When I purchased my 2002 Camry XLE-4 the sales person suggested that I change the engine oil every 3000 miles. The manual says to change it every 5000 miles under normal driving conditions. Should I follow the maintenance cycle of the manual that was printed for the car or does anyone know of a good reason why the oil should be changed more frequently. I hope it was not just an overkill suggestion by the sales person because of Toyota's oil sludge problem on some of its engines. The engine in my Camry is the 2.4-liter DOHC, 16-valve VVT-i 4-cylinder type.
Does anyone have any information regarding the factory oil filter vs aftermarket filters? They look a little different and I was hoping to get some feedback for my 2002 camry. thanks.
Tried to replace plugs, on front of engine. One went ok , two went sour. Removed the ignition coil and the boot remained on the plug. Can't pull boot out. Talked to Toyota parts man,who asked the service tech. The service tech claims that the whole ignition coil needs replacement at a cost of $95.00 apiece. Thinks I'll look around junkyards to find some.
Does any one if camry requires special maintenance at 30k miles?. The manual says to replace the coolant in addition to regular oil and filter change. When I called the toyota dealership the service person recommended replacing coolant + transamission fuild + fuel canister + pcv value and whole lot of other things for $375 package. Is it really necessary or should I only go for oil, filter and collant replacement. I live in Michigan and do not tow anything.
Yes, at 30K you should do the following: 1) Oil and Filter Change 2) Transmission Oil Change 3) PCV Valve 4) Adjust all Belts 5) All remaining filters 6) If not Platinum Spark Plugs, change them (their Cheap). 7) Coolant 8) Check, maybe change tires 9) Inspect suspension, Trans axles
I would have to contact my personal mechanic for further details as to what else is normally changed at 30K.
I own an 04 SE 4 cylinder Camry. I'm about to change the oil for the first time. Can someone tell me where the oil filter is. Also is it difficult to change the oil on the new Camrys. Your help is appreciated.thanks.
I am looking to change the fuel filter myself. I know where the filter is...but it looks quite impossible to get to it and change it.
Has anyone changed the fuel filter themselves, and how did you go about doing it?
Btw, for those looking to change your own oil, I HIGHLY recommend buying one of those valves to replace the nut on the oil drain. Makes changing the oil much faster, and less messy. There are several on the market, but I am using the SureDrain (I think that's what it's called - sold at Walmart). Has been working fine for 2-3 years now.
I own a '02 4cyl Camry with 29k miles. I recently had to replace the engine. So, the engine is new, but the rest of the car has nearly 30k miles on it. Do I follow the maintenance schedule based on the odometer or the engine? If I do it based on the engine will I be neglecting other important items? Thanks.
Just wanted to revive a topic that was started before but I didn't see answered ... any consensus around whether the dealer recommended 3000 mi. or manufacturer recommended 5000 mi. service was preferred or ... practical? TIA
The fuel filter is connected to the stainless-steel fuel lines by 2 hex nuts. The threads on the S S fuel line are sometimes damaged during assembly. The hex nuts therefore cannot be easily open! One would have to exert a lot of torque on the hex nuts to overcome the bad threads' resistance.
The shops have a special box wrench designed to prevent damages to the hex nuts as it is torqued.
If you damage the fuel line, you cannot drive the car to the shop. It must be towed in, which may cost a few hundred dollars. If you fail to assemble the 2 hex nuts properly to the fuel line, you risk having fuel leaks in the engine compartment, which can be very dangerous.
I took my '93 Camry with a factory fuel filter to a trusty mechanic and had it replaced for $20. Better yet, have it replace at a reputable dealer.
Fuel leaks can be deadly and are not something anyone should take any chances!
3,000 miles. i drive 35,000 mi/yr; long, country miles which are easy on a motor. still change ea. 3,000. had a pontiac bonneville with 160,000 mi on it when the tranny died. changed oil ea. 3,000 mi. have a 1967 mercedes 250S sedan with a zillion miles on it. change oil on that a lot. old and tired, needs and deserves tlc. good luck
New to Toyota, bought 1998 Camry for son. Runs great but malfunction indicator light just came on. I tightened gas cap and light still stayed on. Manual says to bring to dealer which I would like to avoid. Any ideas what to check? Also any good internet sites to buy OEM mats for a 1998?
i'm actually going by the manual (2001 camry le) which says to change them at 60,000. i'm at 65,000 right now. i thought they (the plugs) would be easily accesible. this is my first newer auto and all my others were simple to change. do i need to remove the the valve cover(?) to gain access to the plugs?
Sorry about that, I thought they were using 100,000 mile plugs that year. No you don't need to pull the valve cover. Take a firm grip on the plug wire head (the part right next to the cover), not the wire and pull straight up firmly. You will need the correct size plug socket(deep well) and at least a 6 inch extension (12 inch would be better)along with a ratchet. It is a very close fit, so you won't be able to get in there with an extra thick cheap type. Don't over tighten them when you put in the new ones. Good luck.
thanks bud. i appreciate the advice. you know i was checking out the plug wire heads next to the valve cover, and you're right it is a very tight fit. i pulled on them before i came to this site for advice, but they seemed like they didn't want to budge and i was afraid of breaking something. i'll come back and let ya know how i fared. thanks again!
I try to listen to the mechanics with radio shows on the weekends. All recommend that cars with 100K mile plugs should have the plugs loosened up at every 30-40k miles and retightened or else there is a very good possibility that the plugs will stay there for life. They have encountered enough owners that have come in for the 100K change and found the plugs impossible to remove or have customers come in with broken plugs, having tried to remove them at 100K by themselves.
I had a 1998 Camry and it had exactly the same problem. It is caused by oxidation in the light bulb socket assembly. Not enough to prevent the bulb from working, but enough to fool the electronics into thinking that the bulb is out. Assuming that all the bulbs are OK, then remove the front left indicator assembly. Consult your owner manual which describes this procedure under light-bulb changes. The left was always my problem. I don't remember exactly, but you may have to remove the headlamp asembly first to remove the indicator assembly. They are very easy to remove, secured only by a couple of bolts and they clip together. Remove the indicator bulb and clean the terminals with a light sandpaper and make sure that the bulb socket is connecting securely in the housing. Reconnect, reassemble and your problem should go away for 6 - 8 months, but it will be back!
I drive a 4 cyl 2002 Toyota Camry XLE. I have not had one problem the 28 months I have driven it. In addition, I regularly change the oil and filter myself.
However, just today I was cruising on the freeway and noticed on the bottom right of my instrument panel what looked like a check engine light. The manual says it's a "Engine Malfunction Lamp" and that I am suppose to take it to a Toyota Dealer for them to check it out.
The light came on around 24,500 miles on the odometer. Is this just a reminder to get some upcoming 30,000 miles service done on the car, or could it actually be something serious?
No it is not a service light. You have a malfunction that may or may not be serious. You are under warranty, so take it to the dealer as soon as possible. My guest it will have something to do with your emissions system.
You Camry has an OBDCII plug under the steering wheel. Go to Autozone and have them do a free plug-in diagnostic readout and tell you the code. If the resulting code(s) arenot readily defined, search for it (tehm) on the web. Usually, you will find the source that way and save money by begin able to either fix it or bring it to an non-dealer mechanic to fix for you.
Thanks for everybody's response to the malfunction indicator lamp.
I was excited to hear it was possibly only the gas cap. Well, my father had just borrowed my car and out of the kindness of his heart re fueled my car. In doing so, he put the gas cap on, but didn't tighten it so it "clicked." So I eagerly tightened it so it "clicked" and started up the car.
Unfortunately, the Malfunction Indicator Lamp stayed on. Bummer. Well, this morning, 2 days after tightening the gas cap, I planned on visiting a Toyota Dealership to see what's up. While driving, I noticed the Malfunction Indicator Lamp was no longer lit, it was out.
That's my story. I hope it doesn't come on again. Thanks for all the advice. Happy motoring.
Maintenance calls for trans service @ 30K on my '02 V6. Dealer wants $130 for a flush and fill. Why not just drain and replace fluid? What's the capacity if I just drain and fill myself. Flushing at 30K just sounds like a money maker for the service dept.
With electronic ignition and fuel injection, the cars require very little and very simple maintenance.
I had a 89 Camry LE (250K) and 93 Camry LE (200K) and had no problem doing all preventive maintenance myself with no mechanic training and mimimum amount of tools. The cars all ran great with no problem.
1. Changing engine oil and filter and transmission fluid to owners' manual schedule is very easy. Just buy a flat oil container to store the used oil and recyle it at the part stores. Use a steel tube to lengthen the wrench handles for extra torgue to open the tough oil lugs.
2. Change front disk brake pads when the sensors start sqeaking. Toyota's OEM pads last longer on the rotors and will not make noise. I do much better brake jobs than any brake shops, spending much less time not having to wait around at the shop. Bleeding the brake fluid every 2 years should improve brake performance.
3. Adjust the rear drum brake. Replacing the shoes is possible but the shoes hardly work and are rarely worn! It's much safer to buy the SE or XLE with 4 disk brakes to take full advantage of the ABS. Save a lot of time replacing pads too!
4. There is no need to service the fuel injector unit. Every 20K miles, give the car a full tank of premium gas (Shell V power with 5 detergents etc...) with 1 bottle of injector cleaner. That should keep the injectors nice and clean, and the cold start sensor and mechanism to work properly.
5. Replace the air filter to schedule to keep the fuel injector clean and fuel efficient.
6. Replace the spark plugs on schedule. Use a small rubber hose to pick up the plugs from the wells. Do not use Platinum plugs for cars specified with resistor plugs, since that will stress and overheat the ingition coil and eventually burn it out.
7. The rubber timing belt is inside the engine head. Most break at about 100K -120K miles. When they break, nothing bad happens to the engine since it's a non-interferent design (unlike Mitsubishi's design). The distributor rotor is gear to this belt and will stop turning and engine just stop running. Call a tow truck to a reliable shop for $150 replacement. It may make sense to replace the water pump at the same time.
8. Buy a lifetime all-wheel aligment policy for about $200 at tire stores (firestone or Sears) to keep the wheels aligned. The car will run smoother, eat less gas and will not chew up tires.
9. I prefer Michelin's all season tires since they are proved to last longer, ride smoother, wear evenly, leak far less air through the rims therefore I dont have to check pressure too often.
10. US-built struts will probably wear out at about 100K. Replace them with Japanese gas struts and they should last a life time. Worn struts can induce instability and chew up tires which can cause extreme hazards, like spinning, skidding and roll over.
11. The US-built plastic-top radiator will probably leak at about 100K miles. Flushing the radiator every 2 years should prebent premature corrosion. Check for water leaks under the car occasionally as overheating can crack the engine beyond repairs. A new radiator should cost around $200 part and labor. I replaced my own for far less by removing a few screws and hoses!
12. If the car is misfiring, there is a chance that the spark plugs, spark plug cables or distributor rotor are worn. Replace them 1 at a time and check progress.
13. Once a year, take the car to the self-service washing station, wrap the distributor cap in plastic to prevent it getting wet, spray the engine with degreasing fluid and hose it down. That should keep the engine nice, clean and shiny, which would point to any oil leaks or any worn belts ect...
14. Spray some of the degreasing liquid in #13 on the rubber boots around the 2 axles and the rack and pinion assembly underneath the engine. That should keep the acids in the engine oil from cracking the rubber and letting dirt into the greased ball bearings etc... so you won't have to replace them.
15. Check engine belts every year. Replace them when there are cracks on the underside.
I have 36,000mi. Should I have the PCV valve and fuel canister replaced? Also, can I just drain trans fluid thru drain plug? I know this only drains 4 quarts. Or should I have someone with a machine drain the entire system?
You don't need to have any of those services done at just 36,000 miles. Check your maintenance manual.
By fuel canister, do you mean the charcoal canister or the fuel filter?
I used to change my '97 Camry's transmission oil by just draining it through the drain plug. You can only get about half of the fluid out that way. I didn't want to spend the money on a flush nor risk someone messing up the transmission.
I just looked at my owner's manual. I am amazed that is says I may NEVER need to replace my ATF if I don't do any special driving conditions. The fuel thingy is something a read about in another post. The service schedule doesn't say anything about either the charcoal canister or the fuel filter or the PCV valve that I could see. When should these be replaced?
I believe you are correct on never replacing the ATF in normal driving conditions on the newer Camrys (I don't have my maintenance book in front of me).
On my '97 Camry 4-cylinder that accumulated 111K miles before I sold it, I never replaced the fuel filter, charcoal canister, or PCV valve. I don't believe any of these need changing either unless there's a problem.
Some say the fuel filter should be regularly replaced, but I understand it's tricky to do on the Camry. You have to know what you are getting into.
My '90 Mercury Sable also didn't say anything about changing the fuel filter either, but I did change it (with assistance) shortly before I sold the car at 135K miles.
The scrape plate (assuming that is what it's called; it's the plastic covering the front axle components underneath the car) on my '02 Camry LE is coming off. It appears that all the screws on the rear side of the plastic pieces are missing. The result is that the plate is hanging. Typically not an issue; the most serious consequence is that the thing scrapes against most speed bumps.
I am unable to get under the car to determine if this is something I can fix myself. So, I have these options:
1. Do nothing. Should I even consider this to be a problem that needs a solution? Driving isn't affected.
2. Bring it to the dealer. I'm concerned that I'll be charged a small fortune for performing a very minor service (putting in a few screws) and perhaps get jerked around into replacing the pieces entirely.
3. Bring it to a mechanic. Similar concern about gouging. Plus, will they have the right parts?
4. Remove the plates. I should be able to do this. However, would my car be harmed?
I'd get it looked at. The scrape plate ("splash pan") minimizes water and road gunk from getting into the engine compartment. It's not ABSOLUTELY necessary, but I wouldn't take mine off.
I don't trust dealers and avoid them like the plague, unless I need warranty or recall work.
Do you know a good independent shop? Where do you normally get your car serviced?
If you can get under the car, maybe you can tell if the bolts are in fact missing, or if the pan has broken away from the bolts. If it's the former, the cost to fix will be minimal. If it's the latter, you'll need a new pan, but the labor cost should still be minimal. I don't know how much the pan itself costs.
An independent shop can order the part from the Toyota dealer.
my 99 camry LE has reached 90k and i called a local shop for its 90k maintainance. They said that along with changing timing belt, they recommend to change the water tank and a few other things as preventative measures, since the mechanics will be touching that part of the car, i'll be saving some labor cost. Is this necessary at this time?
The other problem that I have with my car is that the little spring-like plastic of the cap/doorx to the gas tank is broken. So now filling gas has become a pain -- either i have to have another person to help me, or i had to use a key or some thing to keep the levelling the lever so that i can open the cap/door. I asked the mechanics, they said it's at least $300 to repair it, because they have to take the whole thing out and replace it. Is there a cheaper alternative?
c) I have been changing oil on this car between 5k-7.5k (mostly high way mileage), now that it has reached 90k, should i switch to 3k schedule?
When I had my timing belt changed in my '97 Camry 4-cylinder, I also replaced the timing belt tensioner spring, the crankshaft oil seal, and the two drive belts (alternator and power steering). These items are all relatively cheap, and none of them had previously been replaced. I did not have the water pump replaced.
However, if there are signs of leakage, the water pump should be replaced. Otherwise, it's a gamble: don't replace it now on the assumption it'll last another 90K miles, or replace it now so you won't have to spend a lot of additional labor hours replacing it later.
I'd recommend changing the oil every 5000 miles or 6 months, whichever comes first.
On your gas door, I'm unclear if the problem is the latch on the door itself, or the cable connecting the release lever on the floor with the latch. If it's the latter, the cost could be high due to the labor involved.
If it's the gas door latch, maybe you could find a matching, intact gas door in a salvage yard?
I have a suggestion that will probably cost you about 99 cents to implement.
Go to a local hardware store and purchase these little 3/8" diameter round, black, self-adhesive rubber feet. These are usually used to apply to the bottom of items that you want to sit on top of a desk or table to protect it's surface. Buy the THICKEST or largest (they're usually about 1/4" thick) one's you can find.
Look inside where the wall of the car is and try to find a place where if you had applied one, it would then require a TAD amount of pressure to close the door. Put it in that location with a piece of scotch tape and close the door. Then, open the door and see if it POPS open. Once you've found a good location, then peel off the adhesive coating on the back of it and mount it (semi) permanently with that. I would also suggest that you thoroughly clean that area before mounting so that the adherence would last.
If you can't find a place that's flat/opposite the door, look somewhere near/on the hinge.
I do oil changes at the DEALERSHIP just about every 3,000 miles. I am actually surprised that they have a "special" so frequently, that it winds up usually costing only $19.99. I also call the mechanic in so that I throw in a $2 tip!
I'm under lease and am slightly PARANOID about maintenance. I've ALWAYS believe strongly in (over) preventive maintenance.
I also rotate my tires every other oil change.
I just bought a Sears TORQUE WRENCH because from now on after I've taken the car back from them doing the rotation, I'm going to RE-TORQUE all the wheel lugs JUST TO MAKE SURE that it is done right.
I hate to have to say this, but I believe the BEST way to maintain your car is to do it YOURSELF. Of course, the next-best thing would be to have a mechanic do it WHILE you are standing there. Where I lived before, for many years, that was the case. The mechanic would allow me to stand there WITH him while he did the work. So I was pretty much guaranteed that it was done right. He actually made a few mistakes during those years, but FORTUNATELY I was there to point them out to him at the time.
Any advice on what's involved in changing the spark plugs on a V-6 Solara? It appears that taking off the intake manifold would make things a lot easier when accessing the rear bank. Any thoughts?
Sorry I can't give you a conclusive answer, but I might be able to shed SOME light.
I would recommend you use the EXACT plug that the car came with. I have found that there are discrepancies at the different websites as to which is the right plug for my car.
I went to the dealer to buy the plugs and he gave me a substitue. My picky brother-in-law told me to return them and suggested that I use the EXACT same plug as in the manual and/or pull one out of the car.
As it turns out, my car (2003 Solara SLEV6) was made with TWO different engines in the same year. And so the plug would differ depending upon the engine. But not ONE of the websites nor the dealer would even ask that question. So I pulled a plug and sure enough it DID match what was in the owner's manual.
The best price I found was at www.RockAuto.com.
According to my owner's manual, the plugs are good for 60k. I'm at 48k now and intend to replace them as soon as I thaw out (New Joisy is cold).
At the same time, I'm also going to replace my PCV valve and fuel filter. I'll also remove my air filter container and clean it thoroughly and replace the filter. I'll then change all 4 brake pads. ALL TOYOTA PARTS, I might add.
In my experience, the Toyota parts are not really that much more expensive than aftermarket, and I am convinced that the parts are of better quality. And if you're doing it yourself, you're saving money anyway.
i have to do a 60k maintenance on my 99 camry. The mechanic told me to get the fuel injection service done and to replace the ignition plugs and ignition cables. I talked with another mechanic at MIDAS and he told me that ignition cables need not be changed as a part of 60k maintenance. I am confused whether to get them replaced or not? how critical is it for the performance. The first mechanic told me that there are some little white marks on the ignition cables which happens when they touch each other or something of that sort...the cables cost $100...i am in two minds now...as such i don't see any problem with the performance of the engine...can someone help me with this?
New member, first post. Walmart oil changes trashed my pan. They seem to prefer to get to the oil filter from below. Anyway, two bolts near the center were missing, the pan dropped down and was dragging when I hit low spots. On the 03 Camry it is a 5/16" bolt 18 threads/inch. Also on the 03 it seems to be holding the front "bumper" together. The bumper was loose until I pulled it together by replacing these screws. I check them after every oil change.(not walmart anymore) I was amazed that the bolts on the 03 were not metric. I had to clean up the threads on the car with a thread chaser.
As you know, the only way to get to the filter is from below, but it's not necessary to remove the plate. There is enough clearance to get the filter off.
And 5/16 inch = 8 mm, so the bolts are really metric.
Follow your owner's manual. You only need to get the spark plugs changed (as well as the oil and filter, coolant, and air filter). The tires should also be rotated and the brakes checked. The underbody should be visually inspected. (But I wouldn't use this mechanic; he'll undoubtedly find something "wrong" with the tires, brakes, exhaust, you name it.)
Forget the fuel injection cleaning, the spark plug (ignition) wires, and the rear struts. Maybe someone else can advise, but I think only the front strut bushings (at the top of the struts) have to be replaced if they make the noise.
I had my '97 Camry 4-cylinder till 111,000 miles and never did any of the above (other than the required maintenance and the replacement of the right front strut due to a crash).
The few times I have changed my oil, I removed the filter from above with no problem. Had my radiator flushed and oil changed yesterday and the filter was removed from above by the "pro's" O3's must be easier to get to than yours. No sense arguing about bolts. I went through all the metrics and none would fit (too large or two small). The SAE cured the problem!
Thanks for your help
3) PCV Valve
4) Adjust all Belts
7) Coolant
http://minimopar.knizefamily.net/oilfilterstudy.html
good luck
Thanks for the help in advance.
epond
epond
How long did your CV boots and engine belts last? Also how do I determine if I have resistor sparkplugs?
(My camry: '99 LE V6 w/ 67k miles.)
I don't remember ever replacing the axles and their CV boots in this car. The engine belts were replaced once at about 150K miles.
Remove a plug and bring it to part stores or your Toyota dealer and buy the exact plugs. Also ask them whether they are resistor or Platinum.
Stick with the exact OEM plug brand and model number for best engine performance and fuel economy. Use anything else and you may be taking a chance.
Thanks for any advice,
Jerry
thanks.
