Nissan Quest/Mercury Villager problems
My 2002 Quest owner's manual (section 9-2) says the capacity is only 4 quarts of oil if you're changing the oil filter; and 3 7/8ths quarts if you're not changing the oil filter. I thought my previous 99 Quest used around 4.5 quarts per change.
The reason I'm asking is because I just had my oil changed, and I noticed the oil is above the overfill line (not good). Also, on the ticket, they've written down 5 quarts. From now on, I'll need to remind my dealer only use 4 quarts. Anyone else had that experience? Thanks.
Revka
Hatchbacks & Wagons Host
Also, I'm wondering if I should have them redo my oil. If they put in 5 quarts, they put in 20% more than needed. What do people think? Would it hurt to have it that way for the next 3k miles?
Revka
Dave? Corsica? Anyone?
Has anybody had an experience with a 1999-2002 Quest/Villager burning oil? I have 22,000 miles on my van and have never burned a drop.
This morning I had the problem corrected. It turns out the oil capacity has changed to 4 quarts for 2002 Quests, because Nissan changed the size of the oil pan for 2002 models. Thanks again.
Revka
I've always changed my own oil and found that exactly 4 quarts brings it right up to the full mark on the dipstick. I'm guessing that they didn't make any changes to the later engines, just refined what they put in the manual as the capacity. I'd be surprised if they made a change to the oil pan on it just in time for the last year of production, but who knows?
If your oil is over the full mark, I'd have them take some out.
As far as burning oil, so far with 76,000 miles haven't experienced it yet. Though I did have a bad oil filter that was leaking a while back, enough that I had to add some oil. I've changed my oil & filter every 3,000-4,000 miles (using Castrol part synthetic), so I wouldn't expect much engine wear yet.
Dave
Btw, I was just at the Auto Zone where their computers showed that both the 2001 and 2002 Quest oil capacity was "4 quarts" if changing the oil & filter. However, the 2000 and earlier models required more oil... at least according to their computers. Talk later.
Revka
I haven't replaced my fuel filter yet, but I should. Don't know how hard it is to get to.
The manual doesn't say when to replace the transmission fluid. 30,000 is a good time to do it. I just changed mine at 75,000 miles, and I probably should have before that. It's pretty easy to do since there is a drain plug for it. I got about 4 quarts out when draining it. I also added a bottle of Lubeguard treatment when I filled it back up. (Someone gave me a good tip on this, the trick is to put back in exactly what you took out. I used clean milk jugs to measure how much came out.) Shifting is noticably smoother now.
Kristorr, not sure what you mean by the engine jumping, but I have never noticed this in our van. Do the engine rpm's jump up or down when this happens? If you could describe what happens in a bit more detail it would help. But, it does sound like something is not right.
Dave
I'll admit that the Quest/Villager is a nice van, especially for the money. I love my 2001 Quest. Snappy? I realize that you are a long term four cylinder fan, but 4000lbs and 170hp does not make for a "snappy" vehicle. Did you move up from a 1976 Rabbit diesel? :-) It would have been nice if Nissan would have equiped the SE models with the 210hp supercharged version of the 3.3V6 - 210hp and 240lb-ft of torque would have made for a "snappy" van.
Can you expand a little on the dirty throttle bottle issue?
Dhoff, I really didn't pay attention to the rpms, but I will in the event that it happens again.
Cookie22 - so far I really do love the Villager. Great handling and so much room (last car was a Cavalier!), but the accelerator has taken some getting used to.
If anyone has any other suggestions that would be great! Thanks a lot!
dhoff Jan 24, 2001 4:54pm
I had the same overheating problems in my Nissan Sentra, both my fans were not running. One fan is critical to running the A/C - no fan, no A/C
J-P
Thanks, I thought the wife said she'd looked there to no avail, but we'll do it again!
Nissan actually replaced my engine because of some known problem with the quest's and pathfinder engines (mine was a 95 so they have this problem fixed, eitherway, I didn't know about the "known problem" until I complained that I had a weird noise).
Also, dhoff I had to replace my fuel pump on my Quest (which was fairly expensive). They said one of the reasons why you may have to replace it is if you don't replace your fuel filter as recommended. The mechanic had a Quest the day before mine for the same problem and this wasn't at the Nissan dealership. I wonder if others have had this problem.
It sound like it's coming under the (driver side) front dash area, right above the brake pedal. My dealer thinks something may be lose in the brake booster, and has even offered to take the whole brake booster apart and check it out....
Not sure I really want to go through the hassle of doing this, especially since it's not causing any noticeable problems. But I thought I'd go ahead mention it here in case anyone else has experienced this, and can offer some feedback. Thanks!
Other than that, my Quest has been doing fine. Just had my first oil change at 3750 miles. I'm probably going to switch to synthetic on my next service, then change my oil every 7.5k miles. Still getting around 18.5 MPG (mostly city). ;-)
Revka
Your mpg is "breaking in" nicely. I've been averaging ~20 mostly city lately, and we should break 75,000 miles this next week or two on our '99.
I think the temp lamp lives in back of the "combination meter," which looks to be a fancy name for the instrument cluster. Don't know how you get back there without removing parts of the dash....
Also, what might happen if I choose to ignore the "Check Engine" light? Everything else seems to be just fine. The van is running very smoothly, except that annoying "Check Engine" light.
Meanwhile here's a link that may be of interest.
Anyone got any tranny fluid info for Toyoda?
Dave
The dealer thought it might be something in the brake booster, and he even went as far as replacing the whole thing; but the click still persists.... Oh well, I guess it's to just turn up the radio. ;-)
Usually the extended warranty is just another profit center for the dealer, unless you get "lucky" and your tranny falls out. I skip them - Revka on the other hand seems sold on them. You may be able to price shop your quote and get a better deal on one too.
Good luck deciding!
Throttle sticking - Dealer fixed it by replacing a module. FORD PAID FOR IT!!
Auto-climate control failed - Fan controller died. FORD PAID FOR IT!! That was out of warranty!
New stuff:
Audiofile Radio - plays fine but the display works when it wants to. Any ideas??
Steering sticks in cold weather. Just freezes up and will not go past 45 degrees. I can let it roll to the end of the drive and it starts working fine. Any ideas? One mechanic says maybe steering seals @ $400. Fluid level is fine and the belt does not squeal under preasure...
Front rattles on bumps. Every one says everything looks fine under there. I am not so sure.
Otherwise, it has been a good traveling vehicle. Too bad I bought it new and cannot afford to trade it. With out the compressor running, I can get up 22 mpg. I cannot complain too much.
An Advanced Search in this topic for "radio" will find a lot of posts like this one:
stickguy Sep 23, 2002 6:35pm
Have you replaced your shocks and struts? I'm at 75,000 on my '99 Quest and I'm overdue. No rattles, but too much sway.
This might help-on the 1999-2000 Quest's One or more of the five bolts that mount rack-and pinion steering gear may have been incorrectly tightened; Could result in steering looseness and noise or vibration. Eventually, bolts could fracture or fall out. I found this information on the consumerguide.com. This recall does not refer specifically to your Villager but If I ever have that problem on my 2001 quest that's the first thing I will check.
3 days ago, my 95 villager suddenly got a rough idle and engin is noiser than before. i can feel the vibration when stop at traffic lights. i noticed that a stronger smell came out of the exhust.
any suggestion on where and how to start the check up?
thanks.
-kent
btw, how can i search by key words through all 1200 messages in this group?
