... I may just be so damn used to it that it may seem normal to me but...that's what I've found."
That sharp on-off throttle response that you feel is the fuel-cut that we are all complaining about. The reason that it is so sharp is that the engine does not slow down much when you let off the gas, but once the "closed-throttle" position is reached, the drop-off in throttle response is dramatic.
When I drove the BMW 528 5-speed (2) weeks ago, it was apparant that BMW had managed the closed-throttle event much better. If the BMW has a closed throttle "fuel-cut", then it is very very hard to notice.
If Nissan would cut down on the auxillary air entering the engine from the idle control valve, then the closed-throttle "fuel-cut" would be much less abrupt. I personally don't think the "fuel-cut" is such a great idea on a 5-speed, but it could at least be made much less abrupt.
2000 rpm while in neutral with no external loads),
some cars drop to idle when 2500 rpm is reached and some cars will drop to 1500 rpm and kind of hold there for a little bit.
I think this is mostly a small difference in the
TPS adjustment from one car to the next, but I
don't believe that it is indicative of the main
problem, which is excess air from the idle control
valve. However, maybe it does make Davedzny's car
worse than others.
From the info you provided I bet a stepper motor operates the valve. The nice feature of this type of motors is that they tend to stay in the same position even after the power was disconnected.
Thus there is a patch to the uncontrollable throttle problem. All we need is a circuit that sniffs the TPS and activates the relay that simply cuts off the power from the stepper motor.
I view the scenario of the operation as the following:
· Starting the engine: accelerator is released, TPS sends 0, our circuit “enables” idle valve, so the engine can have appropriate idle RPM.
· Cruising: as soon as you press the accelerator, TPS outputs whatever nonzero value it has; our circuit reads it and disconnects the stepper motor thru the relay. Now we’re in control of the engine.
· Parking: as accelerator is released TPS sends a zero signal, our circuit reads it and “enables” the idle valve. Now ECU controls the engine RPM and increases/decreases the air flow as necessary.
That’s how I see it. It’s late here in CA now; I’ll try to work on schematics for the sensing circuit tomorrow. Bigk200, what do you think? Maybe we should patent it before NISSAN does?
I also think if the computer sees a low temp from the coolant temp switch it will also open the IAC for more air to richen the mixture and vice versa with a hot to very hot engine. The IAC also kicks in when there are loads on the motor (i.e. A/C, headlights, power steering stops, etc.) The whole reason we have computers controlling the engines today instead of carburetors is that a computer can keep the engine in that window of the "perfect" 14.7:1 air/fuel ratio that minimizes emissions much better then a carburetor could.
Note also that the rear O2 sensors are there to check the job that the front O2 sensors are doing. I believe the rear O2 should remain at around .500mv or less thus indicating that there is little to no unburned fuel left in the exhaust.
It has been a while since I hooked up my old Snap On scanner to a GM or something where you can monitor all of these readings and see the changes take place live, but I am pretty sure my memory holds up on the fact that the IAC is designed to be an actively controlled unit throughout the whole driving range so I don't think it is possible to program it to be an "on/off" type of actuator. I used to be heavily into all of that computer controlled stuff when I was an auto tech. Guess that's why I'm a network admin now....
Dave Z
I e-mailed my Zone Rep the URL for this forum. I specifically asked him to review Post #2 and the other posts from bigk200.
My Zone Rep treated me courteously and professionally. I told him that, unlike some, I could live with the fuel cut condition whether or not it ever got fixed. He said he appreciated my attitude, but that his job was to pursue these types of issues to their logical conclusion in order to make the Maxima a better driving car.
Stay tuned.
Bruce...
Dave Z
Joe
If you want to drive a 5-speed that doesn't have this problem, then check out the BMW's. I also know for sure that Maxima's from the late 80's did not have this problem. I don't know at what point in the 90's that Nissan implemented the closed-throttle "fuel-cut", but it is most problematic on the 2000 model.
(The "fuel-cut" feature was probably implemented with OBD II)
Joe
Perhaps you are one of those drivers who are "all on" and "all off" of the gas pedal? Or perhaps you clutch quickly rather than slowing the car with the gas pedal?
(Most drivers who are "all on" and "all off" the gas pedal will never admit that they drive that way.)
If your car is so great and and other cars are so bad, then why can't Nissan make all cars perfect like yours??? Nissan appears to be fortunate that many owners are too apathetic to complain and many others don't know any better.
Just as you noted in an earlier post, your very own service rep. said "THEY HAD RECEIVED HUNDREDS OF COMPLAINTS ABOUT THIS". I think that statement alone provides vindication for anyone who is concerned about the "fuel-cut" problem.
Dave Z
Bruce...
I'm sure all those folks complaining of the same thing aren't nuts...lol. I just wish I could experience it for myself. I drive 53 miles each way to work every day. I'd say about 40 of them (each way) are highway, that's 80 miles a day at steady speeds (some even with cruise on) and I've yet to experience as much as a hiccup from the car. By the way....I've not had oneone yet come to our dealer with that complaint yet. Maybe then, I'll understand.
Joe
The post is from a 5 speed problem thread that has just started there. Of course I added a bunch of info there, but most people on that board are die hard Maxima enthusiasts and refuse to hear any negative comments related to a Maxima. Here is the quote from the post:
"As for the full throttle thing, I dont know. I do know that I went to inch up and my car took off about 5 feet and hit a pedestrian. I was taken totally by surprise. yeah, felt like a total idiot and luckly I didnt hurt him, I was able to hit the brakes. I never have been able to figure what happened that day. I'm not blaming it on this thing, but it might explain it.
Also, I was getting a tire plugged and the tech was asking me to roll forward up a slight incline. I couldnt do it. the car lept 2 feet anytime I got in enough throttle to move the car. it was really wierd."
Dave Z
Joe
So I am not surprised by reports that the car seems to really take off (leaping forward so-to-speak). It's completely believeable for me anyway.
Inch forward or leap forward . . . those are my only choices.
Bruce . . .
He drives a GLE auto, not a 5spd. I just wanted that to be clear to the other folks here. And I'm not disagreeing with you or him...I agree that the throttle is very sensitive....I feel run up on people bumpers REAL quick with realizing it sometimes
You took quite an unwarranted bashing over there by quite a few folks which was pretty uncalled for....you think that you just insulted someone in their family!
I'm on your side and all of you with the 5spd problems...and I've got quite a few on my side in automatic world
Hey I like the car but I don't have such a blind loyalty to Nissan that I can't see its faults
Ok, I registered the name
http://www.NissanMaximaProblems.com/
I still have to work out with ISP the way to
upload the useful information other there; right
now it's "under construction".
Until then--what do you think is appropriate over
there? Right now I am thinking about brief
description of the problem and links to both
"Nissan Maxima 5 spd Problems" forums.
What do you think?
Do you mind if I quote your post #227 at
NissanMaximaProblems.com web cite?
Joe
Send me an e:mail and let me know where to send my contribution and in what amount.
swallow@sky.net
check it out--the 1st revision of
is up and running
So send me comments if you'd like to (link is provided on the page).
Kostya.
P.S. so far they charged me $61 for 1 yr. "parking" and $35 for registration. Anybody wants to chip-in?
