I've got the same problem, can you help?
:confuse:
Thanks again! :lemon:
my husband got on line looking to see if anyone else was having the same problem and luckily we found several people and one of them actully told him what we could do to try and get it started. We found out also it's going to cost us another $350+ to finally get it fixed. Good luck to everyone.
:lemon:
To me this seems excessive for a car only 2 years old. Has snyone else experienced these unusual types of repairs?
regards
rod
I have a 2003 grandam and I bought it new with 3 miles on it. Exactly one year later in 2004 at 20,000 miles I was replacing my brakes and my driver side rotor. Then appx nine months later still in the same year of 2004 the dealership told me that I need to replace my brakes again, so i did. Now this past August 2005 i had to replace both front rotors and then past November 2005 they are telling me that I need to replace my front brakes again for the third time. The car will be 3 years old in January. So you are not the only one having problems with brakes. I have not replaced my brakes again as of yet, but b/c of safety issues i am going to do and also to avoid them cutting into my rotors. This will be the last time that i replace brakes on this car..
This brake issue was first detected during a high speed highway evasive maneuver (after driving for 2+ hours.) On normal stop and start driving, this problem was NOT noticable. Brakes were applied at 65 mph, and the car had a hard jackhammer feeling to the front end, nore noticable to the passengers in the left side of the car. After that, every time the brakes were applied, even gently, this heavy vibration was felt. There was no overtly noticable pulsing in the pedal, perhaps because the jumping in the handling was so profound! When the car was parked and cooled down, the braking problem seemed to go away until another heavy braking incident would bring it out again.
In defense of the dealership techs, it took this garage two shots to get it fixed as well. They finally discovered that one of the calipers was freezing in position. They knocked it free, lubed it considerably, and the slider seemed to be working without issue. That worked for about 6 months, until the problem came back. On returning to them, their terrifying discovery was that the caliper was not getting adequate brake fluid, therefore the caliper was locking up. Enough damage was done by this time that the entire caliper assembly, plus another set of rotors and the lines had to be replaced. (The garage was embarassed enough that they gave me the pads and rotors at no charge. I guess my yelling that I could have killed or been killed by a catastrophic brake failure might have had something to do with it.)
Just wanted other owners to be aware of this issue if they experience it. I've owned Grand Ams since the ones in the old boxy late 80s. I'm on #5. This one is my first "lemon" that's had multiple issues with the computer, leaks, and other technical maladies.
The lights come on, the stereo and windows work, but when the key is turned, I get absolutely zilch. Hotshotting and jumping, and neutral starting did nothing.
I do not have the persistent security light, however, I've had the security light come on while driving two or three times in the past year. (I've got just over 60K on the car now.) I've also had intermittent engine codes that fail to clear -- a misfire code that despite replacing everything but the computer, it keeps coming back.
I'd hate to tow it thinking it was a starter and it's something idiotic like a GM screwup.
:lemon: ade anyone????
Any idea's????
Just a side note, from reading posts on this board, apparently I am having a problem with the Passlock system, as the car WILL NOT START...different issue for a different time, Thanks for your time!!
Ray :confuse:
PS. the battery installer technician,at NTB said that it was caused by a faulty interior dimmer switch????
As with the starting problem and the Passlock feature. I've only had it happen once but I luckily knew there was a chance of this happening. I found it in the owners manual that if it does not want to even turn over to leave the key in the on position for 10 mins and the passlock system will reset itself. It worked for me when I had the problem but I'm afraid it might start happening more and more.
As a result of my problem with this car I'm considering selling it before I have major problems with this thing. I sold the love of my life (67 Camaro) for a newer car so I would not have to be working on it all the time but it seems like I'm working on this car more and the gas mileage isn't as great as I expected. Also its sad that this car rattles more and has more road noise than my 67 camaro.
Based on what I'm reading here, it's the ignition module in the passover housing -- a $500 to $600 repair job!
Look, isn't there a cheaper fix for this? Can't I disengage the ignition key security thing or something?
I only paid $1000 for my "94 Grand Am
ric
Thoughts?
ric
Sounds like you may have a problem with the ignition switch, the security system is not operating properly when you are putting in the key or it is not reading the fact that the key is in place and that could be causing the security light to activate some times while you are driving.
My 2 cents worth I hope it helps.
My security light started coming on again about a year after paying the dealership $450 to replace a faulty Ignition lock cylinder. I was at my wit’s end. My wife and kids would be stuck at night in some shopping center parking lot waiting 10 minutes to reset the stupid thing. I was able to Bypass, Disable or Ghetto Hack my passlock II anti-theft system on my 2002 Oldsmobile Alero without relays or resistors. I had my local Auto wiring tech install a $5 on/off toggle switch under my dash that is connected into the yellow (key resistance/code/recognition) wire that can be cut while the engine is running to essientially bypass passlock I(1) or II(2) permanently.(I do not have nor intend to install a remote starter and I do not have an alarm on this car.) The toggle switch idea came about because of my concern that a dealership tech could possibly reset the security “fail- enable” mode or the battery could die or become disconnected for an extended period of time and reset the intended fault. All I need to do is flip a switch to break the circuit again while the car is running to take the passlock system offline. When the system is offline, the security light is on constantly.(Not flashing.) I don’t mind the light, but others may want to remove the bulb or black it out. Here’s how the setup works:
1)Switch On while engine is running – Security system is on.(Factory Setting) Security light is off. (Circuit is complete.)
2)Switch Off while engine is running – Security system goes into “fail-enable” mode and bypasses the passlock system.. Security light is illuminated.(Circuit is broken.)
3)Switch On while engine is off – Security system is on (Factory Setting)
4)Switch Off while engine is off – Security system detects this as a theft attempt
and will not allow you to start the car until you flip the switch On to complete the circuit.(Acts as a FUEL KILL SWITCH.)
Below you will find a thread and some supporting evidence of why this bypass actually works. The entire job took 25 minutes. There is an incredible link below with high resolution pictures of the wiring for your specific car. I included the actual photos that I used to gain access to my ignition lock cylinder wiring. *Special note: those with GM Class II Data Bus should leave your radio connected during the entire procedure so nothing weird happens. If you are unsure if your car is so equipped, it’s best to leave the radio connected and let it hang. Good luck and post with your success stories! 12/4/05
http://www.the12volt.com/installbay/forum_posts.asp?TID=59694&PN=1&TPN=1 Is this You? Get in your car....try to start it and find that the passlock II is screwed up again, you have to wait 10 minutes for it to reset. When it resets it starts up and runs fine. Fix-------Start the car, find the yellow wire that I'm sure you've read about, the rcode wire that is, and cut it. Shut off the car and you're done! The rcode wire on my 2001 alero is behind and to the left of the radio, you must take out the radio.....the yellow wire accompanies two other wires, the white and black, the 3 wires are alone and run inside what appears to be a cheap electrical tape that will fall apart in your hand when you start tugging on it, they are very thin wires, maybe 18 to 22. I taped off both ends of the yellow wire too.Took me about 14 days to find this out and reading no exageration 1000 posts. Forget all the relay, DEI and resister crap that I'm sure you've read about. All this writing assumes that this will continue to work.....i WILL be back here to post an update if it fails again. If you have doubts of me coming back to update a failure you can email me
http://www.insurorsservicebureau.com/ISB%20technical/ISB_QA.pdf page 4, The PASS Key Module also has the ability to allow engine operation if it recognizes a system fault in the ignition key reference circuit while the engine is running. In this case the Module enters and remains in a mode which allows the engine to be started and run without reading the resistance chip. This mode requires that the original factory resistance chip key be in the ignition lock
cylinder at the time the fault occurs. During this mode, the
security light will be ON all the time. When the key reference circuit is repaired, the module will automatically reprogram itself to the mode requiring the original resistance chip.
http://www.motorage.com/motorage/data/articlestandard/motorage/292005/169809/art- icle.pdf page 3, If the correct key is in the cylinder and that circuit
fails while the engine is running, this is considered a
malfunction, not a theft attempt. The “Security” light
may turn on to warn of a system malfunction, but even if
it doesn’t, a key recognition circuit failure with the proper
key in the lock will cause the TDM to enter what GM
calls a “fail-enable” mode. Essentially, the theft-deterrent
system goes offline and the engine will start and run
with any key that turns the lock.
http://www.directwholesale.net/diagrams/Images.asp?ImageID=84&link=BULLDOG
http://www.directwholesale.net/diagrams/Images.asp?ImageID=87&link=BULLDOG
http://www.bulldogsecurity.com/ and click on vehicle wiring diagrams to select your particular make.
Also how to disable Daytime Running Lamps http://www.lightsout.org/disable.html
2001 Olds Alero Locate the DRL relay in the main fuse box under the hood, it is #22 corresponding to the diagram on the underside of the fuse box cover. Remove the relay, snip pin 87, and re-insert.
http://www.automotiveforums.com/t491067-how_to_force_security_problem.html
n my opinion, used parts won't solve the problem either because they will just fail like the new part that I put on. There are literally thousands of posts on the internet of people with these same ignition lock cylinder problems. The N-body cars seem to be the leaders.(Malibu, Alero, Grand-Am) Yeah, I can see where this might seem a bit involved.... but it's really not. I just wanted to follow up with evidence of how it works. The quick simple fix is just to cut the yellow wire and tape up both ends. I took a screwdriver to pop the cover from around the stereo and took out 4 screws. Then, pulled out the stereo. The 3 wires from the ignition are right there on the left. Start the car and cut the yellow wire. That's it. You won't have to replace the ignition lock cylinder until it falls apart. I don't have to worry about my wife and kids being stuck somewhere. I certainly didn't mean for it to come across as being complicated at all. Enevitably, someone will ask why this works.
Report Post | IP: Logged
http://www.automotiveforums.com/vbulletin/t491067.html
Ok, with the fix I mention above, it seems what the poster was saying is that if you start your car and cut this wire, the correct code is stored in the cars computer and the automatic shut-off (or non-start) won't be triggered again.
Is that about right?
ric
I have the exact same problem. How did you fix this?
Does anybody know how to fix this.......key won't turn, steering column is not locked.
r
