Panel lights blinking
I just acquired a Florida van, I live in Buffalo NY and it is very cold! This morning I started my 2001 Voyager, put the headlights on and all of a sudden the dashboard lit up and everything started to blink. The fuel gauge, door ajar, oil, battery, just to name a few. The check engine light is also on, I noticed that yesterday when it arrived. I was able to drive to work a mile away but the speedometer sort of blinked it did not work correctly, on the odometer the 61 of 61513miles blinked, the wipers worked the heater worked. I don't think this van appreciated the drastic temperature change!!. Any suggestions as to what the problem is?!
Sometimes when electrical stuff goes crazy, the battery is marginal. It may seem to crank the car okay but I'd have it load tested somewhere. Lots of auto parts stores will do that for free. The battery could be older and the cold wouldn't be helping it either. If it's okay, then check the cables.
Any variations in voltage will cause your car's computer and other modules to run erratically.
You should also have the car scanned for trouble codes to see what that CEL is all about.
It's possible this is temperature related, given how batteries do become weaker as they get colder, but it's also possible that the van had these problems beforehand.
