In my case the brake fluid was below minimum. I filled it up and there is no more parking brake light, Traction off and VSC off lights !
Check your brake fluid.
John
I hate to kick you when you are down but there is no such thing.
As for your transmission, GM makes about the best in the biz. Did your transmission get replaced or was it just fixed? Filings in the case are normal, but they are unusual in high numbers on lower mileage.
alex
flashing but steadily on ... brakes are working fine. Except for light - no noticable symptoms.
Any ideas what might be the cause ?
Thanks in advance!
thanks for any info you can pass on.
Got the intake gasket fixed yesterday, at first my local pontiac dealer told me, "your not the original owner, GM won't touch the repair". Had an aftermarket warranty from a company called Lubrico the other seller gave me with the van, they covered the full cost, thank god almost $800 CAN, just had to pay $100 deduct and oil change.
Get this though, the other night I had called GM Canada and told them what I thought the problem was, he took my name and number and said bring it in and get a diagnosis. He called me back yesterday an hour after bringing the van home and said GM said they would cover the repair, told him thanks for the call, already done, had the aftermarket warranty, thanked him for the courteous reply and the return call.
I guess the deal, at least her in Canada, call GM, don't believe the local dealer and what they say. GM Canada was going to cover it for me.
Thomas
2004, 2005 and I believe 2003's have 5 year power train warranty's in Canada. That said, it's mostly the earlier models that have the problems.
Great news though.
A tire dealer said the wire leading to the wheel speed sensor was damaged, but an attempt to repair it didn't solve the problem. It turned out that the wheel speed sensor in one of the front hubs was faulty.
Not a cheap repair, unfortunately, as the moving part of the hub assembly must be replaced. But it worked and it was a good investment to get the ABS system back.
My Montana 2001 of 55000km was found leading coolant and oil traces appearing in the coolant reservoir.
The dealership agreed to cover the cost of replacing the intake manifold gasket (they believe it worth CAD1400), while telling me that 2 of the cylinder heads need to be replaced for CAD400.
They believe that the cylinder head replacement is not a consequential damage of the coolant leak. ANY IDEAS?
Many thanks
Has anyone else ever had this problem? Will it eventually affect normal operation of the vehicle? Thanks :confuse: :mad:
Typical rip off attempt.
I saw your post on TRACTION SYSTEM light.
I'm having this problem also on a 2000
Montana. ONLY 45,000 MILES ON THIS CAR.
I'm quadriplegic in wheelchair from multiple sclerosis. I just want to make sure.
The car won't give me any problems on a small vacation.
Please write back.
Daniel
Thanks...
Yestery I got a can of refrigerent at walmart and found a big leak at right lower front on the battery side. It left a big puddle of greasy greenish oil on the drive.
Too hard to see exactly what I might be able to repair myself, but looks like a simple thing - I bet the dealer would say it is the whole compressor or some other scamming lie.
Try running a can of stuff in yours to see where the leak is.
I wonder if it is in the same place.
Would this be a passenger's side switch problem?
What is the process to change a power window switch
dalerd
I did a lot of internet surfing about this antifreeze leaking into the engine because of the dexcool rotting the gasket. It is a serious problem that many owners are complaining about. I guess I was lucky my bill wasn't as big as some others , but I am having problems with sensors on ABS, TCS, and airbags, as well as premature wearing of brake rotors, etc...
PLEASE SOMEBODY HELP ANY INFO WILL BE APPRECIATED
THANKS
EVELYN (from canada)
the computer and would start every time.. to it to a small garage and they found the pick-up coil... Hope this helps. Alvin (New Brunswick)
Thought about the heater core, but why the diminished air flow output, when I can clearly hear the fans working. Anyone else with this issue? Solutions???
Thanks for any response. :sick:
fuses for a/c and even the diode in the fuse box by the relay for a/c...thanks for any help
Pnut
ClaireS, Host
Coupes & Convertibles | Vans & Minivans
The mechanic says the clutch does not engage because the refrigerant mixed with the oil. If the clutch would engage without oil, it would destroy itself. You have no refrigerant mix in your system, so the clutch will not engage.
They did an a/c service. Removing all of the air from the system, recharging it, and adding a UV die, so they can see any leaks if the a/c stops working again. Expect to pay $130 - $150.
The a/c stopped working 5 days later. So I have a big leak somewhere and have to take it in again. BTW it's 90 degrees and very humid today.
My van is a 2001 Montana with 62,000 miles.
Keep me posted on what's wrong with yours and we'll compare notes!
-Mike
Unless you purchased an extended warranty from that local dealer, the factory GM warranty is done at 3 years or 36,000 miles.
If $510.00 includes the labor, it's actually a good price. Normally it would cost around $630.
