Ford Focus Hatchback ZX3 - Part XIII
NJ
The reason I sometimes activate the button is just to keep the rpms a little higher because the engine's torque and horsepower peaks are at higher revolutions than where 4th gear often results. I use a little more gas to cover the same distance, and the engine turns a few more times but maybe doesn't have to labor as hard (if that makes sense?).
Almost all cars with 4speed auto transmissions have this feature, by the way. Hope this response doesn't insult anyone's knowledge level!
Paul
e the car, but the front brakes seem to squeak way
to much. I've had the dealer look at them and
they
put new pads on and then had to realign the
rotors. After that the brakes were good for a few
weeks now they are squealing when I brake at about
15-30 mph and there seems to be some vibration in
the brake pedal. I'm going back to the dealer,
but
I keep hearing that the new metallic brakes pads
squeal more than in the past. Any ideas or
anybody
whose has similar problems?
My "day old" baby got 100 new miles put on today! no incidents or complaints so far, altho I noticed the "dead spot" around 2400-2600 rpms.
thanks again for the O/D info... guess i'll leave it turned on, but just knowing what it does gives me a little more insight into my baby. thanks
nj
I find it interesting that different models of the focus are more popular in different areas of the country than others. For example, here in Rural northeastern Ohio the Station wagon is the most popular ( dealers can't keep them on their lots longer than a few days) while the sedan is close behind. There are not many ZX3's around here.
I test drove a station wagon and liked it because I go antiquing and I liked the arm rest ( even though I thought the arm rest was small). The road noise was twice as loud as the ZX3 though and I didn't think it drove as nice. I realy didn't care for the sedan just because I've been driving a sedan and never cared for it. To me most sedans look the same and boring.
My favorite cars have been hatchbacks. I just like the way they are designed and they suit me. I have to say that I had a civic hatchback and liked it a lot, never a problem and it was fun to drive, but dollar for dollar the focus is a better car. As far as reliability only time will tell. It was a chance I was willing to take. The styling is also a issue for me as I love the European look.
I will be extra alert to other focus on the road in the next few days, Maybe I'll even see someone from this group out there!
you will be using od when you travel on the g.s.pkwy. + n.j. tpk.
Make of that info, what you will.
Jimmy
Dictator for life of Lala Land
I have put the synthetic brushed aluminum dash trim around the oval vents. I really love the way it looks, it gives a great contrast to my dark charcoal interior. I plan to get the rings that go around the door release handle and Power locks. Check out www.dashkit.com
On my way home tonight I passed an intersection where an accident had taken place and one of the cars involved was a light blue Focus Sedan. It looked like it was struck on the passenger side and it was totaled. Very sad site to see, I don't know how hurt the occupants were, I hope there was no one in the passenger seat.
From my last fill up to fuel light coming on I got 230 miles, when i filled up it took 10 gallons, so I figure that I am getting 23 MPG.
I am tracking it again to see if this is consistent.
Also, I am still having problems out of the rear suspension. I hear those creaking noises and the car leans a little on the drivers side--the ride seems off. I have explained this to two dealerships and it is like talking to a brick wall. They responded by telling me that I had a defective front strut that was echoing the noise to the rear ( I must have dummy written on my forehead) Well they replaced the front strut- which, I may add, I never knew was a problem. The noise continues in the rear.
Sometimes the car feels like it is not stable at higher speeds. I thinking the problem is either the springs or axle or some suspension component attached to the subframe. I wish I could sell this car, but I would loose so much money. I have had it since Dec. 29th, now it has 15,500 miles. What am I going to do. I know its a good car, but it needs some refinement.
cruising at hwy.speeds 45+.the rpms drop when going from drive to od.similar to 5spd.in respect to going from 4th to 5th.the spouses zx2 auto is
always driven in od.plenty of passing power at all speeds.ive said this before but i believe zetec in
zx2 auto + 5spd. is a much better performer than
zx3.ive owned than both.there is certainly some odd
going on with the varying gas mileage being reported.
One problem has occurred recently - a very damp driver's floor mat - the carpeting on the driver's side is quite damp. This appears to be a problem with the a/c drainage tube - anyone experience something similar??
Anyway, I suppose I had a bit of luck in that nothing else was damaged (aside from my little car's ego). Guess I'll be calling the dealer tomorrow to get a replacement.
Well, just had to vent a bit. I was a little perturbed at the whole thing.
Thanks for listening.
reed.
NJ
regarding the car, I wouldn't put wood trim on it. no way, I don't think it matches neither the colors nor the personality of the car. unlike some I don't like the arm rest on other focuses, to me it's too big, it would make shifting a bit difficult, I think, I guess I'll have to look elsewhere.
gotta go drive...
Look at this post for dash inserts. (It is a refinement of Drebe73 post. Thanks Drebe73!!)
http://www.dashkit.com/newpage12.htm
Does it look better? Please comment.
More talk of noise: I think njzx3 is experiencing a different noise and indeed it is nothing to worry about. I do not want people to think their car will do what my car is doing (and it looks like Moses5). I truly think that this problem is caused by a bad part or parts that met specifications while new, but somehow failed during use. I do not think this is a common problem. Otherwise, many people would be talking about it because it is so NOTICEABLE. Again I will stress...
1, Tapping and rattle is noticeable Inside the car with the windows shut while idling.
2. The rattle can be induced by stepping on and off the clutch a few times.
3. The engine is rough at idle and noisy.
4. I can speed up the tapping noise by gently stepping on the gas to 1000 rpm.
5. I even think acceleration is not as good as it was.
6. When the car is warm, the beginning of first and 2nd in my 5 speed sounds like a tractor. I believe it is related to points 1-5.
Can't wait to bring my baby in.
ND
NJ
good luck
NJ
Probably more like 37-38psi cold. (I corner hard)
Gabe
NJ
go to "ownership benefits" in ford.com and sign up. not a bad deal.
Now there is a company that makes real aluminum dash kits but I found it to be a little steep in cost. See http://www.woodtrim.com/default.cfm
What each of us do to our own Focus is based on our own personal preferences. I made the mistake of commenting that I didn't like what someone on this board had done to their car and ended up hurting their feelings. Just because its wrong for me doesnt mean its wrong for you.
Where are you getting the 34 PSI value?
on a different note, the brush aluminum trim would look better if it wasn't for that crack by the hazard light button like njzx3 said, but the rest look fine to me, I'm sure it looks nice in person. however, I wouldn't do it to my car. I'm hoping they start making trims the same color as the original, that way it would match the center console, the shift knob, and the doors, then I would buy the whole package.
gotta go drive...
The problem is fairly common.
I suspect that the idling and the take off noises are the results of the same defect.
I'm sure you know how to handle the dealer.
I've seen lots of comments like the following one from the contour board in regards of dealers and their BS:
"Dude I have a97 sport, and it does the SAME DARN THING pops out of gear, especially 3RD!!!! when I jump on the gas!!!! Had it to the dealer and they claim "ITS FINE". Yeah we all know how that works!! You have to take a physically totaled car to a DEALER for them to say oh yeah I think I know what it is!!"
NJ
Mike
And why would I think 32 is wrong, you ask? Because the table glued to *my* passenger doorframe says 34! Of course, now I am curious why Ford thinks I need more air in my tires than you do in yours.
I assume that they know nothing about my driving habits and so I won't take it personally
Perhaps Ford's recommendation has changed? The build date of my car is 15 August - fairly late for a 2000.
Wait a minute. The ZX3 doesn't come with the armrest installed from the factory.
greycap,
what's the deal with tire pressure?
Here is what my label reads:
Tire size Front Rear
P195/60 R15 87T* 32 32
P205/50 R16 86H* 34 34
Unless you have the Kona's 16 inchers your tire pressure should be 32.
Did they make an attempt to fix the car?
Did they admit that there is a problem(s)?
Jimmy
Pittsburgh Cycling Club
VP ~ Mountain
In answer to the rear seat question, yes they fold flat, but first you have to lift up the bottom of the rear seat and then the rear seat backs will fold flush. This is kind of hard to put into words but we had this dilemma the first time we tried to fold the seats down. When "properly" arranged you can actually see the underside (ie springs/cushion)of the rear seat as the actual seating area side is flat against the backs of the front bucket seats. Also, you have to give the entire rear seat a very healthy tug to get it disengaged. Sounds awkward, but once you get the hang of it, it's a breeze. Glad to have all you newbies....
: ) konagrl
Now I wonder if I made a mistake switching to the MTL.
Trying to look for any information on MTL vs. D4 ATF. So far I'm getting very controversial opinions. Just opinions, nothing solid.
The MTL didn't make my transaxle to shift any better.
Should I switch back to the Mercon before bringing the car to the dealer for service? (potential warranty issues?)
The major negative aspect of the Cruiser is it's very poor showing in the front crash tests.
The data predicted severe or fatal injuries to the driver. In the Focus, the injuries were predicted to be moderate.
Another negative for the Cruiser was the total cargo area.
Other cars compared were the Honda CR-V, Nissan Xterra, and the Subaru Forester.
Only the Xterra and the Cruiser were NOT recommended.
Focus came out on top overall,the"most logical choice".
It can happen to any car, it's just a bad luck.
Ford should fix it or replace it with a new car!
Now out of curiosity, does any one have a breakdown of minimum/maximum speed, full throttle, in each gear. Like 0 to 35, 1st gear; 35 to 70, second gear; 70 to ?, 3rd gear; and ? to 106 mph in 4th gear? Sure there is something out there in writing on this, not that I want to go that fast. Just trivial information, don't want any points on license.
First of all, O/D on is the default, will allow the trans to shift to O/D (4th gear) and generally get the best mileage. If you are driving on curvy roads, or hilly roads, and want the car to perform better and be more responsive, turn off the O/D. If you are on a freeway, in O/D, and punch the gas, the car will downshift into 2nd or 3rd anyway and the acceleration won't be worse except for a slight time lag involved in the trans shifting.
As for bike size, many current mountain and road bikes come in small/med/large sizes these days, because long seat posts and stems will indeed allow more adjustment from rider to rider. Generally, small sizes will fit riders from a lil under 5 feet to mebbe 5'4", medium for 5'4" to 5'10" or so, and large bikes for folks taller than that. If unsure, go for the smaller frame size lest you come off the seat with the wheels on hills and the center of the bike in a little valley--the clearance is useful at that time.
Finally, the selling dealer should be adjusting tire pressure (and checking all fluid levels, etc.) before a sale; suggesting that Ford is "conspiring" to inflate tires to 24 lbs is kind of naive--sort of like complaining that Ford set the heater control to hot and you bought the car in the summer. Are folks unable to check their own tire pressures any more?
As a road bicyclist, I'm used to filling tires about every 3 days with sewups....and I can check and fill my own car tires too.
George
Also, has anyone else had a problem shifting into 1st from neutral (manual)? Dealer wants me to work with it a few thousand miles (5) before doing anything drastic.
Kona is the silver, love all the 'bells & whistles'!
+ jersey shore the past two weeks than zx3 all year.have you visited ivyland recently?im only a short walk to that town.
Well I still don't have any news on VIN or build date, so I have decided to try improving my karma by passing on a cool feature I have read about in a focaljet forum. I have not seen this mentioned here and I don't have a car of my own to try this on so let me know how this works.
If you hold down the trip reset but when starting your car you can turn your trip readout into an analysis tool that can display several different codes. These codes are intended for the service technician but in my opinion if my car does it I want to know how to use it.
These displays have allot of different feature: digital gas gauge, tack, lamp test, dampening factors. and many more. If you have any questions please look to the focaljet forums and there is a link to a mustang site, I assume that the poster knows that the codes are the same for the focus as they are for the mustang.
