I won't put Dodge Stratus down. If I get good money for my 96 Camry XLE V-6 with 47K miles, I will go back to 2001 Dodge Stratus. The Stratus was very comfortable car on 3+ hour trips.
and decided to get out of the leasing cycle by buying my '98 Sage LE, whose lease is about to expire. The buyout is $13,800 without a warranty. Car is in good condition, with only 30,800 miles. Does this sound like a good deal?
Do I owe it to myself to consider buying a new Camry as the dealer is pressuring me to do? He says nobody buys at the end of the lease as the residual is too high, yet my independent checking indicates this is about the market price for such a vehicle. My aim is to get away finally from monthly car payments, leasing or otherwise. Any advice??
why is the dealer pressuring you to buy a NEW camry?
if you think your leased car is worth $13,800 TO YOU, then buy it and enjoy, and don't worry about what it might be worth to anyone else.
I've been quite happy with my '97, and it now has 66K miles.
Insist that either they pay you what you think you should get, or have them buy you one of those cars in the ads. You pay years of insurance premiums for days like this. Don't settle for an amount that you won't be able to buy the same car.
Mechanics" magazine states that it costs approximately $2.29 a quart. Quaker State's web site is http://www.quakerstate.com I do not know if this works or if it is just hype. I wonder if any mechanics on this site can provide info on this type of product.
I was also wondering if I should maybe buy a corolla..I figured I could either get like a 93 camry or a 95 or 96 corolla for the same price.. but I dont know if there's a big difference in the 2 models...would I be sacrificing safety or quality? Why is there such a price difference??
http://mag-x.com/scoop/camry0101/index.html
So in the end, I decided not to get one (still got one remote left), and vowed not to let my wife drive my car again.
1)ticking sound coming from the left front dashboard area when the car is idling in Park or Drive. The sound is more consistent when the car is idling in Drive (e.g. at a traffic light) and when the engine is warm. There is no ticking sound when the RPM exceeds the 1 mark on the Tachometer.
2)Creaking sound coming from around the steering area when I make turns while driving.
Has any one experienced these noises and how were they fixed?
Also, like any front-wheel drive vehicle, rotate the tires frequently (~7500 miles). There are lots of complaints about tire vibration, pulling to one side, etc. I haven't had any tire/wheel/alignment problems in my '97 Camry LE 4-cylinder, however (66K miles).
My Camry has developed the creak in the steering. It doesn't sound "mechanical" however, more like plastic rubbing against plastic. Annoying but apparently harmless.
http://www.caranddriver.com/xp/Caranddriver/carnews/carnews_spyshots.xml
IS300 convertable, at $35K a pop would really be nice if they make it into full production.
ral2167: Did you make a comparison of the spy picture and the concept pics posted a while back? The over all shapes seems to match along with the visible portion of the front. I think this is it.
Then, I realized that many participants may not catch the humor and prattle on for months about Toyota decontenting the 2002 Camry. AAAACCCCKKKK!!!!
But I don't fret over it as long as it doesn't impact reliability. So far, Toyota has succeeded in keeping the reliability high, so I won't go nuts if a few little straps or little hooks goes missing in the new model.
If it hints these major point that I expect, then I'm happy: (1) as reliable (2) roomier (3) peppier (4) as quiet and comfortable (5) doesn't totally screw up the styling inside or out.
Looking good so far.
http://mag-x.com/scoop/scoop_tm.html#camry
1. Little to no heat when you have the heat aimed to the floor. When you switch to chest level heat, the heat is very noticeable, almost overwhelming. Dealership said the floor vents were closed but I haven't noticed any difference and my feet are still freezing.
2. Car windows continually fog up while driving and back seat side windows (especially passenger side) will not defrost no matter what I try. It makes it very difficult to see.
3. Disappointed with gas mileage - 21-22 mpg all highway miles after 4K miles driven.
Had the dealership check into with no results. Any suggestions?
1. Toyotas seem to have a longer period of "break-in" before the mpg jumps up. Usually around 10K-12K based on my past toyotas.
2. If you live in the north (cold) areas, you have reformulated gas for winter months, and that worsens the mileage to the tune of 1-2mpg. Mine is usually around 24 in the winter.
3. The V6 recommends premium fuel. It will get better mpg and have more power with premium. That being said, I've mostly run 87 octane in mine because the cost/savings doesn't add up between the octanes. The minimal performance difference doesn't bother me for the most part. My 92 V6 has 180K miles, and around 150K we switched to 89 octane because it seems to run better. Most vehicle lose power as they age, so I suppose that has something to do with it.
As far as problem #1, I dunno. I've had several Camrys (92-present)and never had a problem with heat. I totally agree with Cliffy on problem #2, most fogging problems are from "recirculate" mode being used. That mode is more for summer use. When you have the setting on defrost, the AC runs which should totally eliminate fogging unless it's recirculating. If you do not have the recirculate set, and the fogging continues then you have problems, possibly a faulty heat coil or something which might explain your floor heat problem.
Leo
I got about 6 free oil changes with my Camry and they are at 7,500 mile intervals.
I plan on keeping the car for along time so I want to make sure it lasts.Thanks!
If you want to play it safe and change your oil every 3000 miles, that's fine. But, save yourself some cash by learning how to change your own oil and do it yourself.
A guy I used to work with used to have a Nissan Maxima and he'd change his oil every 15,000 miles. At each oil change, he'd add Slick 50. He got 225,000 miles out of the car.
If you have the inclination to do the oil changes yourself, by all means do so.
But I wouldn't take chances with 15K oil changes; at the very least, any warranty claims related to engine damage will be denied.
And IHMO, Slick 50 is expensive snake oil.
Wassabi
My dear old Camry (170K miles) suffered an injury coming over a big steel plate in the road. A hole was punched in the transmission pan, and the pan needs replacement and of course new fluid.
What actually happened is that after the bump, the car was running with odd sounds, like roaring and grinding in the engine. It managed to go 12 highway miles (at 60 mph) back to the airport, and restart after a one minute park. It sounded as though it was not finding the right gear as we accelerated awkwardly back onto the highway, and it was gunning and slowing down. We had to pull over and stop. After the engine was off for a few minutes, it started up fine, but wouldn't move out of park. That is, the gear shift would move but pressing the accelerator did nothing in any gear besides gun the motor. The garage has just called to tell me they will replace the pan and fluid for 200$, and then see what happens.
Here's my dilemma: with such an old but pretty reliable car (head gasket leak, kicky transmission, but never breakdowns), is it worth it to spend 200$ on a repair that may not be all that's needed? We were probably going to get rid of the car in the next 8 months anyway, but if anyone here thinks the pan and fluid are all that are needed, then we are willing to go ahead and repair. The garage did not hazard a guess as to odds that the transmission will not need to be rebuilt or replaced.
Thank you,
Juliette94
p.s. I am posting also in other boards
My friend wanted to perform 75K mile service on his 93 Taurus. There was an old couple doing first oil change on their Toyota Camry LE. I had a small talk with her, she said it was their second toyota first one being 82 Sxxxx(?) which they dumped after 238K miles ! She hoped this Toyota would also run forever !! She also mentioned how she liked the quite ride the toyota gives!! How many GM owners would drive their vehicles for 200K miles ? -:))
Two choices 1. obviously try the $200 fix and see what happens. 2. Try to find a cheap junk yard tranny and have them swap it out. Really shouldn't cost much, but you never know. I would try the $200 fix and see what happens.
